Forgot to put in the title - 1/8th scale! First off, thank you everyone who helped when I was looking for info to draw up plans. I've decided that I've come to a point where I've got enough drawings to get on with it, actually I reached this point about ten days ago, but was somewhat reluctant to start a log till I felt reasonably confident that I would at least get a hull out of it!
Balsa infill - for lack of anything better available...
Sanding the naughty bit...always tricky getting the shape fair
OK, this is as far as I've gotten as of yesterday. Today I'm building a screen door from a kit....much less fun.
As always, constructive cricism, comments and suggestions gratefully received!
F
It is surprising how few waterline models are built.  Kudos to you!  Is the intent for a diorama or a shelf?
I really like clippers and will watch your build with interest.
Okay...some progress. The deck.
Cutting the waterways with their notches for the bulwark stanchions proved a tad challenging and tooks everal attempts...as is the whole build! For simplicity I laid whole planks, end to end. Now I need to spend a few minutes working out the buts... Not to mention some fettling still to do!
Thanks for looking, I'm going to pour a drink, been a long day!
F
Afternoon, all. Well, time marches on and inbetween trying to keep our trees from dying and other work I've managed to find time to start on the deck furnishings. Bowsprit bitts and the windlass, which MacGregor reckoned was the old handspike type. Took a few attempts, and I know it's not perfect, but it's about the best my skill level allows, this time.
I want to get all the deck furnishings on before I start in on the bulwark stanchions and bulwarks etc. as they'll be a bit fragile so it's probably best if the deckhouses and all are there first.
F
Nice work on the windlass.   I'd think about at least planking the hull before fixing anything to the deck since you'll have roll the ship around a bit for that.
Thanks, guys. Mark,the problem is that I'm going to plank the bulwarks which means the stanchions need to be in place which, being tiny, need the planking to stabilize them. Thinking about it, you may have a point: perhaps what would work would be to get all the holes in the planking cut/drilled and then plank. Then It would be just a matter of placing the cabin trunks and hatches etc. I'm very much feeling my way with this build. I'm also wondering whether she was built with a wheel or a tiller. MacGregor's reconstructed drawing shows a wheel which he bases on a slightly later and similar Schooner, Nonesuch, which did. In the Aberdeen museum there's a model of her built by one of her captains. Sadly the picture is tiny but I could swear he built the model with a tiller...I suppose she could have started with a tiller and had a wheel as an 'update'...dunno
F
Wow!  That image from Aberdeen is small!!  The  obvious answer is that it seems like a perfect excuse for a trip to Aberdeen! :)
Alternatively, you could write to the museum and ask them.
John
A trip to Scotland would be great...but.... I think I'll try and contact the museum today and see if I can beg a bigger Jpeg. Looks like he indicated coppering on the hull, too.
Fraser
I'm watching your build with great interest, Fraser.
Earlier this year, I finished my Scottish Maid and it's nice to see another one coming along.
Dan
Yes, it was from the Artesania Latina kit, but pretty heavily modified.
Hull construction followed the kit closely, but fitting, masting and rigging was almost all scratch built.  The rigging diagrams provided were pretty awful, so I made heavy use of Rigging Period Fore-And-Aft Craft by Lennarth Petersson to get the rig correct.  The diagrams for fitting out the masts and spars were qusetionable too.  I learned by experience to go with more reliable documentation -- like Petersson's book -- to save a lot of time, frustration and effort.
Dan
Got it! I know what you mean, back in about 1980 I bought their 'Harvey' - Baltimore Clippers are the dogs wossits - back then the bulkheads were hand cut...and quite a few didn't match the drawings with the kit. My Local shop (The Modellers Den in Bath) sent them back and they were replaced with a slightly more accurate set. The wood supplied for the deck was rubbish, so I forked out for a load of Lime planks. About this time I found a copy of 'The Model Ship Builder's Assistant' By Charles Davis....So everything from the bare hull onward was scratched. Deck houses, Tiller (found a bit of Holly to carve that and the Bowsprit out of - wish I could find some now!) masts and rigging. Coppered the hull...Kept redoing bits until they were as good as I could do. Converted it into a double tops'l job.  Sold it at Auction. Since then I've accumulated a reasonable reference library which includes Rigging Period Fore-And-Aft Craft, a most useful book! Back then I was living in a bed-sit and had a Dremel tool and a Dremel saw I picked up at the Model Engineers exhibition. Things are a bit better now.
F
It looks great!
:pirate41: you'll hit the target going this way foreward!
Thanks for sharing!
:10_1_10: Christian
P.S.: My gift to you - your new clock you wear when working in the shipyard...
Edited by Kronprinz
How lucky onshore whilom you have been
you will remake whensoever the ship is sinking.
Seneca
__________________________
Building:
HMS Wolf 1752, 1/48 snow-rigged Sloop 6pfd - 10 guns
Breton Thuna fishing boats 1/125 (plastic) & 1/50 (wood)
Reconstruction:
HMS Flying Fish 1806, 1/48 Baltimore Schooner 12 gun
Hi Fraser,
Should be a very nice model when finished,there were some very nice ships built in Aberdeen. The Thermopylae being the most famous. If you get no joy with a photo from the  Maritime Museum of their model do let me know. My son lives there so I could ask him if he would go and take some pix of her and email them to me,I could then pass them on to you. I would assume one is allowed to take photo´s there.
Regards,
Dave :dancetl6:
Dave: Thanks for theKind  offer. In fact I have had an initial reply from the museum to the effect that my request has been passed to the relevant department...so we'll see if anything happens!
Christian: ?? a joke? Or is this some sort of comment on what I'm doing?
Some several days work and the hull is planked...except for the stern which is proving to be a tad more complicated....Oh, and I should add, there's a need for a bit more finessing on the planking
Thanks for looking,
F
A bit of quick work with the sandpaper and she'll be the 'bee's knees', mate!
John
Fraser she is developing into a nice looking model.
Michael
I remember getting to this point too.  Drilling the hold for the rudder post had me scratching my head for a long time!
Ended up drilling one hole down from the deck and one hole up from the stern post and hoping they met in the middle.  (Worked like a charm, by the way.)
Your model's looking great!
Dan
Like always I'm late to the party but the build looks so good I think I'll stay around.
Bob
Current build:  SS_ Mariefred
Dan
Yup, been there done that...faith in the eye! On this one, being so small it was a straight up through job...concentrating hard on keeping straight!
Bob: hardly late! Really just getting rolling...lots of nightmares ahead!
Yes - don't look on the watch - the time you can't see on the clock is shown in the progress on/in/at our model - and no watch hand can take away the satisfaction from your model... It's great work you do. The run of the planks aft is well done!
I'm very interested to see the stempost and the opening to let the rudder come to the decks level to "cross" the tiller...
Greetings from the man with two clockfree rooms in the flat: bathroom and workshop
Seneca
Building:
Reconstruction:
Duuuh, never looked at the watch face! Too right. There is no clock in my 'studio/workshop' If I'm working in the afternoon the only time that matters is when it's time to take the dogs down to the field for a bit of play....and they tell me when it's that time!
I have the hole drilled for the rudderpost though I have yet to finish off both the stern post and the cutwater. I've been very hung up on how to do the stern decoration, which Artesania Latina, in their kit accomplish with a relief shape. I was looking at my Model Shipways 'Emma' which has a similar shape on her stern, but it's just a simple moulding and it occurs to me (ummm, at about 0400 this morning) that I could do something similar with the Maid...maybe in brass wire. Day off today; going to take the dogs over to the coast for a run on the beach and a change of scenery from our valley!
es stern decoration is a very important point - a tremendous eyecatcher for everybody including ourself...
To copy the stern's shape seems to be a good idea - why should we always try to reinvent the wheel a second time?
Then have a nice walk with the dogs... my four kitten only have got a finely adjusted "stomage-clock"
and geather completely to an orchester twice a day - allways on the tick at seven...
Christian
Seneca
Building:
Reconstruction:
Despite the lack of updates, work has been more or less constant. When you're daft enough to do a scratchbuild from a three-view drawing, there's a lot of work in finding out what the missing bits should look like, then you have to draw them up before youcan cut wood to make them. Also theres' a dearth of information about the smaller ships of the Nineteenth century and I'm really having to dig to find information. Then there's accidents, like the model falling off it's building jig and landing on it's vulnerable **** timbers...
That's now repaired and, I think, better for the rebuild...
Work continues under the watchful eye of Scraps, the Works Gremlin...
A lot of time went into figuring out the shapes of the rails and then cutting and fettling them and the combined channels/pinrails and I'm now in the process of fitting them.
I had been looking forward to visiting the Science Museum in London at Christmas, but just learned that the Shipping gallery has been put into storage! In the interests of making the museum a better interactive roadside attraction, I suppose. It was a blow when the NMM turned their 19th-20cg allery into the Henry the VIII show and now this. Damn!
F
