I'm considering upgrading my current butane torch to a Smith Little or Smith Little "knock off". I noticed this kit:
https://www.hampdon.com.au/uweld-micro-torch-kit-for-cutting-welding-brazing
I've went and had a look at the kit, the handpiece seems reasonable, but the tips seem low grade. Replacement tips are about $7 AUD each. Has anyone had experience with this kit?
Grant.
The little version on this would fit what were essentially hypodermic needles - all metal and not stainless steel as a tip for a micro flame.  I think the ones I have are ~12 G.
Would one of those push fit over one of your tips?  If that worked, it would get you more use from even a low grade tip.
We used 12 G to make up IV solutions in the sterile hood.  I am not sure - it has been a long time, but I think they were all metal.  Heat transfer might make using needles with a plastic hub an interesting experience.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Go with the tried and true Smith Little Torch.  Quality w/o questions of reliability.
Kurt Van Dahm
Director
NAUTICAL RESEARCH GUILD
www.thenrg.org
CLUBS
Midwest Model Shipwrights
North Shore Deadeyes
Butch O'Hare - IPMS
The cylinders shown are small but one doesn't need a gas leak of any size.  My little torch is set up on much larger tanks.  Tanks should always be turned off when finished.
Kurt Van Dahm
Director
www.thenrg.org
CLUBS
Butch O'Hare - IPMS
The torch pictured is a Chinese knock-off of a Smith's Little Torch. I have one and I'd say that it has proven adequate for several years of limited hobby use, but I had problems with it at the outset. The oxy hose leaked something terrible, but not so I noticed it. I thought I was getting half empty bottles from the hardware store before I followed the instructions (duh!) and tested every fitting junction and discovered the hose clamp wasn't making a tight connection. One mini-hose clamp later and I was good to go. There's a serious price difference between the real Smith's Little Torch and the knock-offs. (The AU price on the one pictured is astronomical! Shop around on the internet for the best prices. I got mine in the US from Harbor Freight mail order for about $60 US, as I recall.)
I didn't know I was buying a knock-off when I bought my torch, although I was suspicious because of the lower price. The knock-offs are practically indistinguishable from the real Smith's Little Torches. The difference in price has to do with the tips and sloppy assembly on the hose connections. The real Smith's torches have high quality tips that work better and last longer. At less than $150 for the disposable tank kit, I urge you to buy the real Smith's Little Torch instead of a cheap knock-off or out-and-out counterfeit. (The counterfeits even copy the Smith's instructions and box appearances, which call them Smith's torches.)  https://www.amazon.com/dp/B000T43L30?SubscriptionId=AKIAJA54JMESX73IGPXQ&ascsubtag=719191942-16-963305102.1626138622&linkCode=osi&psc=1&tag=d_2b_a_p-20&th=1
Research it further on YouTube. There' s a ton of very good videos on the subject of these "little torches." I consider one essential for fine silver soldering. They are widely accepted as the industry standard in the jewelry business. Just don't get suckered into buying a knock-off thinking you're getting a bargain. See: https://www.youtube.com/results?search_query=Smith+Little+Toroch
Edited by Bob Cleek
