I frame out the gunport before applying the hull planking.  You can use a stick, cut to the correct dimensions, to act as a template to build the gunport around.
Toni
Member IPMS
                           Utrecht-1742
Wife asked me to put drain holes in a container she had dragged in to plant something in, used a 22 revolver to make the drain holes. After that she used her own revolver for such chores, might try that, shoot a hole in the bulwarks or side, run a jig saw blade through it, attach the blade to a saw, and have at it.  If done carefully, you can do both sides at once and save ammo.  :pirate41:
Edited by jud
Is the hull solid, plank on frame or plank on bulkhead?  Not unlike Jud's method, but for modelers without firearms, if all the planking is up, draw the location of the ports exactly where they should be.  Keep in mind that if multi-decked, the ports on the lower deck are larger than those on the next deck up and so on to the QD and FC.
Once the openings are marked, drill VERY SMALL holes just inside the line.  Then cut with a scalpel or a scalpel and keyhole saw (small ones for Xacto work well)  combination.  Use a plug the right size as suggested by Toni and file or use sanding sticks to open the port to the proper size.  Once done add the sills top and bottom and the linings on the bottom and sides.  There were USUALLY no stops on the top of the port but we have seen a couple contemporary models at RMG and I think Preble Hall that have them on all four surfaces.
Cheers
Allan
Edited by allanyed
An aspect of gunports that seems to be often missed:
The sides of the ports are parallel to the frames, not perpendicular to the LWL.
The sills and lintels are parallel to the deck at the port location.  In the middle there is little or no difference port to port.  At the ends, each port is individual in shape.
The ports are parallelograms with vertical sides.  A stick used as a gauge for every port on a particular deck produces an inauthentic result.
The gun truck or skid sits on the deck.  The barrel tracks parallel to the deck.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
Cheers
Allan
it is a plank on bulkhead.
  • Solution
Theory here:
It is difficult to get an acceptable finish on a gunport by cutting it and finishing the sides of the cut.
It may be a successful procedure to make the opening oversize and inserting a frame of a sill and lintel and having a veneer layer where the frame timbers would be.
If you are set on all rectangular openings, the same jig can be used for every port on a particular deck to glue up the framing.  It is then a matter of shimming each frame.  If the frames are mounted before placing the outside planking, .....
NRG member 50 years
Current:
NMS
Other
 I cut squares matching the port dimensions from blue tape and applied them to where I wanted the port openings to be. I then used an Exacto knife with a chisel blade (see photo) and small hammer to cut out around the tape. It's a slow process and it required a good quantity of blades but it worked. Always practice on a scrap piece of wood first.
