14 hours ago, LucienL said:
I think it would be better to make sure that the brass piece was fully bent to shape before gluing on.
This is a good general rule of thumb for all materials. Glue can hold things in place, but ideally should not have to hold much tension. You're making great progress!
On 4/9/2021 at 4:59 PM, LucienL said:
The metalwork on the transom was one of the more difficult parts of the build so far. I was a bit messy with the CA glue at first and continued to clean it up for a while. I planked both sides of the transom after bending so that the planking would still be visible on the poop deck.
The top rail was a bit of a challenge as it almost needed to bend in two directions
Here is my first scrappy attempt at the decorations, you can see a lot of the CA glue residue as I kept taking it off and bending it again to get it right. I've realised now that it is good to have some soft-nosed pliers for this work as well as the flat nosed ones for bending and straightening respectively. I think I was hoping that the CA glue would hold the brass in a bend, which was a mistake. I think it would be better to make sure that the brass piece was fully bent to shape before gluing on.
I also varnished the paint to make it dull again
It might be difficult to see, but the varnish did make the white look a bit dirty and yellow
Here are the davits
Also, I re-did the doors using the oak stain and also a little bit neater than the old ones
And this is the transom after some more tidying up
Looks good. It does help to have the right tools , like round nose pliers . Makes it a little easier
Okay, so now I’ll talk about my first coppering attempt, which did not go that well. First, choosing material; I initially was unsure about using copper tape as I was worried it would be too thin and not sticky enough. I was hoping to just find a thin sheet of copper, which I would then use to cut the plates out of. Eventually I found a wide copper tape from an electronics supply store. I then attempted to patina them with ammonia fumes. To do this, I suspended small pieces of the tape over a container of the liquid ammonia. I put a lid on the container and allowed the fumes to darken the copper. This gave an extremely inconsistent patina ranging from almost black to blue-green.
This may be what some people are looking for, but I wanted a dark brown patina. I am sceptical that the plates would have been installed shiny on the Beagle. This was a time before rapid transport of materials and the plates would have been unlikely to remain clean and un-oxidised on their journey. Someone who knows better may be able to correct me, but this is just my feeling. Also, more importantly, I did not think that the shiny copper plates would have fit aesthetically with the Beagle as a working boat. I feel it better suits a large first rate ship of the line than a somewhat ill-equipped survey ship from an unpopular line of naval ships.
Also, cutting the plates out of this copper tape was very difficult. It was a constant challenge to get them all cut to the same width and evenly. This also resulted in a lot of handling and a loss of patina. Some of the plates were glued on using contact glue as the ageing process caused the paper backing to fall off and the glue to lose its strength.
Once I realised that I was unhappy with this, it was back to the drawing board. I had also tried bicarb soda to age it (which did nothing) and a copper carbonate and ammonia blackening solution (which also did not give the desired effect). I did some more research on patinas and came to the conclusion, that to get the patina I really wanted, I needed to use what the professionals use, which is liver of sulfur. I also bought some 5 mm wide copper tape from an electronics store so I wouldn’t have to cut the plates out of large copper pieces.
Previous builds: HMS Bounty's Launch (Model Shipways), USS Albatros (OcCre)
Current build: HMS Beagle (OcCre)
Future builds: HMB Endeavour (Caldercraft), De Zeven Provinciën (Kolderstok), HMS Victory (Caldercraft/De Agostini/Artesania Latina/Corel)
Okay, so now attempt 2 at the coppering. I bought liver of sulfur in the gel form from a jewellery store online. The gel form is better as it doesn’t lose potency quickly like the solid form does. https://koodak.com.au/products/liver-of-sulphur-for-silver-copper-brass?variant=30180608397. There are some very useful tutorials online on how to use the stuff and what to be careful about, I’ll outline the main points.
I added about 3 mL of the gel to a cup of boiling water from a kettle (not rolling or bubbling just steaming). It's good to let the water cool a bit before adding the gel. If you boil the liver of sulfur, you get toxic sulfur dioxide, so be careful. The hotter the water is, the quicker and deeper the patina will develop. I tried colder water, but it ended up more purple than brown. You have to be quick to get the copper done quickly as the water will cool and the strips dipped later will be a different colour to the ones dipped earlier.
Then I stuck the copper in for a couple of seconds, as soon as there was a colour change (again, you need to be quick, a second too long will make it too dark), I took it out and stuck it in a bicarbonate bath. The bicarb bath is meant to halt the reaction, but it might change colour after it dries a bit. I went through a few trials at different temperatures and leaving the copper in for different times to get the colour I wanted.
I set up a bit of an assembly line, with the copper strips and then a rectangular container with the liver of sulfur solution. Then I stuck in maybe 3 or 4 strips, by the time the last one was in, the first one was ready to take out. Then I had the bicarb bath and stuck them in straight away. It doesn't matter how long they stay in the bicarb bath; they will still change colour when they are taken out.
After the plates were on the ship, I lightly buffed it with some fine steel wool to make it a bit more orange again (careful to not turn up the corners of the plates). One side was a little too dark and the steel wool made it similar to the other side.
This was my first batch of plates and it did come out a bit too dark and purple, I think I left it in for a little longer than the other side. Anyway, it looked different after some varnish.
Please note, this is a mistake, do not repeat what I have done. The varnish is not a good sealer for the copper (this photo the varnish is still wet). I'll show in a couple of posts, but there were many problems with using wood varnish to seal the copper. The liver of sulfur does not dull the plates and the patina is still shiny, so it does need some kind of dull coating to look accurate at scale.
In terms of actually cutting the plates and placing them, all I can say is; have a sharp blade, be patient and don't be unwilling to take plates off if they are wrong. Anyway, time for photos now...
Really like the copper plates you have done, the kit provided ones for other builds I've done are all a bit too nice and shiny for my liking and you have gone to the trouble to darken yours, wish I had!   So good to see someone making their own - well done! 👏
Andrew
Completed (Kits):-
Thanks AJohnson, it definitely adds a lot of time to the build, the experimentation was quite time consuming, but I feel it was worth it.
Hello everyone, and welcome to another episode of me slowly losing my sanity, today we will be talking about the rudder.
I ground down the pintles and gudgeons provided to make the scale a little better and also drilled a few extra holes.
Then after a very long night I was able to assemble the rudder hinges and attach them to the boat. This is where things go wrong…
First and most obviously, this should not have been after the copper had been varnished. Drilling into the hull caused some of the varnish to flake as it did not cling to the copper properly. Second, while the hinges here do run parallel pretty well, they are not perpendicular to the sternpost as they should be. After some more painful back and forth, I decided that this was unacceptable and re-did it…another long night
While this did correct the angling issue (mostly), the varnish flaking got worse (foreshadowing).
Anyway, then I decided to ignore this little area of the boat and work on the bow.
Ominous. Going back and fixing things one doesn't like is often frustrating but usually feels better afterward.
Sorry for the break between posts, just been dealing with a hectic couple of weeks and haven’t had much time for boat related things.
It took some fiddling, but I did eventually get the bow details the way I wanted. I added another scroll at the bottom
Also, there is a little confusion between the photo instructions, videos and materials list regarding the sizes of the wire you’re supposed to use. The videos indicate that they should all be 1 mm, but the parts list says some of them should be 1.5 mm. I went with the parts list as I figured this would be the best way to avoid running out of material.
I also used some filling putty to connect the rails to the boat and make it look a bit more like one piece. As with all my metal work so far, it started out a little scruffy, but I’ve been working on slowly tidying it with a Dremel and a blade.
Unfortunately even with me being frugal I still ran out of 1mm brass. Its inevitable so if you dont have any available I would order it now before you get to page J where you will definitely run out.
Also had the same issue with the paint looking clumpy and someone suggested watering down the acrylics so help it be more smooth and clean looking.
I still have 30 cm of 1 mm (3 rods), I just had another look, I will not need that much, maybe my kit just had a bit more, I'm not sure, I can't think of anywhere where I may have saved brass. If I'm missing something, I still have my 0.8... aluminium that I used for the scroll. (it's in some imperial unit🤮).
Might have another go with the paint, thank you.
Also, no offence to people who do use imperial, I am just not a fan
I've grown fond of metric but it's hard to find things in the US that isn't in imperial lol. My kit only came with 6 brass 1mm rods so you might have gotten more probably. You need about 8 pieces in total as far as I can tell so you should be more then fine with 30cm.
Technically, the US uses a system called US customary units. Although similar to imperial units, the two systems are not 100% identical. I only know this because I am a science writer and have to be careful regarding naming conventions and such. 😜
But yeah, we all knew what you meant. 😉
I appreciate the clarification and what ever it's called the United States need to not try and always be different lol.
Interestingly, our products use metric (SI) almost exclusively.
It truly is a good system I try to use it when ever I can. Especially with dealing with the small details metric measurements work so much better than 1/16 and 1/32 inches
When I only knew a little bit about the imperial system, I knew it was based on 12 for conversions and things, which I could respect, because 12 is objectively a better number than 10 when you want to divide things. But then as I was working on my first kit, the bounty’s launch from model shipways (American), I was exposed to that darker side of the imperial system. Does 1/16th or 3/32 of an inch mean anything to anyone?
It means the super fricken small lines on a ruler and it's such a pain to measure with them. Makes me want to pull my hair out one piece at a time.
Okay, so here is where the varnish started to go a bit wrong. The thing that really got me to make the change was the appearance of blue-green spots in the varnish seen here.
The varnish had been gradually turning darker and greener over time and I think it is because to wood varnish did not properly seal the copper. As a result, the copper was able to oxidise and cause colour spots in the varnish. I suppose anyone could have told me that sealing copper with wood varnish was a bad idea, but some mistakes we just end up making anyway.
The second major thing was the flaking and bubbling of the varnish. I used a pretty thick coat and because the varnish did not stick to the copper very well, it was easy to form bubbles. These bubbles could break off and leave dips in the finish.
From attempt 1 at the rudder, note the damaged spot just above the middle gudgeon and below the top gudgeon. I tried to cover these in more varnish, but that often made things worse and led to more bubbles.
These factors led me to conclude that the only solution was to strip the varnish from the copper and seal it with a proper copper sealant. I don't know if this exact product is available overseas, but I'm sure there'd be something similar. I really wish I had found this earlier.
The stripping process was quite traumatic, and I was very reluctant to take photos. First, some of the patina was lost in the removal of the varnish, which meant some plates had to be replaced. Second, the varnish stripper was quite runny and caused some serious damage to the paint (it’s a paint and varnish stripper). The border between the white paint and the black wale had to be almost totally re-done.
The copper sealant was very glossy, but quick drying, meaning that many coats could be added quickly. I could tell that this was a much better adherent to the copper, and it was very difficult to cause the same flaking seen in the wood varnish. To remove the glossiness, I wiped a very light coat of the matte varnish over the copper. To do this, I just dipped a tissue in the varnish and gently wiped it over, avoiding thick build-ups or streaks. Here is the end result
While there are a few bumps, this is more a result of the copper laying not being perfect and sanding it smooth would involve losing patina. Anyway, I'm pretty happy with this and have learnt a lot for coppering hulls in the future. One technique that I think might be easier that I haven't tried, would be to press the plate lines into a long strip of copper tape without cutting through. These strips could then be used to cover the whole hull without using individual plates. This would be much quicker and might give a better effect. I haven't tried it, but might give it a go if and when I ever get to the Victory (got a few boats I'd like to do before that though).
Still looks pretty good
So now the deadeyes, OcCre has made the chainwales on this one very easy. The pieces come with the holes already laser cut, so all you need to do is glue on a strip next to the laser cut part and widen the holes.
I wanted to blacken the brass wire that goes around the deadeyes. I used my homemade blackening solution from my Bounty’s Launch build and left the brass pieces in for way too long. I think the solution has lost some of its strength, maybe as the ammonia has evaporated, so I might need to make up a new batch for when I blacken the chain. Anyway, the brass went all brittle and was practically unusable. Instead, I went to buy replacement wire, but couldn’t find brass in the same size so just used copper. The copper is a lot softer than the brass but worked well enough. They couldn’t be blackened as they had a protective coating, so I painted them instead.
The round nosed pliers came in really handy for bending the wire.
The deadeyes are a little out of scale, I think. From AOTS, they look a bit smaller, and I did measure them to confirm this. There are two reasons why I chose not to replace them. First, by the time I discovered this issue, I was so sick of re-doing things, especially with regards to the deadeyes. Second, there are two sizes of deadeyes in the kit, one for the mizzen shrouds and futtock shrouds and another for the main and foremast shrouds. It thought that if I were to keep up this ratio, the futtock and mizzen deadeyes would be too small. Anyway, I think it looks all right.
Then I started to nail on the deadeye straps, which are a really nicely cut piece in the kit. This was very fiddly at first, but I got into a rhythm.
There is an issue with the kit instructions regarding the chainwales as many who are building this kit have realised. The 5-deadeye chainwale for the mainmast is the wrong way around in the instructions, it should be flipped upside down compared to the instructions like this. I’m not sure how this mistake got through. I suspect, it’s because the kit is slightly different to the prototype on the box, which is different to AOTS. I think the parts were made according to AOTS, but when they made the instructions, they tried to copy the prototype, which has 2 straps next to the stairs, then a gap for the gunport and then the 3 straps.
Anyway, I was pretty happy with this, until I read a comment by @Keith Black describing how the straps should angle with the shrouds as they move further away from the mast. This makes sense now, I kind of ignored the angling shown in the picture in AOTS, as I didn’t really know why they had done it as it looked very random as they attempted to angle around the gunports. Once I started to angle them myself, I realised that they could all be made to angle properly without having to keep the ones close to the gunports straight.
First, I had to remove most of the nails and do some filling and painting to hide the mistakes. To get the angling right, I used a dowel for the masts and marked the height of the shrouds from the plans. Then I tied some thread at this height and inserted the dowel into the mast step. Then the thread could be used to mark the angle for the straps. So, this is what it looks like now…
I guess now we wait until the shrouds go on to know whether the angling is actually right
And with that, the hull was complete. This log is now up to date and any posts from now are happening in real time. I'm having some fun (and some frustration) with the deck furniture at the moment. Still putting off those hammocks...
Now onto the fun stuff. First up were the flag lockers. I have no idea why the lid on the kit version of these lockers was so comically oversized, so I made it mostly from scratch. I also used some of the gunport hinges that I didn’t use on the aft-most ports to give them some proper hinges.
Then I chose to replace the brass ladders with wooden ones. This is something I committed myself to early in the build, but I didn’t quite comprehend how fiddly it would be. I used leftover 5 x 2 mm sapele from the Albatros (cut back to 3 x 2) and some 3 x 1 mm limewood for the rungs. The sapele did not hold the glue very well and it took a few tries, but I’m pretty happy with the result.
Edited by LucienL
After looking at the belaying pins, I decided that their heads were a bit too round and they looked a bit too crowded on the forecastle so I have ordered some new ones. Turns out I wasn’t okay with the plastic large deadeyes in the kit and also ordered some more of those. Fun times ahead, redoing the deadeyes for the third time.
During this waiting period, I took the time to make a few other tweaks that I’d been thinking about.
First, I gave the bow another go with diluted paint, which did turn out a bit better, I think it’ll be okay once the figurehead is on, but I might try and sand it back again. at some point
I went back to the gunports as well and added small bits of 0.5 mm wire to mimic the actual hinges and some chain links to mimic the loops that would hold the gunports open
And finally, after some measurements from anatomy of the ship, it seems like using 6 mm dowels for all of the masts may be a little unrealistic. I've ordered some larger 8 mm dowels for the main and fore masts and some extra 5 mm dowel for the mizzen mast. I've made some appropriate adjustments to the mast steps to accomodate this, but may need to do some filling for the mizzen mast, I'll see how I go, that's a little ways off
Hey everyone, sorry for the delay between posts. A bit slammed right now. I'm still working on re-doing a few things. I did get to the wheel, which I made way more complicated than I needed to.
I ended up drilling holes into the the area behind the wheel and feeding the thread through there. it was very fiddly and probably not worth it, but I've done it now.
More recently, I went back to the copper to give it a proper finish. The matt effect from the wood varnish still wasn't quite right as it was so thin and couldn't be sanded without losing the patina. I decided to lay a lot of the copper protector over it to give a very thick coat that could be sanded.
Then I sanded it smooth and used a light dusting from far away of a matt spray sealant. This gave the desired effect and I am now pretty happy with it
The deadeyes and belaying pins have arrived so I will get onto that soon. I ended up going with 3 mm deadeyes for the mizzen masts and tops and 4 mm deadeyes for the main and fore masts. The belaying pins are small 9 mm brass pins that are actually shaped correctly and I will probably paint a beige colour to try to match the boxwood ones. I will need to cut a new fore pin rail however as the holes are way too big for the tiny belaying pins (they're only around 0.5 mm thick)
Your copper hull looks excellent! Very realistic effect in the end. Well worth the effort you have put in.
My next build will be the Amati HMS Pegasus which comes with copper plates for the hull. Though I probably won't go to the lengths you've gone to for realistic weathering. I will be leaning more towards the decorative look than the authentic look as it is a very decorative ship.
Thanks Techtonic! The Pegasus is a very nice ship that I'm sure you will do a great job with. The untarnished copper will look great on that one.
Okay, so went a bit dark there. I finally have a couple of weeks to give the boat some undivided attention. I was really struggling a bit to motivate myself to the deadeyes again, but I got through it. They are now wooden and appropriately sized.
I also finished the new belaying pins with the new pin rails. They are 9 mm brass pins painted a beige colour and I think they look right now. It seems like it is pretty difficult to get correctly scaled wooden belaying pins that won't be extremely fragile, so the painted brass ones will have to do.
And then onto new and exciting things. So first up is the poop side rails, which are extremely delicate and a bit tricky as the eyebolts provided are a little short and had to be reinforced with a lot of epoxy to make somewhat stable.
I also finished the azimuthal compass and the other poop details. I did print out a little compass rose to glue on the compass, but it was too small to print properly. I touched it up with a pen, but it looks okay, I think. I’m not going to add the stowage blocks yet as I’m not really sure how the whaleboats will be placed yet. I think once I’ve made those and get a better sense of the size, I can add them.
Anyway, working on the carronade and windlass now, good to be back.
