Hi all,
the last half Frames are roughly shaped and dry fitted to the hull structure.
Next is to adjust and glue them before moving on to the transom parts.
I wish a happy Easter weekend to all of you!
Cheers,
Udo
Current builds:
Le Coureur 1776 - CAFmodel 1/48
VOC Retourship Batavia
Boston Typhoon steam trawler 1/32
Research/Side Projects/On Hold:
H.M. Bark Endeavour
HMS Bounty 1787
I have spend some spare time on the Bounty,
All the Frames are installed now, followed by the Transom wing.
I think it will be better to start fairing the hull before moving on to the transom parts to prevent damage as the parts are very fragile.
So, next is to copy the Body lines from the planes and prepare some templates for the sanding party.
Cheers,
Udo
Current builds:
H.M. Bark Endeavour
HMS Bounty 1787
Hello Udo.
This is one amazing build and you explanations are the making of a tutorial on how to make a fully framed a model ship. :)
You're got another follower and will look for updates.
Regards Antony.
Best advice ever given to me."If you don't know ..Just ask.
Completed Mayflower
Completed Fun build Tail boat Tailboat
Completed Build Chinese Junk Chinese Pirate Junk
Completed scratch built Korean Turtle ship 1/32 Turtle ship
Completed Santa Lucia Sicilian Cargo Boat 1/30 scale Santa Lucia
On hold. Bounty Occre 1/45
Completed HMS Victory by DeAgostini modelspace. DeAgostini Victory Cross Section
Completed H.M.S. Victory X section by Coral. HMS Victory cross section
Completed The Black Pearl fun build Black Queen
Completed A large scale Victory cross section 1/36 Victory Cross Section
Thank you Mike and Antony!
Unfortunately not much Progress to report, I'am still busy with sanding and fairing to prepare the hull for planking.
For me this is always the hardest part of modelship building, I don't like that at all.
But I guess everybody got his Favourites!!! ;)
Cheers,
Udo
Current builds:
H.M. Bark Endeavour
HMS Bounty 1787
  • 4 months later...
Hi Udo.
Any updates on this amazing build.
I am getting withdrawal symptoms :)
Regards Antony.
Completed Mayflower
Thank you for your Interest Antony!
Well, due to usual summer activities not much happend in the shipyard since the last update, but now the Bounty is back on the work bench.
I'am still busy with hull fairing and sanding, although the Frames were preshaped it is a lot left to sand.
A few Frames are undersized, don't know why, might be paper distortion from the copys or carelessness from my side. Anyway, got to fix those spots  with adding woodstrips and sanding.
Hopefully it will be done in a few days.....
Cheers,
Udo
Current builds:
H.M. Bark Endeavour
HMS Bounty 1787
  • 2 months later...
Hi all, waiting time is over, it continues...
Although hull fairing has not been completed yet I have started to fit the transom parts to have a break from sanding.
To complete the hull fairing  a few more "low" spots on the Frames require attention. I will cut some left over material from Frame building to be cut to the Frame width, run it trough the thickness sander for approx. thickness and sand it to the hull shape after glueing.
Edited by UdoK
Cheers,
Udo
Current builds:
H.M. Bark Endeavour
HMS Bounty 1787
very nice framing Udo,
its going to be a beautiful hull
Nils
Current builds
-Lightship Elbe 1
Completed
Thank you Nils.
Window framing completed and I made some good progress on the hull fairing last weekend.
Cheers,
Udo
Current builds:
H.M. Bark Endeavour
HMS Bounty 1787
  • 11 months later...
Almost one year since the last upate, time goes by but the build is still alive.
Hull fairing has been completed, all the low frames are filled and sanded again. I have installed one another transom wing and a Piece of wood to support the planking around the rudder opening. Now on to the wales.....
In the last Picture you can see some damge on the false keel caused by the 'heavy sanding equipment' during hull sanding. I will probably replace the after part of the false keel after planking is completed.
Edited by UdoK
Cheers,
Udo
Current builds:
H.M. Bark Endeavour
HMS Bounty 1787
Hi UdoK.
Nice to see you back on the build.
As always a Exelent build.
Regards Antony.
Completed Mayflower
  • 2 years later...
Hi all,
It's time to do something on the Bounty again.
The lower transom is planked with the supplied pear wood planks. In order to obtain the lateral bending of the planks, I made a template with the required radius of the planks, soaked the planks in water and allowed them to dry in the template.
Before the first belt of the wales had been cut and attached I made some plank clamps from a brass rod, threated rod M 3 and cherry wood.
Cheers,
Udo
Current builds:
H.M. Bark Endeavour
HMS Bounty 1787
Hello Udo.
I am excited to get such a nice update on the Bounty build.
Nice clamps.
Regards Antony.
Completed Mayflower
Thank you Antony,
my intention is to have the updates coming more often again.
Cheers,
Udo
Current builds:
H.M. Bark Endeavour
HMS Bounty 1787
