4 hours ago, Capella said:
Thanks. I'll check it out.
While organizing the planks and dowels, I used a digital caliper and noticed differences in widths varying by as much as a millimeter.
So, @Patrick B I scrolled through your log and
found this comment by @RobTBay
which got me thinking: Does the species of the wood REALLY matter in the end?? I mean, from MY limited and inexperienced point view, isn't it ultimately just the dimensions and color of the wood in question that really matters?
Having said that, I know from personal experience that the hardness of the wood matters to some extent. Case in point: while I was sorting out all of the Beagle kit's planks and dowels, one very light-colored and seemingly "loose fibered" (best way I can describe it) piece of 2mm x 2mm very easily broke while I was handling it.
So I suppose different types of wood have properties that make them best-suited for different applications in the context of wood model ship building, but do we, as the assemblers of the kits, need to know that detail?
I say to the kit manufacturers, "Just accurately describe and indicate in both the plans AND the parts what goes where."
First build: US Ranger - Corel
Second build: HMS Beagle - OcCre
Hope I didn't open a can of worms here by introducing wood species! Let's try to pack a few of those worms back in the can. 🙂
Short answer ...no it shouldn't matter, at very least not in this case.
Long answer ...yes, different species of wood have different properties. If you ask on this forum what is the best species to use to make a model ship (or for a specific task), I'm sure there might be a healthy "debate", or probably at least some strong opinions. I only introduced the topic of wood species to point out that the parts list in this kit seems to refer to the same material in one line as "sycamore" and another line in the parts list as "lime wood". It appears to be a reference to all the same material in the kit. Use the light colored thin 0.6 (0.5?) mm x 5 (4?) mm stuff for the deck boards (A20 and B11), bulkhead boards (B7) inside lining of the bulwarks (C3), gunport interior lining (H7), etc. In most instances in the parts list it is called "sycamore" and in only one instance it is called "lime wood". I think the lime wood reference in this case (B7) is a typo. What the actual species is, is not really significant to building this model.
IMHO
Rob
Love the conversations going on here! Thanks everyone for your input and continued encouragement, support and advice!
So I'm nearly finished with the planking the deck:
(God, I wish I could figure out how to orient my photos in here on my phone, which is where I do most of my posts - sorry for the portrait alignment)
Anyway, as I was planking the deck, I realized that some of the notches cut out in the deck do not need to be cut out, so I marked those on the underside of the deck:
As you can see I decided to mark which notches to cut out and which not to.
Some advice for future Beagle builds...
Sorry, guys I got those last two images switched around! Dang technology - and I'm a database programmer!! 🙄
Edited by Capella
Looks good.  Glad to see you went with the individual planks instead of the pencil lines.   Have you been watching the YouTube videos from Occre?  I found them quite helpful on my build, and probably relied on them more than the instructions.
No, actually, I haven't watched them yet. Although I'm pretty early in my build. But I'm sure as I progress, I'll have questions about how to do something, etc, and I'm sure the videos will come in handy then. I've heard good things about the videos.
Not sure what kind of glue you used on the deck, but Occre recommends using contact cement on deck, and the second layer of the hull.  I don't think contact cement has a lot of fans on this forum, but I had really good luck with it.  I had never used it before and the videos do a good job of demonstrating how to use it.  I definately think you should consider it for the second layer of the hull.  I have some photos of me using it on the deck of my Frigate Diana build log if you want to check it out.
I've just been using the PVA glue that I included in a picture I posted earlier in this log.
Thanks for the tip, Ross.
I'll look into it.
Edited by Capella
Couple of brief updates on my progress:
Planking is done and ready to trim the excess on the edges.
The underside of the deck, indicating what to trim and what not to.
Trimmed and in the process of sanding.
After sanding I'm going to fill the inevitable gaps with wood filler, line the planks and "nails" with a pencil, and then seal with the satin varnish that was included with OcCre's Beagle paint kit.
I have a trouble spot that I have a question about:
The little triangle of deck planking in the below pictures is only 2mm at its widest on the right and 12mm long. I'm having a heck of a time gluing a tiny plank piece there and getting it to stay.
I took a look at future steps in the plans and it looks like the after superstructure will cover it anyway, but I wanted to ask and make sure before I continue on... 20230112_225513.thumb.jpg.091ef0e904081673a57b7dd5c7ebfe1f.jpg
20230112_225513.thumb.jpg.091ef0e904081673a57b7dd5c7ebfe1f.jpg20230112_225526.thumb.jpg.55d000392fb47f8dc1fa56191ed5850d.jpg
Looking at page B of the plans, it looks like the aft superstructure does cover that part of the main deck, but I wanted to make sure...
Edited by Capella
I started outlining the deck planks and placing "nails" with pencil and I'm just not sure if I should continue with this method.
Take a look:
I don't have the steadiest hand and I'm just questioning if there's another method to do this or if I should just abandon the ouining of the planks and nails.
At this point it wouldn't be too difficult to remove what I've done with an eraser and some sanding.
Any suggestions would be greatly appreciated!
I personally think the natural lines created by your individual planks look great.  I wouldn't add with pencil.  I personally do not like penciled on treenails, but that is a personal preference.  I think if you sand and finish your deck without any pencil marks it will look great.  When your model is complete there will be very little empty deck space.  I don't think not having the treenails will be an issue then.
Hey capella, this is probably too late, but I found that shading the edges of the planks before fitting them helped.
Alternatively, you could go as you have and outline the planks. Then run over it with a razor blade (or even a broken piece of glass) to clean the planks and hopefully keep the grooves
Previous builds: HMS Bounty's Launch (Model Shipways), USS Albatros (OcCre)
Current build: HMS Beagle (OcCre)
Future builds: HMB Endeavour (Caldercraft), De Zeven Provinciën (Kolderstok), HMS Victory (Caldercraft/De Agostini/Artesania Latina/Corel)
So, here's what I ended up doing with the deck:
I'm happy with it. I lined the ends of the planks and pressed light dots for the nails and then sanded the deck to "mute" the dark color of the HB pencil I used.
Probably for my next project I'll look into the patterns actually used back then. I've seen lots of discussions about "5-4-3-2-1" (or some such) patterns discussed here about deck planking but I didn't want to get into such details for my second project.
So, for you Beagle builders, I've been working on the launch on page K. There's a launch on that same page in the lower right of the page that looks a lot like the launch in the rest of the instructions on that page. Its hull is painted white. Is that to indicate that the launch on that page (K) should be painted white?
I hope so, 'cause here's how mine turned out:
Pretty crappy-looking hull, if I do say so myself. A bunch of lessons learned building that one! The differences in coloration are mainly due to the fact that I used wood filler, which (obviously) didn't stain the same as the wood.
Edited by Capella
After going through the plans to try to determine if the launch on page "K" was supposed to be painted white, as is the launch on that same page, I decided to go ahead and paint its hull white.
So I moved on to the launches on page "L". The first one (L1 through L12) was a pretty simple to put together the keel and "bulkheads".
I left that one and moved on to the next one, L13 through L28, but I'm having a heck of a time figuring out which end of the keel is the front and which is the back. It looks completely symmetrical to me. I can tell that the "bulkheads" from fore to aft are slightly different, but I don't see any difference in the keel between the fore and aft.
Hi Capella,
You're right in that it's difficult to see the difference but maybe the photo below will help.
Your build is coming along great, keep up the good work :)
Chimp
Current Build: HMS Granado - Caldercraft
Previous Builds: HMS Beagle - OcCre,   HM Schooner Ballahoo - Caldercraft
Hi Chapel,
What size launch is this?  I notice you have the tholes set up with two for each of three thwarts, but no tholes for two of the thwarts so no possibility of rowers to use these thwarts which would likely never be the case.   Is this a kit instruction?  If it is single banked they would be alternating and more likely having six thwarts, but if double banked every thwart would have a pair, not just some of them.  Maybe consider scratch building a launch or other types of boats on your next adventure, it is not a difficult project.   There are several current launch builds in the scratch build forum  (1751-1800) as well as a dozens of contemporary drawings on the RMG Collections site and the Wiki Commons site that should help. There are scantlings available for everything from frames to risings as well, in a number of publications.
I realize this is only your second build, so baby steps.  😀  It is never easy but should always be fun!
Thank you for sharing your build with us!
Allan
Edited by allanyed
Hey, Allan
Thanks so much for the info and tips.
It is indeed a kit instruction:
I'm totally fine with going with what the kit says. Although historical accuracy is very important to many here, I just like the hobby for the enjoyment that I get out of the process of building them and the sense of accomplishment that I get while the model is being built and, of course, the final outcome.
I'm sure that eventually I'll graduate to the "dark side" - but only if I enjoy it! 😉
Finally: an update! - And a question....
So, here's the my "K" boat launch (for you non-Beagle builders, that's the first of four launches for the kit, with instructions for it on page "K"). I was very happy with the fact that it was to be painted white, as I really did a crappy job on the hull. 😉
The bottom launch I call "Little Guy" 20230125_212717.thumb.jpg.0580fc3e1f6a0e8168188ba5a4c66eb6.jpg
I'm in the process of working on launches B and C (my personal designations) on page L.
I started on B, but got a little too gung-ho on clamping it and broke a few of the "ribs", so I took a breath, glued those back into the (mostly) correct positions and started on launch C, which is pretty similar to B.
I finished the keel, ribs and planking on C. Pretty happy with how it came out:
However, when I moved on to the bottom of the launch I cut out the parts for the rudder and the part in the front that curves up from the keel to the top of the hull. I'm sorely lacking in my period-ship terminology (despite the fact that I served 5 years on a US Destroyer), so here's a picture of the part:
Here's the question that I mentioned at the beginning of my post: As you can see from these pics:
... that part doesn't fit against the hull very well at all. The two pics have the part flipped around, so it doesn't fit right in either direction.
The only thing that I can think of to do is to file the heck out of the hull and the keel part until the part fits.
Any suggestions other than my plan would be greatly appreciated!
Oh, and I have a beef about editing emoticons in this forum  on my phone: why can't I get rid of this emoticon?
I switched to my computer and left the above Mods, am I the only one with this issue? On my phone I was completely unable to delete that emoticon. I got on my computer and was able to select and delete it no problem.
Edited by Capella
Ah, that is annoying. I would also think cutting a new one would be a good idea. You could even bend some of the 2 x 2 mm sticks to fit it. Did this piece fit well with the false keel?
Unfortunately I didn't test the fit before planking.
I'll probably try to file the hull and piece to get it to fit, and if that doesn't work, I'll have to make my own. Plenty of scrap wood from the templates...
That's frustrating! Looking at pieces L54, L56 and L58 (the stem and stern pieces for the two similar boats), they are all very similar but each subtly different (and their orientation makes a difference as well) ...and then you have to adjust to fit the hull as constructed!
I've been keeping a list of things I would like to add or change on this build, but recently started another list of things to watch out for from issues encountered in other build logs. This one makes the second list for sure. 🙂 If it's any consolation, you're helping me! 😄
Rob
Rob
That is indeed a consolation. That's one of the biggest reasons why we do these logs. I've gotten some great help from the plethora of Beagle logs here, myself.
Edited by Capella
So, my delay in updating my progress was mainly due to waiting for a couple of things that I ordered to arrive: 1) The much-mentioned Vallejo Matte Varnish (side-note: Boris Vallejo is my absolute favorite artist - mainly for his fantasy art - I have two books of his - and had to wonder if the brand was named after him - slim chance, I know, but was wondering...) and 2) a small clamp-on vice to assist as a third hand in things like tying line/tackle on blocks, etc. That turned out to be a helpful purchase!
So in the mean time I worked on the four launches, mounted the main deck to the hull, and built up the supports for the fore and aft upper decks. Have a look below.
I was glad that the first launch's hull was to be painted white, as I did a horrible job on the hull on that one. I committed myself to using the process of building the launches as a learning and practice experience in preparation for planking the ship's hull (and paying attention to other details that will carry over to working on the rest of the ship).
I'm pretty happy with how the two longer launches' hulls turned out - a few minor issues, but it was a good learning/practice experience.
20230202_205735.thumb.jpg.5d1f212ea68e1adbaad4080bf3324189.jpg20230202_205740.thumb.jpg.3c62fed777ae924b395833d70c3a4a99.jpg20230202_205729.thumb.jpg.736e7a043fc3ba991f4d120732ca2b21.jpg20230202_205749.thumb.jpg.7a417f61c6d1da3f5ffc4f40f93170d1.jpg
Weekend's coming up, so I'm expecting to make some good progress!
Edited by Capella
20230202_205729.thumb.jpg.efdef01dbfc4bef877b63248a1cc2b67.jpgSo, my delay in posting another update was because I was waiting on a couple of orders: the much-mentioned Vallejo Matte Varnish for the decks and a small clamp-vise (for a third hand to aid in tying block and similar things).
In the mean time, while waiting for those, I finished the launches, mounted the main deck on the hull, and built up the supports for the forecastle and stern decks.
Okay, I got the windows and doors, and the upper fore and aft decks mounted:
20230206_201410.thumb.jpg.65e16091e227849cbfcf9270ea670627.jpgNext steps are to sand the false bulkheads near the upper decks in preparation for planking, bend and mount the gunwales (not sure if that's the proper name) and plank the gunwales.
A question regarding these steps:
Sorry. I can't seem to rotate the image on my phone.
Anyway there are nails provided with the kit. The pictured tool is a "pin pusher", right?
I looked for something similar on Amazon, but came up with a LOT of results - most of which weren't anything close to the tool in the image. Can someone suggest a good, cheap tool like that?
