15 minutes ago, DocRob said:
I'm still undecided about the next build, it will be a spontaneous decision.
Well ignore me then, I detest the "Experts" the bolt and rivet counters that take all the fun out of exploring the subject... We build to our individual standards brother and it can't be any other way....
Whatever you decide to build I will enjoy looking in, If I can offer any help I'm here but remember, always build to your satisfaction... It's going to sit on your shelf not anyone else's....
Your bent winged bird is one of the best I've seen done in 50+ years of modeling.... Very pleasing to the eye and something to be proud of...
Quote:
Arizona would be a welcome build, in a pre December 7, fit. On some forums, the paint job (gray versus blue) fires up flame wars as to who is correct. I have no oar in the water on that. I just love a well documented build and finishing log. Your work, whatever the build, will do your subject proud. 😄
Ken
Started: MS Bounty Longboat,
3 hours ago, DocRob said:
Thank you, you should definitely build one David. Skill sets are only limited by not developing them and I'm often amazed, what is achiveable with a bit of planning and trying out.
I was using good Kabuki tape for masking in my opinion the best material, as it cuts very precise, it doesn't shrink and it adheres well, even in tight spots and corners. Most of the residues on the clear parts were from the inside, like caused by fumes and not through the color application directly.
I have to establish a better workflow, when using lacquer paints with their aggressive thinners. I never had these issues with acrylics, but the lacquers spray so well. I will dig into that with other builds and test, if a bath in Future may help.
Cheers Rob
Hi Rob. Yes, I'll build that 1/48 P47, just waiting on some paints, and eventually build the 1/35 F4U. As a note to my skill sets - it's not so much that I can't put any model together and have a decent result, it's that I have some vision problems that make it difficult and quite time consuming to do fine close up work even with corrective lens glasses.
I had not heard of Kubuki tapes so had to look them up. They seem to have a pretty good coverage though maybe not as much as 3m who seem to cover the entire spectrum of whatever needs to be taped.
Again, your F4u is a great build!!!!!!!
Dave W
I have followed your build and enjoyed it a lot. You got a very nice model with a distinctive weathering finish.
Congrats,
Dan
I will not ignore you Egilman, your input to my Corsair build was priceless and I'm very thankful for it. I only build for fun and living very remote, never attend competitions or shows. The only real competition is challenging myself with new techniques and hopefully succeed.
Thank you again for your warm reception of my bent wing bird, comments like yours are very motivating.
Cheers Rob
                             Duchess of Kingston - paused
                             USS Arizona 1/350 Eduard
23 hours ago, ChrisLBren said:
Simply amazing - one of the best aircraft models I've ever seen.  Congrats
Thank you Chris, with a bit more distance, I start to like the Corsair. I may even paint the pilot figure, a little challenge in it's own, at least for me.
In fact, I'm blushing a bit with so much praise, but the Corsair is an easy kit to shine with, as it nearly builds itself and I could fully concentrate on painting and weathering.
Cheers Rob
I have not even thought about starting this and there's the first controversy :D, but thank you for your confidence in my shaky abilities when it comes to ships in small scale, Ken.
Cheers Rob
I'm very sorry to hear about your vision problems Dave, but I also read the willingness to build in your post and that's what it's all about. Modelling is a hobby we do for fun and everybody contributes what he is able or willing to do.
I used a lot of different masking materials over the years, but Kabuki has become my go to solution. Tamiya Kabuki tapes and a little less refined, but cheaper is the Tesa professional tape are what I use mainly, along with pre cut masking sets from Eduard or in this case from HGW, which are made from Kabuki as well.
Cheers Rob
Congrats,
Thank you Dan, I always create a picture in my  mind, with a very detailed vision of what I'm planning to achieve with a build. Normally I get into a kind of building and painting groove than and follow my vision like painting by numbers :D. Except for the finishing touches, it worked with the Corsair.
Cheers Rob
... and a happy new year to you all and of course happy modeling :champagne:
Cheers Rob
