Hi,
I'm Dutch, live in the south of Holland, in Berghem a small village with my wife, i am retired.
I am new here and hoping  to start to build HMS Winchelsea  1764 in 1/48 as well.
Inspired by all the other beautiful builds here I downloaded the plans en ordered the first en second chapter in yellow cedar.
Thanks
Jan
Jan van Oorsouw
current build:
HMS Winchelsea 1764 1/48
on Hold:
Triton cross section
Speel-jaght  1662  (Kolderstok)
Sloop Mediator 1745, (plans Jeff Staudt.)
Thank you, Ron, Chuck and Greg I look forward to the moment to be able to start with the Winnie the lockdown makes it more complicated to get good building materials, but soon I will start making sawdust anyway
Jan van Oorsouw
current build:
on Hold:
Welcome to the group, and happy modelling.
Just take your time and above all enjoy 🙂
Current builds;
 HMS Winchelsea 1764 1:48
Completed:
Welcome aboard Jan.  You chose quite an attractive model to build.  This group project has a number of talented and very friendly model builders.  Feel free to ask questions about anything, as no question is too stupid.  😉
Tom
Hoi Jan,
hartelijk welkomen in onze groep en veel plezier bij het bouw van deze mooie model.
(welkom in our group and a lot fun building this fine model)
Regards Christian
Thank you Vladimir, Edward, Tom and Christian.
I will not fail to ask questions if I get stuck in this great project
Jan van Oorsouw
current build:
on Hold:
Welcome Jan! Nice to see a fellow countryman here building HMS Winchelsea too!
I’v just started as well and will be following your build closely. Hopefully we can learn from each other and avoid nasty mistakes together. There are many skilled artists here: very, very experienced builders who are willing to help you along.
I wish you good luck with your build,
Frank.
Current builds on MSW:
HMS Winchelsea 1:48
Prior builds on MSW:
None
Here's my first question. What do you think is best for plywood?
I have 2 choice's Birch 5-layer or Poplar 3-layer,
I have read in various construction reports that the protruding parts of frames break off, so my choice goes to Birch, this is stronger but harder so that it makes sanding more difficult.
Like your opinion.
thank you
Jan van Oorsouw
current build:
on Hold:
Thank you Chuck, Polar it will be
Jan van Oorsouw
current build:
on Hold:
With Baltic Birch plywood you will be sanding until your arm falls off.  It's Poplar core without question.  Yes, Poplar core is weaker than Baltic Birch.  You just have to be very careful around protruding pieces, and use temporary reinforcement.
Tom
Edited by wyz
Thank you for the advice
Jan van Oorsouw
current build:
on Hold:
Yesterday the package came in with the laser parts from chapters 1 and 2 so today I could start making sawdust.
I started cutting out the false keel and bulkheads with my scroll saw. my previous ships were max. 20"
So this ship is a monster in my opinion, it is a lot of work, but we have the time and take it easy.
I also immediately made the supports to fix the hull to the building board from waste wood
Jan van Oorsouw
current build:
on Hold:
Hi Jan,
I'm happy your first chapters arrived :) Just a word of advice from someone who didn't get Chuck's bulkhead set...pay particular attention to the placement of the markings on the bulkheads. A millimeter off here or there will mess things up later on. I learned this from experience. Looking forward to pictures!
Ron
Current Build- HMS Winchelsea 1764 1:48
This week I've been making the false keel and bulkheads.
I also assembled the bow.
What you see is the test fit of the bulkheads.
Next week I start making the keel and gluing the bulkheads after which the sanding starts
Jan van Oorsouw
current build:
on Hold:
Why do my photos appear upside down in the construction report, even if they have already been turned around
After a bunch of testing, I found the problem. It seems my Samsung Phone has a gravity device so when you turn the camera to Landscape from Portrait the screen follows - As long as you keep the click-button on the right!. So not only does the photo have a GPS stamp, it apparently has a "This side up if you click with the button on the right.
Edited by oorsouw53
Jan van Oorsouw
current build:
on Hold:
With plastic aircraft modeling this wouldn't be a problem Jan, but a frigate doesn't make any loopings I'm afraid...
You're makeing nice and steady progress!
I'm already offically lame in my right arm form sanding the bulkheads..
HMS Winchelsea 1:48
None
