Hi All,
The planking on the Lady Nelson is going about like I suspected… first build and all. I am using the “Chuck” method of bending (you should patent that 😄). Got the planks to lay down flat on the frames, but there is still a tiny step. I know sanding will take care of this. I’m guessing the tool is a “gimmick”? Anyone use it or tried it?
Dave
Current builds: Rattlesnake, Curtis P-40 Warhawk - 1/33 Card
Completed builds: Lady Nelson
On the shelf: NRG Half Hull Project, Various metal, plastic and paper models
Are you talking about this tool?  I have it but haven't used it yet.  I'd be interested in other's views, too.
BoilerDan1 Chamfering Tool Review.
Robert Chenoweth
In the research department:
Nothing at this time.
Looks like something that would be great but wionder if it actually works.Currently unavailable on Amazon.They are currently sold in the uk but for over £60 is a bit expensive for what it actually is. I will be also interested on peoples view so go post Dave
Completed     St Canute Billings            Dec 2020
Completed    HMS Bounty Amati          May 2021 Finished
Currently building HM Bark Endeavour
Dave,
The angle of the chamfer on every plank is dynamic but the tool has a fixed angle each time it is set so the angle will be wrong except for one small part of the plank edge if it used along the entire length of the plank.    The same issue applies to the angle of the rabbet.  A stiff back razor or any other hand held scraper blade can have the angle adjusted as you move along the plank when done by hand.   Sanding will probably work, but for me, scraping is easier to control.   The ROUGH sketch below explains it better (I hope).
Allan
3 hours ago, allanyed said:
Dave,
Allan
Hi Allan,
Thanks for the reply. So after bending , you fit and scrape each plank by hand for the “up close and flush” fit?
Dave
Total gimmick and totally unnecessary.  You’re guilty of overthinking it again.  You can simply sand the bevel onto the inside top edge of the plank. You don’t need to get overly detailed with this, especially if the plank is properly tapered and shaped
Regards,
Glenn
Current Build: HM Flirt
Sometimes scraping alone, done well, is the finishing 'sanding'. Don't scrape after sanding: small abrasive particles shed by the sandpaper and embedded in the wood surface will blunt your scraper.
I get this. This is why a full sized ship bandsaw has an adjustable bed that changes the angle of the cut as you pull/push a plank through it.
