I bought this kit ages ago for when I needed a palate cleanser. So I got an aftermarket set (which is designed for a SSNModellbou kits it appears ) then parked it and pretty much forgot about it. I did pull it out once as I thought I’d make it as a sci-fi flying boat but saw the forgotten aftermarket set in the box and re parked it.
Then I’ve been told again I’m presenting at our annual show so I asked online what people want and was told how to do seascapes. There are lots of I tube videos and about 7 ways of doing it but how to do it as a quick demo?
So I used my foam cutter and make a progression of seascapes which will culminate in a complete model on a base in a sea.
Now the kit! Not much to it. I built it in 20 minutes so I had a template to use.
Greg
On 7/27/2024 at 7:55 AM, RGL said:
as I said I built the entire kit in 20 minutes
I swear my very first thought when I saw what the subject was and its scale was that this kit might take you ten minutes to build. I wasn't far off the mark!
So step by step, foam base grooved with a wave.IMG_9126.thumb.jpeg.fbcb1be9b96cc5f3dc308960b7458624.jpeg
primer (I suggest you use an acrylic so it does not melt the foam)
DAS putty to make the waves then a simple black primer
blue for the ocean with lighter blue near the crests of waves
clear gloss coat over the top and some foam
Sea foam and spume and a clear resin coat
Greg
Hi Greg, I have been following along without commenting but have to now :)  That is a very nicely finished diorama, even if based on a small easy to assemble kit.  The overall finish is superb with all detail nicely shown.
cheers
Pat
