Figures 261-265: Folding chairs to be mounted on several locations on the wagon walls. They are designed to allow to move the seat up and down freely, though when you install them in the place you fix them in either closed or open position.
There are altogether 7 of them. Some parts need painting, some paper decoration.
Current :
HMS Sphinx by Vanguard
Completed:
Orient Express Sleeping Car by Amati
Bluenose II (Artesania Latina)
Istanbul Tram - Occre
Bluenose II - Artesania Latina
Bosphorus Sandal Fishing Boat
Riva Aquarama - Amati
Titanic - Mantua
Bosphorus Fishing Boat - Tersane Model
San Juan Nepomuceno - Artesania Latina
Bluenose - Billing Boats
BUILD DAY 26 / 1 hr / (TOTAL: 71 hrs)
Figures 266-271: Construction on both ends of the wagons. Note the doors I made earlier.
After this, the wagon structure will rest aside for a long time while the outer walls are being prepared. Lets see.
Thanks for watching!
Edited by aydingocer
Current :
Completed:
Titanic - Mantua
Thank you all for the nice and encouraging comments!
Current :
Completed:
Titanic - Mantua
i love this kit, and what you have done to her
All the best
Kevin
KEEP IT REAL!
On the build table
My other builds:
BUILD DAYS 27-28 / 5 hrs / (TOTAL: 76 hrs)
Next in the line is construction of corridor side outer wall. The wagon structure will rest aside for a while.
Figure 272: We start with photo etched the nickel panels, which will be glued on the plywood structure. In the photo you see how they came out of the box, even though they should be totally flat. When I press on them with my hand they bounce back to the same shape! I don't want to use tools to bend them as I am afraid of kinking them. I just hope they will remain flat enough when glued on the plywood. There will be also other components like wooden strips and another layer of photo etched panels to enforce the structure, so hopes are high.
Figures 273-276: Aligning the window openings of the nickel sheet with that of the plywood. Nickel should form a thin frame of about 1mm wide from the wooden window.
Current :
Completed:
Titanic - Mantua
Figures 277-278: 3x0,5mm lime strips around the window frames. This side will be the inner wall of the corridor side so let's see what kind of wall sturcure will come on top of them. Used the plan sheet for measurements.
Current :
Completed:
Titanic - Mantua
Figures 279-281: Glasses for the fixed windows, i.e. they don't open. They are the ones narrower than the others. Note also the wooden decorations which will be visible in the corridor side. Some trimming of the acetate was necessary here and there.
Current :
Completed:
Titanic - Mantua
Figure 282: Outer walls on the sheet. I put the part numbers on the back side before removing them so that I am not making any mistake during assembly. Some of them look quite same, yet they are not.
Current :
Completed:
Titanic - Mantua
Figures 283-287: Next sequence of photos show the progress of aligning the photo etched parts, painting and gluing using the order in the instruction manual, with one exception: According to the instructions, starting from the rightmost end, you should first glue the upper panel and then slide the lower panel towards under the extrusion of the upper panel (i.e. the lower panel goes around 1.5mm underneath the upper panel). This does not always work. I tried it and especially with super glue, it caused a lot of problems, such paint strip off etc. Instead I glued the lower panel first and upper panel after it and it worked just fine.
Color is Vallejo Steel Blue (see photo). I used airbrush.
Current :
Completed:
Titanic - Mantua
My hands are shaking 😄.  This is the first time I have ever done a sticker work at this level of precision.
Figures 288-291: These yellow lines are provided as elastic stickers, not decals (thanks God). They are in 1.5mm and 0.5mm thickness. From the back of the sheet I read it is a brand called Avery Dennison, in case anyone wants to find out more about them.
Overall it went wery well and I am kind of proud of the work :)
Current :
Completed:
Titanic - Mantua
Figures 293-295: Decals. There are decals at some white parts of the sheet as well. They are white texts to be applied on the black metal structure.
You use the printing as a guide for their location. Same goes for installation of the yellow lines. Note you can select the route among the available options.
This is all for now.
Current :
Completed:
Titanic - Mantua
27 minutes ago, yvesvidal said:
WOW!! It is coming along rather nicely. The blue color is spot on. Will you spray a coat of satin clear to lock everything?
Yves
Thanks! I don't know, maybe not. I applied the paint on a scrap piece and waited one day to dry. After that it felt good enough, no peeling etc when I rubbed it. It may just stay like this.
Current :
Completed:
Titanic - Mantua
very nice work with the painting, decaling and pin striping. Avery makes a lot of office supplies, one line of which is stick-on mailing labels. A reliable product line.
Ken
Started: MS Bounty Longboat,
BUILD DAY 29 / 2 hrs / (TOTAL: 78 hrs)
Logo, route nameplate, wagon number plate.
Figure 296: These are the smallest parts in this kit. They are the hooks for hanging the route nameplate. After removing them from their brass sheet you'll need to trim and file them so that they stay on the wagon smoothly.
Figures 297-298: In the two pictures below.
Left: Just removed from its sheet.
Right: trimmed and filed, ready to use.
Current :
Completed:
Titanic - Mantua
Figure 299: The hooks in place.
Current :
Completed:
Titanic - Mantua
Figure 300 : Alright! Now the logo is in place, together with the nameplate my train is officially The Orient Express!
:champagne-popping-smiley-emotic
Current :
Completed:
Titanic - Mantua
For the decals "Compagnie Internationale....", you may want to use Micro-Sol if you can procure that chemical:
http://www.microscale.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=MD&Product_Code=MI-2&Category_Code=FINPROD
It works beautifully to stick the decals next to the surface and to get rid of the micro air bubbles underneath.
Yves
Yves
Thanks for the tip! Will definitely check it!
Current :
Completed:
Titanic - Mantua
Yves
I think I found it on Amazon,
Does it help to brush it on my already applied decals, or is only good for future decal work?
Current :
Completed:
Titanic - Mantua
You can brush it on top of already placed decals. If the decals are still silvery, you can reapply and touch a pin tip into the decal to get the solution under the decal.
Ken
BUILD DAY 30 / 3 hrs / (TOTAL: 81 hrs)
Continuing with the compartment side of the carriage. The work is pretty much the same as the other side. This has more windows.
Figure 301: Nickel parts. They are also curved out of box. Now that I know they won't be visible, I use some force and hammer to flatten them enough.
Figure 302: Here they are flat.
Current :
Completed:
Titanic - Mantua
Figures 303-304: A 1.5mm gap is required from both ends for assembly. There is a bit less space than that  so I trimmed a little from the side. By the way I had to do this small adjustment for the corridor side carriage as well (i.e. the previous one).
Current :
Completed:
Titanic - Mantua
Figures 305-307: Gluing process. I used superglue. Note the window frame alignment with the plywood part on the third photo.
Current :
Completed:
Titanic - Mantua
Figures 308-311: The toilet windows have to have some degree of opacity. After all it is a toilet, right? In order to achieve this, the instructions recommend to spray matt varnish on them. I tried it on a scrap piece but the result was awful. Instead I rubbed them a few times with fine grade sandpaper. Turned out not too bad.
Current :
Completed:
Titanic - Mantua
Figures 312-313: Similar paint job as the other side. I stop here for today.
Current :
Completed:
Titanic - Mantua
Figure 314: My Fiskars have arrived. Excellent grip and mechanism for easy blade replacement.
One excuse less to blame the tools in case of a screw up 😀.
P.S. They also have great frying pans (Hard Face series), but I know it is a topic for a different hobby forum 😆.
Current :
Completed:
Titanic - Mantua
BUILD DAY 31 / 2 hrs / (TOTAL: 83 hrs)
Figure 315: Blue plates and pinstripes are in place.
Similar work as that of the corridor side carriage and no surprises hence I don't have many photos nor much to tell.
Pinstripe trims on an ice cream stick.
I have less than 10cm left of the 0.5mm stripes after the work. It was getting scary towards the end. Amati could have put one more line of cut on the sheet (which would not cost them anything). But anyways I survived.
Waiting for the Micro Sol decal setters from the mail before I apply the decals.
Current :
Completed:
Titanic - Mantua
