North Carolina Oyster Sharpie by Paul Le Wol - 1/24 - from plans drawn by Thomas Pratt
Hi Colin, thank you very much for your comment and for the suggestions. Lots of interesting content there.
Regards……..Paul
Completed Builds   Glad Tidings Model Shipways. -   Nordland Boat. Billings Boats . -  HM Cutter Cheerful-1806  Syren Model Ship Company.
Link to comment
Share on other sites
On 7/19/2024 at 2:16 PM, JacquesCousteau said:
Very nicely done, such clean worksmanship!
What he said!  Beautiful work, Paul.
Gary
Completed Scratch Builds
Link to comment
Very fine craftsmanship, indeed! I'm a late comer to your build log but really enjoy your style of building. A very pleasant combination of aesthetics, artform and skill!
Current Build;
 1776 Gunboat Philadelphia, Navy-Board Style, Scratch Build 1:24 Scale
On the Drawing Board;
1777 Continental Frigate 'Hancock', Scratch Build, Admiralty/Pseudo Hahn Style, "In work, active in CAD design stage!"
In dry dock;
Scratch Build of USS Constitution... on hold until further notice, if any.
Constructro 'Cutty Sark' ... Hull completed, awaiting historically accurate modifications to the deck, deck houses, etc., "Gathering Dust!"
Corel HMS Victory Cross Section kit "BASH"... being neglected!
Link to comment
Hi Everyone, thanks to all of you for the generous support. While working on the cap rails and painting the hull I was also working on the cabin. It is just about complete so this update will be about that process. There’s a lot of angles and curves to the cabin. The four sides were made from 1/16” x 1/4” AYC
and after a lot of trimming, tweaking and dry fitting they were ready for gluing together. The window frames are made from boxwood strips. A 1/32” x 1/32” strip is glued to the back of the 1/32” x 1/16” strip to create a channel.
 I found it easier to glue them together while sitting in place.
After the glue was dry the cabin was removed. A beam was added to support the 3/64”  x 3/16” roof planks and then a coat of clear shellac was applied
Sliding wood panels were used in the window frames instead of glass. My story is that some of the builders of these boats couldn’t afford glass.
A few coats of paint later is when I noticed that I had forgotten the drainage holes in the sliders. Splash boards were used instead of doors because the cockpit is not that big.
Now it’s back to painting the hull. Hope to see you soon!
Regards……..Paul
Link to comment
It looks nice Paul but did you have a reason why (apart from the cash strapped fisherman tall story).
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Hi Keith, I’ve come across photos of a few oyster boats ( not sharpies) that have sliding wood panels as opposed to glass windows so I thought that it wouldn’t be too far of a reach for a sharpie to be equipped in a similar manner. The subject kind of reminded me of a book I had read a long time ago. I think it was a Louis L’Amour western where he was talking about buildings in the old west not having glass windows because it was expensive and difficult to get. I always enjoyed his books. Might have to pick another one up someday 😀
Regards……..Paul
Link to comment
Excellent reasoning Paul. It now all makes complete sense. I don't know if they had toughened glass readily available in North Carolina in that era but if they didn't that would also support a wood solution.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Isn't the internet clever:-
Toughened glass was invented in 1874 by Francois Barthelemy Alfred Royer de la Bastie. Wire mesh glass was invented in 1892 by Frank Shuman
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Nice work on the cabin, Paul.  I was wondering how you like working with the Alaskan cedar?  Never tried it myself, but something a little harder than basswood would be nice.
Gary
Link to comment
Gary
Thanks Gary, the Alaskan Cedar is very nice to work with. It will sand to as smooth a finish as you want and it holds a clean edge. Very nice for making small parts and it takes heat bending without breaking as long as you take it slow. All in all I like it a lot. Joe at Modeler’s Sawmill is very good to deal with._
Regards……..Paul
Link to comment
2 hours ago, Jim Lad said:
Just catching up after being away on holiday, Paul. She's coming along beautifully.
John
Thank you very much John. I hope that you had a great holiday!
Regards……..Paul
Link to comment
Hi Everyone, many thanks for all of the Comments and Likes. About a month ago I started working on the cap rails and in that time they were completed and the hull painted. Between coats of paint the deck furnishings were being worked on. A piece of wood 3/16” x 5/16” was pinned to the deck as a placeholder for the bowsprit. The bulwarks were finished to the bowsprit and then the cap rails were made. The cap rail around the stern was cut from a sheet of AYC and assembled in the same manner as the covering board.
 I decided to use a strip of wood at the bow instead of cutting the cap rail from a sheet. It was a bit of a battle to get enough bend. Should have used a more rounded piece of wood for the jig. You can see a bit of a kink in the rail but the strip was wide enough that it could be sanded out.
This is where the painting started. First a coat of clear shellac and then around 6 coats of thinned paint. The posts that support the dredge roller were added halfway through the painting because the cap rail and the rub rail needed to be notched.
The white - grey was finished being applied and then a few days later the hull red was applied below the waterline. I had the wooden plaque laying around so the boat was mounted on it in order to scribe the waterline and to show how it will sit.
Next comes a bit of sanding and touch up work. Then on to the deck. Take care of yourselves!
Regards……..Paul
Link to comment
 Paul, that looks fantastic! Very very nicely done.
Current Builds:  1870's Sternwheeler, Lula
Completed: 1880s Floating Steam Donkey Pile Driver
Link to comment
The build quality continues to impress Paul. All looking very smart.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Thank you Keith, I really appreciate your comments.
Regards……..Paul
Link to comment
11 minutes ago, Jim Lad said:
She's looking very 'swish', Paul.
John
Thank you John, I think that’s the look I was going for. 😀
Regards……..Paul
Link to comment
Hi Everyone, thanks to all for your Comments and Likes. The past week was spent working on the cockpit. The floor was glued together and cut/sanded to size. Before gluing, the strips of AYC were sealed with WOP tinted with Vallejo Dark Slate Grey pigment . ( 1/2 tsp. / oz. ). The floor was then glued into place.
The cabin’s aft wall sits on top of the floor so this was glued in next.
The cabin wall material that was shaped a little while ago was taped back on to the mold and a piece 3/4” wide was cut from it and given a test fit.
The remainder of the wall material that was still taped to the mold was used to shape a strip of 1/32” x 1/16” boxwood that wood become the outer edge of the wall’s cap.
A jig was made to keep it honest while gluing.
A smaller mold was used to shape a strip of wood that would become the inside edge of the wall’s cap. This strip was then glued to the inside top edge of the wall.
The cap was sanded and thinned wood filler was applied to fill gaps in the lamination.
After some sanding and a few coats of paint the wall was given another test fit.
Next I’ll be heading to the bow to start the deck planking. Hope to see you there.
Regards……..Paul
Link to comment
Excellent job! I particularly like the coloration on the floor planking, the tinted wipe-on poly really effectively gives it a slightly weathered look.
Link to comment
Thanks @JacquesCousteau for your comment on the weathering. I was kind of debating about how far to take it. I think it will end up being semi-grunge.
13 minutes ago, druxey said:
I'm late to the scene: very nice neat work and bending job!
Thanks @druxey for your comment on the bending. I was thinking about the cockpit wall for the longest time wondering what the best process would be.
Regards……..Paul
Link to comment
Just like all your work, Paul - neat, clean and everything fits together perfectly.  Extremely fine modeling!
Gary
Link to comment
The use of the wooden cloths pegs made me smile. The build is coming along rather well.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Link to comment
Thanks Keith, I’m not sure where they make clothes pegs these days but they don’t seem to be very good anymore. 😢
Regards……..Paul
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
