The below drawing happens to be the Artois, but it is similar to many others.  Is there a name for the line marked below.  I have traced it in magenta on the profile plan to see if I could figure it out, but it does not seem to hold any significance.   I am sure it has significance as lines were not arbitrarily drawn on these plans so I am curious to know what it is about.  The deck line can be seen in red on the original plan so it is not the deck.
TIA
Allan
Line question AAA.PDF
Allan,
I am not an expert in this area, but I have encountered the same line on my Crocodile draft.  I have interpreted it as the top of the moulding that is even with the bottom of the midship rail. Once the moulding diverges from the rail at the waist it continues aft to the quarter galleries and forward to a point above the stem.  I'm not sure if that moulding is called the "drift rail?"
Adam
Given that there is not all of the interior drawn in red,  that the line shows no reference to the outside rails and mouldings, that it is all on the same level, and that it is at the correct distance above the gunports -  I believe  that it is the underside of the deck at the side.
NRG member 50 years
Current:
NMS
The U.S. Ex. Ex. 1838-1842
Other
BINGO!
I knew that....once. :(
Craig.
I do know, that I don't know, a whole lot more, than I do know.
Current Build: 1:16 Bounty Launch Scratch build.   1:16 Kitty -18 Foot Racing Sloop   1:50 Le Renard   HM Cutter Lapwing 1816  Lapwing Drawings
Completed....: 1:16 16' Cutter Scratch build.
Discussion....: Bounty Boats Facts
My first given was incorrect.  There are red lines.  I missed that.
Struck out!
Drift:
I can't think of any use that I would have for the shear line?
Edited by Jaager
NRG member 50 years
Current:
NMS
Other
6 hours ago, allanyed said:
I cannot believe how stupid of me not to just take the line all the way through to see such a basic thing by myself.
How do you think I feel? I worked this out months ago and then forgot :(
Craig.
