Hello!
Well after a fairly extended absence I am back. Just about finished my side project of a LED cube, so I have the work table back for ship building.
Time to start working on the yards and started off with the main yard. Cut a length of 5mm dowel plus some extra. To form the octagonal centre portion I cut 8 lengths of 0.5mm by 3mm walnut strip. Trimmed and shaped the strips with a bevel and then added to the dowel with CA.
Added detail at the ends of the yard with some styrene strip and brass wire. Still need to add the stunsail boom rings, and paint the yard. After that it is onto the fun of added foot rope and rigging.
Jim
Current builds:
HMS Snake
HMS Hood
Mechanical Solar System
Completed builds:
HMS Ballahoo
Glad you're back to it Jim, yards are looking good.  See you took the same approach with the boom irons, the supplied cast metal loop around the yard seem way out of scale.  The Amati PE fittings seem better than the CC solution.  I've decided I need to build a display case before I can get back to my Snake to avoid dust issues.  When will you get going onto Diana if that is next?
Cheers,
Jason
In the shipyard:
If you made such a cube, wel done, though, it would drive me completely nuts :wacko::blink:
Carl
Welcome back Jim.
Have you purchased any after market fittings for the yards (except the styrene strips) and what kind/type of them?
I shaped all my yards many days before but (as I remember) I was stuck with the way to fix/attach all those metal material to the yards.
Thank you.
Edited by Stergios
Time for another update.
Spent the last week putting together the finishing touches to the main yard.
Simulated the footropes by creating stirrups from a lengths of brass wire and a false seizing using guttermann thread. Finally added the footropes themselves using thread.
Served a length of thread and seized the ends together to create a loop for the sling. Also seized two jeer blocks to the yard, in addition to all of the other various blocks.
Finally, added the stunsail booms and tied them in place to the yard.
Jim
Current builds:
HMS Snake
HMS Hood
Completed builds:
HMS Ballahoo
Nice work Jim, did you 'turn' the yard on a makeshift lathe you were working on? Like the footropes, something to remember ...
Carl
I shaped my spars totally by eye and hand, I never felt the need to use a lathe or drill for that purpose although I did for the actual masts to ensure that the caps fitted accurately. Shaping the spars I found so easy and not a difficult job at all and not taking an excessive amount of time. I used a simple rule to makrk the tapers. A felt pen dot on the precut lengths, the dot being the finished diameter required. I used no knifes just a fine file and abrasive papers from coarse to fine. The octagonal sections were laminated with 0.5 to 1mm basewood strips up fron filed squares in the spar the taking of the corners to form an octagan. It really was that simple.
Norman
Edited by normanh
Norman
Current build Trumpeter Arizona 1:200 with White Ensign PE and a Nautilus Wooden Deck.
Built Caldercraft Convulsion, HM Brig Badger and HMS Snake.
Awaiting - Zvelda HMS Dreadnought planning to get the Pontos Deck and PE Upgrades, Panart 1:23 Gun deck model and couple of the cannon kits Manatu - French siege mortar, and American coastal cannon.
Jim,
You need to sacrifice something to get such a smart result ...
Carl
Greetings Jim,
Very nice work. May I suggest that the foot ropes don't look natural? Too tight and too perfectly shaped. Loosen them up and let them drape to form curves instead of sharp, precise angles.
wq3296
Been working on and off for most of the week but nothing really exciting to report.
Another lesson learned about looking at all the plans in advance. Started studying the running rigging plans and the second sheet has a series of blocks stropped to the masts for use with the spars. I have now installed all these extra blocks but been a pain in the butt with all the standing rigging in the way. Would have been nice if caldercraft included these blocks in the mast plans.
In addition to this the rigging plan for the boom includes a double block stropped to an eyebolt in the deck near the bulwark. Again, a touch irritating to install with the standing rigging in place.
Question for knowledgeable people:
What is the best order to rig? Boom and gaff first then the spars or vice versa? I don't want to create issues for myself further down the line.
Edited by jim_smits
Jim
Current builds:
HMS Snake
HMS Hood
Completed builds:
HMS Ballahoo
From memory when I rigged my Snake I started mast at a time working upwards and outwards. I found it worked for me pretty well as the last thing you want is to struggle inboard on the decks with everything else in place.
Norman
Norman
  • 2 months later...
Well, I am still beavering away at my build but I have been very slack in updating my log. In all probability is due to the fact I ant be bothered tidying away everything to take images but I shall endeavor to keep you all updated a bit better....!
Anyway. I have added spars to the mizzen and got a good deal of the running rigging in place. I have now moved onto the main mast and I have finished the main sail spar and currently working on the main topsail spar. Find this stage to be lots of mini projects and then putting it all together. Feel like you're not making progress and then suddenly it surges ahead.
Quick teaser image. Hope fully more updates to follow in the days ahead.....
Jim
Current builds:
HMS Snake
HMS Hood
Completed builds:
HMS Ballahoo
Nice Jim, if you add what you've done and what I've done, we'd both be done by now  :)  Seriously, looks great.  I've had a few detours, I've decided to redo the footropes on the fore yards which is a little tricky when doing it when the yards are on the ship.  I also decided to add ratlines to the topgallant shrouds, even though these are identified in the plan, I can find no logical sense why they wouldn't be there as the topgallant yards should have foot ropes and the chaps need to get to them somehow...
Cheers,
Jason
In the shipyard:
Jim,
Don't bother tto tidy up. It has it's charms(!!!) Looking good though
Carl
  • 1 year later...
Stergios,
Why don't you send a PM ... I know Jim to be rather preoccupied with some recent personal events
Carl
Stergios,
Hi Carl and thank you.
Jim has sent me his relative reply on time!!
Cheers
Edited by Stergios
  • 2 years later...
Well....
This post is over three years overdue! Two new jobs, one house purchase and move, wedding and an early first baby. Quiet really....
I am taking the late shift on feeds whilst my wife gets to bed early. So while baby Edward is napping I have two hours to kill each night.
Really struggling with space to build Hood until my workshop gets done so time to unpack the Snake build and get it finished off finally.
Tonight is is going to be spent re-sorting all my bits and pieces and trying to find all the wood, dowels, styrene strips and tools that have been packed up. Small shopping list needed also!
Kitchen table is dual role!
Edited by jim_smits
Jim
Current builds:
HMS Snake
HMS Hood
Completed builds:
HMS Ballahoo
all the best my friend, all the best
Edited by mort stoll
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
By now you must be multi tasking! Take care ... both of your son and your build ... and remember to have some fun
Edited by cog
Carl
Well, spent the evening trimming excess thread from several half finished bits of rigging and generally tidying up.
Then proceeded to pore over the rigging diagrams. After a three year hiatus it’s taking a while to get my head round them again!
Jim
Current builds:
HMS Snake
HMS Hood
Completed builds:
HMS Ballahoo
