I've only built one kit, Yankee Hero, but I am ready to give it another try. I'm a rank beginner and an a little overwhelmed by the seeming complexity of the Mary Taylor. But I am going to take it one step (challenge) at a time. I'm not much of a woodworker - I'm better with solder and tiny electronic parts, but I started today (I bought this kit in July 2022 and this summer's trip to Searsport has gotten me fired up!).
Here goes. Today I inspected the kit parts, drew guideline and a temporary waterline on the hull, made the templates and put the hull in a vise.
Templates - Mary Taylor
Then I started sanding. Gosh, there was a lot of sawdust flying...
This is going to take some time!
Now it is time to lay the keel - a little adjustment here and there, lots of CVA on my fingers, and voila! Add a bit of wood filler and a wee bit of sanding......  When the filler dries, I will give it a light landing and contemplate my next steps. Next will come the decking and the bulwarks and the transom, which I can't get my head around.  Thanks to the others who have posted their patterns.
I am planning to copper the hull using the copper tape that I happened to buy when I bought the kit. It has an adhesive on the back. Can I rely on it to stick to the primed and painted hull?  Also, where can I find a pounce wheel that has closely spaced tics?
Edited by PhiipG
Add additional text and a picture
Never considered model ship building to be dangerous.
While cutting the rabbet in the hull for the port bulwark, the #17 blade slipped and cut my thumb. Lots of bleeding, some on the hull. I guess I could say I have a blood sister now.
Edited by PhiipG
With bandaged thumb, I soldiered on, and in my enthusiasm inadvertently put too much pressure on the keel, and the section between the screw holes for the pedestals broke off. Fortunately, that was the only damage, because my young dog, who is my assistant, picked up the broken piece, thinking it was a chew toy for her. I glued it back on and continued with my knife handiwork.
Cutting the groove for the rabbet has proved to be the biggest challenge so far.
Edited by PhiipG
I traced the rabbet, made a template, fit the template, cut the bulwarks from the plywood, and then adjusted them to fit the rabbet. I found that soaking the bulwarks and rough fitting them to the hull made it easier to adjust them to their final finished shape. A little more sanding here and there needed, but I'll get them fitting.
Edited by PhiipG
Transom fitted, bulwarks fitted.  I'll cut the the tops of the bulwarks and then begin cutting and pouncing the decking. I have only been able to find a pounce wheel that leaves 1/8 marks which are too widely spaced for the planking. I'll search in some more stores or else simulate the fastenings with a small awl.
Although I built the Yankee Hero, the Mary Taylor is a magnitude more difficult. I feel I am learning and the NEXT ship will be even better.  See you in a few weeks.
I pounced the deck and washed it  with a thin brown. Sadly, I didn't push the pounce wheel hard enough and the nail indentations aren't as defined as I would have liked. I don't think I can fix this. so I'll do better on the next build. Deck glued on and cockpit shaped with a dremel tool. Then I glued on the bulwarks. They still required a little fiddling. I used Elmer's glue and pinned and clamped them and the transom for 24 hours. Slight mismatches here and there, but I am learning. Fine sanding of hull. I'm going to be away for a couple of weeks, so the hull will be ready for priming and painting when I return.
Question: where do I find the paint scheme for this model?
Edited by PhiipG
  • 3 months later...
December 17, 2024 - I haven't been posting, but I have been working on the Mary Taylor, and in spite of a few mishaps and miscues, I am pleased with the progress. Since this is my first real model, I realize there are lots of things I could be doing better, and I realize I have made lots of slight mistakes that can't be fixed in this model, but I also realize that the NEXT model I won't make these mistakes, either.
Coppering the hull with 1/4 copper tape was not as difficult as I imagined. I used adhesive backed tape so did not add any CVA glue.
Still working topside with the top rail. Now I am starting to add the deck furniture and hardware. Couldn't resist putting the unfinished masts in place just to start to imagine the finished ship.
Edited by PhiipG
I have built and painted the deck furniture and I am placing on deck just to see how they look. When I  complete the cockpit cowling later today, and I will be ready to begin the rigging.
Already a couple of the lower deadeyes have taken  flight as I was binding them with wire. I will need to order replacements.
I have no idea how to build the masts and the booms. The instructions are not clear.
Is there a guide that will get me started on the rigging?
Edited by PhiipG
You are doing a great job - hard to believe it is your first model.
As far as rigging goes, the Mary T. Is about as simple as it can get. I recommend you search for other build logs for this kit and see how they tackled it.
The “Shop Notes” section on this site does have a section for rigging but there are over 60 pages of topics so it might take a while to find a particular topic.
Keep up the good work.
Tim
Current build:  Syren
Past builds:    Continental Navy Frigate ALFRED (build log & Gallery)
                        Steam Tug SEGUIN (build log in the kits 1850-1900 section)
                         Liberty Ship SS Stephen Hopkins (Gallery & Build Log)
                         Lobster boat RED BARON (Build log)
                         USS Basilone (DD-824) (Gallery & Build Log)
                         USS Olympia (Gallery)
                         USS Kirk (FF-1087) (Gallery & Build Log)
I have been working on a topsail schooner model, and in the process I have learned a lot about schooner rigging. Here is a link to where rigging the model starts.
https://modelshipworld.com/topic/19611-albatros-by-dr-pr-mantua-scale-148-revenue-cutter-kitbash-about-1815/?do=findComment&comment=1007247
I have also posted a thread about rigging and sails on topsail schooners:
https://modelshipworld.com/topic/25679-topsail-schooner-sail-plans-and-rigging/?do=findComment&comment=750865
There is a lot of information in the schooner rigging thread! A version of this is also included in the NRG Journal Winter 2024 - Vol. 69, No.4.
Phil
Current build: Vanguard Models 18 foot cutter
Current build: USS Cape MSI-2
Current build: Albatros topsail schooner
Thanks for the comments and the links on rigging a Schooner. The rigging itself doesn't seem complicated; I'm just lacking the technical skills needed to get it all looking good on a model. Might as well dive right in!
Here are a couple pictures of the ship, ready for rigging.....
IMG_2136.thumb.jpeg.f5bd47555b04c2cb65ba41bee34c9952.jpegIMG_2136.thumb.jpeg.f5bd47555b04c2cb65ba41bee34c9952.jpeg
Edited by PhiipG
Hello,
Could you please advise where you measured on the plan to get the dimension needed to establish the waterline? I have read a number of brief articles/comments telling you how to mark a waterline but haven't found any info on where you get the dimension. Just getting started on Mary Taylor. Thanks,
Bruce H
OK, rigging competed, as best I can do it. I had the most difficulty with the blocks and stropping them. But the ship is completed except for a little touch up paint and figuring out a way I can make the rope hanks that hang on the lines look natural.
I will order the materials for a glass case tomorrow as well as a brass plaque to identify this project. But for all intents and purposes, the Mary Taylor is read for her sea trials. Thanks so much for your thoughtful comments and encouragement. I've learned a bit, and I feel that with every block and line that I set, I gain a little more skill.
On 2/17/2025 at 5:15 PM, bruceh said:
Hello,
Bruce H
I estimated where the waterline ended at the bow and stern from the drawings and drew a line between those two points - getting the ship level and using a jig with a pencil attached to scroll it on the hull.
  • The title was changed to Mary Taylor 1850 Pilot Boat - FINISHED by phiipg - BlueJacket Kit
FINISHED!
I completed the rigging, did a pit of paint touch up, secured lines on deck. All that's left is putting it in the glass case. Time to start thinking about the next kit..... I welcome all suggestions for another kit, plus you comments on this completed one.
Happy sailing
Very elegant little pilot boat.  Well done!
Steve
San Diego Ship Modelers Guild
  • The title was changed to Mary Taylor 1850 by Phiipg - FINISHED - BlueJacket Shipcrafters - Pilot Boat
