On 7/6/2024 at 9:58 PM, Ras Ambrioso said:
Keith, I try to leave the brass shinny because it attracts the eye to the metal work. I enjoy working with brass specially the lathe work.
I think the metal work is taking over the modeler's work.... Just saying 🙂
Yves
Ives, I make these models for my own pleasure and to share it with friends. My fun is in the research and of the
planning. Then comes the challenge of the fabrication procedures and I am more a mechanic than a carpenter or a painter.
Ras
Current builds:
USS SAN PABLO-1920-1/64 scale-River Gunboat
Previous builds:
Stern Paddle Wheeler ZULU-1916-1/48 scale
Freccia Celeste-1927 350cc racing motorcycle-1:9 scale- Protar kit
Boeing B17F- 1/72 scale- Hasegawa kit
HMS Mimi-scale 1/24-Fast Motor Launch
Amapá 1907-1/64 scale-Brazilian Customs Cruiser
Scottish Motor Fifie. 1/32 scale. Amati kit
Patricia. Steam powered R/C launch. 1/12 scale. Krick Kit
African Queen. Steam powered  R/C launch. 1/24 scale. Billings kit
Emma C. Berry. Sailing fishing smack. 1/32 scale. Model Shipways kit.
The boiler deck completed. Continue work on engine piping.IMG_1755.thumb.JPG.57d1a4be0acb4c43c6dd0cc51a54917b.JPG
Thank you for your comments and likes.
Ras
Current builds:
Previous builds:
A little more progress. I worked on the stairs from the main deck to the boiler deck. I used a system that I learned from Kevin Kenny's building of the Naparima. The method uses the mini saw with a kerf that matches the material  for the steps, in this case, 1/32".
IMG_1831.thumb.JPG.46120669673106c358751473efa5fddd.JPGThen I used jig to insert the steps.
And this is the unfinished ladder.
The finished stair will have  handrails and a thinner profile.Then it will be painted
Ras
Current builds:
Previous builds:
Good progress Ras. Here is a variation on the method of making steps if you are interested.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Keith, I when to looked at your Germania and I have to congratulate on that model The hull is exquisite. Regarding the ladders, Ken Kenny's system uses a long piece for the sides of the ladder and then sets the miter gage to the stair angle. The blade is set to half the thickness of the side strip. One side is cut and the miter angle is reversed and a new see of steps is done. The strip is advanced just like for making a box joint. This is the video:
I have used this method several times and for the Amapá, I used card stock for the steps.  Using Wefalk advise ,I shellac the  card stock.  In this scale I used 1/32 thick strips.
I did some more work on the model as shown in the following photos.
The piping forward is completed and the stack painted dark grey as per the forum's advice. I wish I have done that for the boiler too.
The engine piping is complete.IMG_1847.thumb.JPG.fab92477245d8e301c6345e0a2615fed.JPG
I finally, my latest micro work: the anchor hawser pipes:
Thank you for your comments, advice and likes. I have learned so much watching you guy's work. Thanks.
Ras
Current builds:
Previous builds:
Very nice, indeed!
Current Build;
 1776 Gunboat Philadelphia, Navy-Board Style, Scratch Build 1:24 Scale
On the Drawing Board;
1777 Continental Frigate 'Hancock', Scratch Build, Admiralty/Pseudo Hahn Style, "In work, active in CAD design stage!"
In dry dock;
Scratch Build of USS Constitution... on hold until further notice, if any.
Constructro 'Cutty Sark' ... Hull completed, awaiting historically accurate modifications to the deck, deck houses, etc., "Gathering Dust!"
Corel HMS Victory Cross Section kit "BASH"... being neglected!
Ras - yes I had previously viewed that video. The main difference is that Mr Kenny's method has many more operational steps and hence more opportunities of errors to creep in. By attaching the side strips to a backing block at the correct angle and then setting the saw to half the depth of the side pieces both sides and be cut (identically) in one pass of the table saw. The only thing that then needs to be set for each cut is the moving the fence by the distance between the steps.
Nice clean bends on the pipework. Well done.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Keith, I see, your jig actually carries the two  sides at the same time on the same setting of the fence. Outstanding!
Your method is now in my list for future ladders. This why I enjoy this forum  so much.
Ras
Current builds:
Previous builds:
I may have missed something in Keith"s jig so, after a lot of thinking, I figured how to be able to cut the notches for the steps at the same time on both opposite sides.
Cutting the angled sides was a little troubling in my micro saw because of the extreme angle but I managed to do it using MicroMark's "taper jig". To change from right to left I disassembled the jig and turned it over. Pictures of the new ladder will follow soon.
BTW, the reason I was doing another ladder is because the first one (post #64)came out one step short when I tried it the model. Sorry, senior moment😪
Ras
Current builds:
Previous builds:
Raz - yes that works. I tend to be a bit frugal with my use of wood so I use an MDF block with the pre cut side planks held on it (at the correct angle) with double sided tape. Once the step slots are cut I remove the side planks by brushing a bit of white spirit on to the MDF to break the bond.  Because the side planks are already the correct size I don't have to cut the shallow angles and therefore no need for a taper jig.
We all have senior moments, in fact mine are the dominant type of moment.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Keith, I did exactly the same process by setting the two opposing sides on the board with the double sided tape. But my tape was not that strong and it made a mess when trying to get it through the saw. By using a little more wood I managed to make the parallel cuts. Been very interesting to explore all these fabrication methods.
Edited by Ras Ambrioso
Ras
Current builds:
Previous builds:
Zulu is almost complete. It is time to start the last big item: the paddlewheels. I have looked through the forum at different methods to fabricate these wheels and the one I like most was the one used by Cathead in his Peerless. But, Zulu was a ship made in England, then disassembled and shipped to India where it was put together. And the plans show the wheels made with metal rims. Thus, I decided to use a method similar to one I used to assemble my Bianchi motorcycle spoke wheels.
The rims will be made from 1 mm styrene sheets and I will use some 1 mm brass square tubing. Following is the jig and the first rim before cutting it through.
To be continued.
Ras
Current builds:
Previous builds:
22 hours ago, wefalck said:
The parts for the wheel are photo-etched.
I have always thought it would be fun to make a large working model of a paddle wheel. I have often seen Waverley on my sailing trips around the Hebrides and watched her paddles with interest. Maybe after Cangarda is finished I will have a go.
Edited by KeithAug
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Wefalk, wow, those are paddles. But, unfortunately I am not at that level yet. Those wheels are absolutely perfect.
Keith, The plans I have been using are from an old issue of the Model Shipwright. If you look at the plans at the beginning of my post you will see that they were designed for R/C. It shows using an electric motor and a worm gear drive for the paddles. The plans could be enlarged to something like 1/35 or even larger 1/24. They would make a beautiful sight in the ponds. If you are interested, you could send me your address and I will mail a set to you.
Ras
Current builds:
Previous builds:
R
Ras - thank you for your kind offer. If I am not mistaken Zulu has the simpler non feathering type of paddle wheel. The ones that Eberhard posted were feathering paddle wheels. You probably know the difference but this video explains it well -
I was thinking about making the feathering type so unfortunately Zulu's plans don't help a lot, but thank you anyway.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
I knew about the feather wheels and that's why those wheels presented by Wefalk are so incredible perfect at a small scale. Just figure out how many minuscule pieces need to be fabricated. And all these by a guy 90 years old. BTW, I am 88 years old.
Ras
Current builds:
Previous builds:
A youngster then Ras. Many more modelling years left to add to your fleet.🙂
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Continuing the paddle construction. I cut out the space between inner and outer circle. But, trying to maintain concentricity between both circles I left four radial pieces uncut. The spokes and wood hub were then added.
Once that was completed , the holding webs were cutout and replaced withe rest of the spokes.
And following is a rough look how the paddle wheel will look.
What is shown above is a combination of port and starboard parts just for looks. The spokes on each side must be perfectly aligned in order to accept the paddle boards. I will be using the method that Cathead used in his Peerless build.
TO BE CONTINUED
Ras
Current builds:
Previous builds:
Good looking paddle wheel Ras.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Thank you guys. Your likes and comments keep me going
Ras
Current builds:
Previous builds:
Been reading through your log and have just caught up.  Wonderful work on this interesting vessel, Ras!  I admire your resourcefulness in both materials and construction technique.  Will be following along on your final steps.
Gary
Completed Scratch Builds
Work continues on the paddle wheels. Following is the first wheel assembled sans the paddles.
Ras
Current builds:
Previous builds:
Ras, was the original red or is that detail. Lost in the mists of time?
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
Keith, The only information I had on this ship was an article in Model Boats in April 1982. I have tried to get the other two issues to no avail. The drawings from Ray Vine indicated that the paddles were gloss red and the frame gloss green but I decided to follow the USA practice of having the whole paddle wheel in red.
Ras
Current builds:
Previous builds:
The paddle wheels are done and we are now working on the assembly.
One of the the main bearings
And the assembly presented to the sponsons.
Now working on the eccentric cranks and the pitman connecting rods. Then finally add the paddles or what I have seen elsewhere called: the buckets. In September it will be one year since I started this model. It has  been a wonderful experience and big lessons have been learned. Most important is to plan the order of the assembly to avoid interferences. In this model I added the railing way ahead of the bulk of the deck furnitures and now I am faced with having to redo it after damaging the fragile wires.
Ras
Current builds:
Previous builds:
Ras - It is funny what I miss in passing. I have only just realised Zulu has two paddle wheels. Are they on a common shaft or can they rotate independently?
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
My guess is that each wheel was independent which will be helpful in navigating the narrow Indian rivers. Making the wheels independent gets too complex to make in a static model. I opted to provide the wheels with independent hubs which makes them rotate independently but the eccentrics will be attached to the common shaft. This makes it easy in the static model. Furthermore, While building the hull, I fabricated the sponsons out of a solid piece of wood without taking in consideration the eccentric travel which required an open space below the deck surface. As I said before, poor planning. So now I have two wheels that will rotate independently from engines that will not be capable to complete a revolution. I plan to paint a dark space where the cranks are supposed to get below the deck surface. Again this is a static model going nowhere.😏
Ras
Current builds:
Previous builds:
Ras - I always think that I should build the same boat twice to correct all the mistakes in the first one. I never do of course.
Keith
Current Build:-
Previous Builds:-
Other Topics
Nautical Adventures
