I have started to build HMS Sussex 1693 from the plans by Gilbert McArdle, all the frames will be made from tulipwood.
These first two pictures show how I fitted a removable keel by fitting a piece of brass tube into the baseboard and a smaller piece of brass tube to the keel.
The tulipwood being planed for the keel
Milling the tulipwood for the forward frames
The frame templates are glued to the tulipwood, the glue I use is a non-toxic washable glue stick
Cutting out the frames
xebec 1:60 scale, scratch build
Sanding the forward frames
Milling the stem scarf
Forward frames fitted to the keel and deadwood
This is one of my main machines, an old 3 wheel, 104" INCA bandsaw.
mij
This looks to be an interesting build. I have the book by Gib McArdle and will be very interested to see the model built up from his plans.
Edited by gjdale
Very nice work in a larger scale.  I'm willing to spend a few years following your journey.
Are you fairing the insides of the frames as you go along, or will you wait till the exteriors are faired?
Dan
Hi Dan
Yes, I shall be fairing the frames on the inside as I go along. I like to have it looking neat as possible.
mij
Good work MJ!  I'll follow along.  I particularly want to see how you use your mill to make parts.
How big will she be when done?  Masted and rigged?  OK, I'll stop with the questions.
Wes Cook
Current Build: USF Constitution (Model Shipways)
USF Essex (Scratch build)
MS Syren (build log lost, need to rebuild)
Future Builds: MS Confederacy
The mill I`m using is a Proxxon mill/drill-complete system BFW40E, the model will be 47" long and will be built as a navy board model.
m i j
Here are some photos of HMS Sussex from the Authors book
This will be an interesting an challenging project for me, and I know I shall have the support from you when I neeed it.
mij
With out measuring the spindel sander, (as I`m at work) the top plate must be 12" square and the body 18" high.
If your building a framed model, it`s a must have.
mij
Impressive tool collection, mij.
I will add a few thoughts about the spindle sander. It is a very useful tool for sanding the insides of curves. I would recommend an oscillating type to avoid sanding the same spot on the drums and one with multiple drum diameters. A would also highly recommend some sort of dust collection on this and all power sanders. This can be as simple as a shop vacuum connected to the sander and run off a combined switch. Before dust collection my sanding spread dust from the basement throughout the house and I woke up most mornings with congestion - no more.
Before buying a spindle sander I used a drum fitted to a table top drill press. All the frames on Naiad were done with this arrangment.
Ed
Hi Ed
This an oscilating sander, and at the back at the base, there is an outlet for a vac.
But I don`t always use it, my work shop is an out side garage.
mij
Here are some of my tools I use for models.
Walker Turner drill presss, and Proxxon lathe
Proxxon mill/drill
Draper 16" fretsaw
mij
nice setup there Mij.  I hope Santa Claus brings me a mill this Christmas....  Do you like the Proxxon?  For the money they seem OK from what I've read.
Wes Cook
Yes they are great tools for model makers and if you look after them they will last a long time.
My latest gift to myself is a Proxxon OZI 220/E Multi tool (Delta sander) which I will use to fair the frames.
mij
After fitting 8 full foreward frames, I decided that I was not happy with my build, I built the frames oversize and I was to fair them inside and out as Gilbert McArole done on his build.
I used Titebond for all the gluing, so I put my build in a bucket of water to release the glue.
It came apart with the use of a pallet knife between the frames, I will have to re-cut 8 more floor timber, because I had to chisel them out of the deadwood (I did say to myself, mind your fingers, I`ve now got a plaster on my index finge on my left hand).
I will now fair the frames as I fit them, which is the way I mormally build my models and I am much happier with.
First picture of my re-build.
These are 2 of my new Proxxon toys
Hi Brian
It only came yesterday, but I used it on a piece of scrap wood and you can do a lot with it. I`ve got other pads and cutters to go with it.
mij
Can you tell us the model number of the one on the right in the photo please? I can't seem to spot it on the Proxxon site. Looks cool though! :)
Started to build up the frames.
The first picture is the full frame drawn on paper with the floor timber and the top timber tacked to the paper using Copydex.
This picture shows the 1st futtock glued to the floor timber and the top timber using Titebond and held in position with 1bl weights.
This picture shows the complete frame, slightly over size for fairing.
