Looks like you're making great progress!
Off to a good start!  Following along on this build.
Robert Chenoweth
In the research department:
Nothing at this time.
I have the molds put together. Reading "The Dory Book" I found it interesting the early frames were not put together with gussets. One thing not described in the instructions but laid out in the details of "The Dory Book" is the removal of material from the frame at the angled joints to allow water to flow through. I plan to add these in after the glue sets up.
The evolution and design details of small boats shows a lot of opportunity to model even small boats more accurately. I have been leaning towards the smaller craft as I build my skill sets and research reading.
If I recall, Howard Chapelle's American Small Sailing Craft addressed a section on dories. (My library is packed and in temporary storage, so I can't verify that fact.) He discusses both versions of boats with and without sails.  A lot of small craft was 'customized' for specific roles and locales.
I find what you describe on the dory very interesting info on this construction. I'll have to take another read through my copy.
Robert Chenoweth
I'm finding it very interesting to learn about these crafts. The second half of the book is filled with plans for many different dories with many different applications. I'm approaching this model with the book in hand. Build the model, read the corresponding construction steps. So far the build process mimics the construction process pretty closely, and I and that fascinating.
They will be tiny, what's 1/24 of say 3/4 of an inch?
Craig.
I do know, that I don't know, a whole lot more, than I do know.
Current Build: 1:16 Bounty Launch Scratch build.   1:16 Kitty -18 Foot Racing Sloop   1:50 Le Renard   HM Cutter Lapwing 1816  Lapwing Drawings
Completed....: 1:16 16' Cutter Scratch build.
Discussion....: Bounty Boats Facts
Very cool to see research informing your build! That said, I was under the impression that the corners of the frames were already removed to represent this detail. They're slightly angled where the garboard would meet the bottom, which forms a small space in the corners. But maybe there's a difference in what The Dory Book shows?
That's what I found too. When I test fitted the bottom to the frame  saw that there was space for the water, so I left it alone.
I have the bottom fitted to the frames. I think I will leave the to set up overnight. I did notice that the transom was a little off centerline.  I soaked the transom and the aft section of the bottom and placed a clamp to see if it will straighten out overnight.
I have everything beveled (I hope) and the garboard planks soaked and fitted to the frames and bottom. Being my first project I'm finding this to be a little nerve racking as I don't know what to expect, but I'm taking faith in the instructions.
It is fun reading along in "The Dory Book" and reading about the use of spilling blocks and the geometry that goes into creating the garboard planks.
I was worried about the bevels as well. Especially because the planks are so thin, it is hard to make it look like the instructions. It really isn’t as big of an issue as it would seem. When you place the next strakes, if they don’t seem to lay right, you can fine tune the bevel
  - Eric
Good to know, thank you.
