Working on the bowsprit and deck works.  Screws are just dry fot for now.  Looking for a good paint to make them brass.  Struggling with getting started on the bowsprit shaping.  The instructions call for an overall length that seems short compared to pics.  Trying to figure out how to estimate proper length.  There also seem to be some errors on the deckworks.  The main cabin area shows two entries but the bluenose ii only has one.  Too late to adjust that.  They also have the actual barrels on the main deck, not the cabin deck.  The skylight is also on the main deck, not the smaller galley deck (which doesn't have a doorway access).  Looks like AL decided to cut some corners on these.  Maybe just kept designs from their original bluenose or another kit?  Adjusting where I can as I go.
Deckworks update.  Working on the windlass.  Haven't glued the axel yet as I'm thinking of adding a section between the right drum and the windlass housing to be a drum for the chain haul (to be more accurate?) In photos, looks like it's two drums, housing, main drum, housing, final drum.  AL left out the double drum setup on the port side
Skylights ate built and painted. Both cabins are read for finish.  At the helm, I added a short tub behind the helm so it would stand off the steering gear cabinet a bit.
I have two challenges now.  First, the poop deck from AL is a poor fit.  Try to decide if I should modify or rebuild from scratch.
I also made my first big goof.  When I started building the skylight panels, I grabbed the wrong wood. Grabbed some walnut of similar size instead of the sapely.  Oops.  Fortunately, I plan on painting the rails anyways so I can use any wood as long as it's the right size.
Just taking my time here. Making dories. Kept the white rails but I think I'll stick with wood finish on the hulls.  Also putting together the anchor davits?  Add an extra ring behind the pull to setup the chain hook and haul line.also added the yellow stripe on the bulwark same as the white.  Just cut thin strip of the decking,painted, and the glued on.  More crisp than I could probably paint on.im also model the windlass.  There is an extra section on the port side AL leaves out.  Took apart on of my daughters beads to make it.  Also adding some additional elements I can see in the bluenose picks like the breaker bar and a valve handle.
These chainplates really suck!  The AL design. Just doesn't work.  Makes me wish I had a soldering setup.  Maybe time to get one and learn.  Pictures don't show the issue well bit their design is just flawed.  Now to find a better approach!
I'm really disappointed with the quality of the metal pieces supplied in my Pen Duick kit by AL also. They are crude and often totally unrealistic looking. Hopefully, they are small enough that they won't be noticed that much but I see them sticking out like a sore thumb!
Bob Garcia
"Measure once, cuss twice!"
Current Builds:
Hms Brig-Sloop Flirt 1782 - Vanguard Models
Pen Duick - Artesania Latina 1:28
Completed: Medway Longboat 1742 - Syren Ship Model Co.
Yep, I'm tempted to just layer up CA or use modeling paste at the joint of the chainplate and strope so i can pain and hide how bad it looks.  Kind of doing the same with some of their other metal works the are inaccurate or just crude!
Continuing forward, chainplates don't look as bad once I build up a little ca and then paint them so going with that for now.  Working on the bowsprit too now.  I've crafted the wood rails that are just to either side of the top centerline with thin slots to put the tie down lines for the foresheet when it's stowed.  Modding the rigging connections to look more like the real thing too.
Finally getting pics in again.  Been working on deck fittings, adding pins to everything (nothing is glued to the deck yet). Added the railings.  Set the anchors and davits.  Been working through rigging planning to see where eyeballs are needed in the deck/rail.  Most recently, just set the bowsprit.
Created a bowsprit bail.  Working on masts, booms, and gaffs. Modifying various bands.  AL'S trestle trees are fairly inaccurate.  Augmenting where I can.  Goosneck on forecast is wrong kind too so moding with wire.
A little further.  Bands for halyard (I'm using polystyrene straps for bands because they are easier to just bend/glue and then paint).  But trestles are assembled now.
Realizing more that AL is consistently off in proportions.  The lower masts above the trestles are shorter than they should be but making it work.
5 hours ago, BobG said:
Very nice work on those masts, Travis.
Thanks Bob.  Now in need to figure out blocks.  With my mods I now need twice as many of each block type from what AL gave me.  Would like to fabricate my.own but will be very slow and the wood I have might not be dense enough.
I've used blocks from Syren Shipmodeling Co  before and they are excellent.
Bob Garcia
Current Builds:
With the masts nearly constructed, though I should document the mids, starting with the forecast.  Added a small round plate at the top ball of the mast that will be used for the flag halyard.  Replaced the master rings on the masts so I cloud have more.  Could only find a silver color which isn't ideal but all I had nearby.  Tried paint but didn't take well so just sticking with it.  Constructed a bail for the jib stay and jib sail and a second for the sprint stay.  Added additional band/block for each peak gaff halyard.  For the trestle, added the crane with attach for peak halyard, some brass works for both detail and realism, and bracket for fore throat halyard. Pinned the base of the upper mast (it's sitting free in the trestle, just the pins keep it in place.  This way i have a little flex in there when setting the stays).  Added the sheave in the lower mast that was used to hoist rigging when needed.  Couple Fairleads (small eyeball with a beading crimp tube through it).  Painted the metal mast wraps for the gaff wear.  Then replace the goosneck.
A lot of similar work on main mast.  Only one bail component at top of lower main mast.  Couple changes in brasswork at trestle.  And kept the standard rest for the goosneck.  Two metal wraps on the mast for both the gaff and the boom.
  • 2 years later...
Finally getting back to this after a very long break!  Picked up a serving machine from Syren.  Finally getting the chainplates installed.  I found the AL has a mistake in their design.  They have an extra chainplate that doesn't exist.  There are only 5 on each side of the main maste.  They included six in their design and the sixth one is actually ahead of the mast instead of behind.  Going to have to figure out removing one with ruining the bulwark but I'll figure it out.  Also getting the rigging started on the masts.
Focus right now on perfecting my eye splices and scratch built shackles.
Moving to futtock shrouds.  Al doesn't really even attempt these in a realistic way so back to scratch build!  I also found that every model I have seen and every practicum seems to show the foremast without a real futtock under the trestle.  Just eyelets to hold down the upper shrouds.  Photos of the bluenose show both mast with the futtocks so I'm going to make both.  Main mast is on.  Combo of shaped wire and brass rings.
Upper shrouds started.  I'll do the lanyards later when I have all the initial rigging set.  Couple more stays.
Moving to the booms.  Needed another ring for the boom tackle and added the staples for the lazy jack and Fairless.
Moved on the the boom tackle.  Ordered some blocks from syren and wanted to see how the smaller 1/8" blocks would look.  Man, those are painful to work with!  Finally gave in an used ca for the stropps to the blocks and then sized the stropps.  As painful as it was to work that small, I like this scale much better that what came in the kit.
Main boom tackle started.  Testing the fit.  The boom crutch ring always shows the blocks attached by small rings but I just could not get it to work the way I wanted.  Either the ring was too thin and would bend under tention or too thick for the scale.  Not to mention hard to work with in this area.  I decide to take an easy route and instead mock the rings by wrapping thread.  At this scale, can't really see a difference anyways
Further along after some travel.  Both gaffs rigged up.  Added temp lines to represent the sail tension since I haven't made sails yet.  Halyards are set temporarily too so I can quickly remove when it's time for sails.
Created chocks on the main gaff and the long strip on either side (for chaffing?)  This wasn't ok any plans/examples but is on the actual bluenose.  Also, all the plans out there show bands on the fore gaff for the single blocks of the peak halyard but looking at actual photos, these are supposed to be the rope bands with chocks too so added those as well.
Took a while contemplating making sails.  On my last build, I used the approach where a single thread was pulled from the cotton material at each seam which I do think looks better than sewing fake seams.  But this time I'm using muslin and the material is just too light/thin to pull threads.  So I experimented with various sewing approaches.  Landed with a light color thread and small stich length.  I also used a very light colored bolt rope (might not be very visible in picks).  I'm using rings for all the clews and an extra hand sewing thread at the rings to bind them there (like done on many actual sails.  Not sure on reefs yet.  Actual bluenose 2 doesn't have an extra "band" for the reefs.  The just sewed reinforcing at each reef point so still thinking there.
