First, the vacuformed sails will be discarded. also, the plastic decking will be replace with wood. I took some glued-up decking, and painted it wood, then wiped it off with thinner. SInce the main deck was a little wider than the wood, I had to butt splice 2 sheets together. A scrap strip of 1/32 basswood added strength to the joint.
When flipped over, you can't see the joinery.
Next step is to insert wooden blocks because I will be using pedestals, not the plastic cradle tht came with the kit.
First step is to rough up where the blocks will be with some 60 grit sandpaper.
Then some 5-minute epoxy to hold the blocks, which were tapered to fit the curve of the bottom.
Definitely go with the laser cut grates.
I have this kit and was wondering what to do with it.  Using the hull and scratching the rest sounds like fun.
I following your build with renewed interest.
Current Builds:  Revell 1:96 Thermopylae Restoration
                           Revell 1:96 Constitution COMPLETED
                           Aeropiccola HMS Endeavor IN ORDINARY
Planned Builds: Scientific Sea Witch
                            Marine Models USF Essex
  • 3 months later...
