The dhow seems to be quite the important boat historically, however I haven't found a whole lot of information about how dhows are constructed.  Most of the information about the dhow is about their importance to trade and the cultures that used them.  The range of the dhow extended from the Red Sea to the the Indian subcontinent.  According to Wikipedia, Dhows likely originated in India 1400 years ago, but are now more common in the Red Sea with most being built in Yemen.
A kit review can be found here.
As far and the build, the kit starts in a pretty standard way.  The false keel bulkheads seem to be very precise in their shape and cutting.  In previous builds I would remove the char from every edge.  That resulted in bulkheads that were loose and needed to be carefully aligned.  By not removing the char, the bulkheads fit quite well and everything was mostly square.  Two bulkheads, 2 and 8 needed a little adjustment to square up.
The stern bulkhead, number 13, is supposed to have two support pieces added.  As they are shaped, it appears that they should line up with the stern bulkhead's lower edge.  The problem with that is that they don't line up with the false keel.
I lined up the the support pieces so that the false deck will sit on them and beveled the edges so that they would be level.  The instructions in the next steps show that the supports will line up with the bulkhead after faring, so I will see how this lines up.  It seems like an excessive amount of wood to remove.
Stem supports were also added.
Basic deck pieces were added and nailed down.  The nails are necessary and useful because there is a slight concavity to the deck.
Once the false deck pieces are in place, the instructions call for gluing along every edge to secure everything in place.
The next step will be faring the hull after the glue dries.
Edited by SiriusVoyager
  - Eric
Time to fare the hull.  Frame 10 seemed to be a bit short so I bulked it up a bit with some pieces of scrap from the plywood sheets.
The shape of the bow is also a bit strange.  With the added structure, I'm not exactly sure how much to take off.  The bulked up part of the false keel doesn't line up with the forward bulkhead, so I will have to make a educated guess to get the right shape.
The false keel and "actual" keel aren't quite the same shape either, so I will need to be careful with the planking to make sure there aren't any gaps.  It is also tricky getting the shape of the false keel just right.
I took a couple days to check and recheck the faring.  I think I got it about as fared as I felt comfortable getting it to, without taking off too much wood.  I'll touch it up as needed as I add planks.
  - Eric
Hi - I see you've had a look at my build and will have noted a few of the problems I ran across with the build. To make the best of this you do need to dry fit and measure most items as I was never really happy with what was given on the plans. As for the padding out of the bulkheads I seem to remember at least two needed work otherwise the planking had a dip in it!!
Have fun and look at as many photos of actual working dhows as you can find, avoiding the tourist ones if you want something with realism.
Rick
Edited by Rick01
Rick
Rick, I have definitely taken note of some of the issues that you came across in your build and appreciate your documenting them.  I’ll be referencing your log as I go.
  - Eric
Just your standard first layer planking.  I am using a curling Iron to heat the strakes to bend and twist them.  It is working fairly well to get the strake to be the general shape of the hull.  This is also the first time I have used nails while planking.  I am not putting a nail into every bulkhead because it doesn't seem necessary where they fit and conform well.  I am putting a nail in where the strips need just a little help to conform to the shape of the hull, mostly in the stern.  At this point I will need to start shaping the strakes better to fit without huge gaps.  The last strake to go on was a bit tricky because of the amount of lateral bend needed.
The one area that is giving me grief is the bow.  After the first or second plank, the first bulkhead isn't in contact with the strakes. I could visually tell this would happen from the beginning.  The instructions don't really have any information on it and it is pretty obvious that it would be a very odd shape to force the strip to conform to the bulkhead.  I am contemplating wedging some scrap wood in there just for some structural support.  I have had to do that a little bit with second bulkhead.
The instructions don't mention beveling the false keel towards the front, but looking at how the keel attaches, it seems necessary.
  - Eric
Looking great, good luck on your journey  with this one.    :cheers:
                   WASA
                   USRC Harriet Lane
OK, this is the notorious first planking (I wonder, why kit manufacturers still go for it, while there are better methods to create a solid foundation for the 'real' planking. However, It may have been better to begin planking prototype-fashion from the garboard up. This give you a better feeling for the run of the planking in general and how it is supposed to rund against the keel and the stem. I would consider this for the 2nd round of planking.
It is also a good idea to have a look how the planking is/was done on the real thing. One of the places where traditional dhows were built until quite recently is Sur in Oman. Just 'google' with 'dhow sur oman' and lots of pictures and videos will pop up. You will have to search for images with a dhow under construction, as at completion the hull below the waterline was smeared with a concoction of quick-lime, coconut-oil and what not against the attack of Terredo navalis and you cannot see the run of the planking.
@wefalck  Thanks for the search suggestion.  There are some good photos of hull planking.  I will be starting at the garboard for the second layer planking and trying my best to make that look authentic since it will be the visible layer.
  - Eric
Eric, when I read the log name starting with Sultan lead me directly to the band Dire Straits and their song Sultans of Swing,
Just like the song your start of your Sultan looks good.
Does it have double planking?
Respectfully
Eric, I did a quick research on the Dhow and found this link for you.
History and Construction of the Dhow
I don't know if you got it before, hope it can be helpful.
Respectfully
Incidentally Norbert Weismann, who is one of those who intensively researched Arab vessels, particularly those of Oman, over the past 30 years just started publishing a series of articles on the Sanbuq (albeit in German):
WEISMANN, N. (2024): Der Sanbuq DHI'B.- Das Logbuch, 2-2024: 158-165.
Weismann discusses the origins and characteristics of Sanbuqs.
The kit seems to be based on a lithograph in PÂRIS's 'Souvenirs de la Marine', Plate 57 in the first volume, which in turn is based on a drawing by LeMasson of 1865 (preserved in the archives of the Musée de la Marine, Paris). This appears to be first detailed western drawing of a Sanbuq (spelling varies depending on the transcription into which western language). LeMasson was involved in the construction of the Suez Canal.
Edited by wefalck
Thank you for the link and compliment.  Fortunately for me the model does have double planking.  I should have some updates to the log very soon.  I happen to have the song Sultans of Swing loaded onto my phone twice.  I'm not sure why but as a result I tend to hear it fairly regularly.
  - Eric
The first layer planking is completed.  I was hoping that I wouldn't need to use any wood putty to fill in gaps, and I likely could have gotten away with not using any.  In the end, I decided to go ahead and use the putty just to make sure everything is nice and smooth.  I didn't expect so much filler to be left after sanding, but that is ok.  I will need to decide how I want to proceed next.  I want to stain the deck and would prefer to do that prior to the second layer hull planking to avoid any unintentional splashes of stain onto the hull.  However, the second layer planking probably adds structure that would help any breaking or deformation of the bulwark when trimming the bulkheads in step 8.  I may try removing one piece of bulkhead and see how the bulwark holds up.
The prow isn't quite straight but it will be under the keel/stem and will be hidden by the second layer planking.
  - Eric
I decided to trim the bulkheads to do the decking first.  This is to make staining easier and in case I accidentally damage the bulwark.  It will obviously be easier to repair damage to the first layer planking than the outer layer.  I think this was a good plan because there were a few small gashes in the planks, and some of the planks did need to be glued together because without the bulkheads, they were not being held in place.  I used some dilute white glue to get in between the planks, then wiped down the sides so that the outer layer can be properly glued.  As far as trimming down the bulkheads, it went easier than I expected.  A little IPA and some time with a blade and they came off the planks fairly easily.  The trickiest part was actually cutting the bulkhead extensions.  I couldn't get a straight cut and it took a bit of careful cutting to avoid damaging the planks. The next step will be to sand everything down to smooth it out and plank the second layer inboard of the bulwark.
  - Eric
I started placing the deck planks.  The instructions call for placing the inboard bulwark second layer planking prior to the deck.  I figured it would be easier to adjust the height the top of bulwark planks than to try and get an exact fit on the last deck planks along the edges. I started on the forecastle. I decided to offset every three planks and use the pencil caulking method.  The photo below shows how I estimated the angles on the plank edges.  It isn't exact because of the curve of the bulwark, so I cut it short and then sanded to fit.
The forecastle planked, trimmed and sanded.  I'm not sure where the small nick came from, but it will have a batten covering it.
I also started to plank the main deck, but first the small drop in the deck for the mast holes needed to be planked.
I carefully made every strip the perfect size and glued them in.  It looked great, but when I tried to very carefully drill the mast holes out, the soft thin wood fell apart.
I removed that strip of wood and will leave it as is for now and deal with it when the time comes to place the masts.IMG_3053Large.thumb.jpeg.e4d4530466a3be30fb5006908987b5ee.jpeg
Main deck partially planked.  I'm not sure why it looks like the planking is much narrower just aft of amidship. I am thinking either inconsistent strip width (could be me or the manufacturer, the wood is very fuzzy) or camera tricks. When I start the next row of planking I will replace that plank if needed.
  - Eric
Thanks for the reminder Rick. I did remember your log mentioning leaving a few of the parts out for proper fitting. Rereading your log, I won’t add any more pieces in that area until the masts go in.
  - Eric
Lots of time spent working, but only a small update.  The main deck is planked and the aft deck planking started.  I learned one lesson while planking.  When cutting the planks, I cut a bunch of 60mm planks to have them ready to go.  It turns out that the planks aren't quite the same width.  The better option would be to cut planks for one row from the same strip of wood.  This is to ensure an even width on each row.
  - Eric
Finished planking the deck (almost).  Apparently I forgot to take a photo of the competed and sanded deck.  I am a bit disappointed with out the planking came out.  Part of it is my own work, part of it is uneven strip width and cut, and part of it is how soft the wood is and how easily splinters peel off.
I decided to stain the deck using Varathane Ipswich pine stain.
Here is the stained forecastle compared to the unstained main deck.
The entire deck stained.  I think it looks much better with the stain.
It was shortly after this that I realized that I hadn't finished the deck.  The bulkhead between the main deck and the poop deck (would that be a poop deck on a dhow?) needs to be planked.
Deck planking is now finished.
Time to start planking the hull.  Keel, stem and sternpost installed.  I appreciate that AL kits attach the keel before the second layer planking so that small gaps between the planking and the keel parts can be covered.
  - Eric
I wouldn't worry too much about the looks, if you search working Dhows their decks don't even have nice neat planking more often than not and as for neat rope stowage - the idea never existed.
Fair bit of work as far as trim on the deck yet! 😉
Rick
The deck looks really nice, but if you pull your finger along the planks you will find how rough they are, this as the fibergrains has risen.
Now use aluminium wool as a sander and your deck will be smooth and getting a shine.
Respectfully
Actually, unless it were one of those modern tourist-dhows, it is unlikely that the deck of dhow ever shone. They were built rough and treated rough in their daily life.
Deck and planking of the real thing also would not be too regular, as wood in this part of the world is a precious good. These dhows were built from timber imported from India for important structural parts and cheaper and more crooked wood, such as Mango, was used for other parts. They had to make do with whatever lengths and widths was available.
I noticed that when first looking for working dhows, I just didn't feel competent to get a deck to look as rough as those I did find where deck and fittings were well photographed.
Rick
This is always the dilemma, when we are building 'realistic' (as opposed to 'artisanal') models: how to make it look rough without looking like shoddy workmanship. It can be quite instructive to have a look at what railway- and plastic-modellers do, though some tend to overdo the 'weathering' a bit.
5 hours ago, Rick01 said:
I wouldn't worry too much about the looks, if you search working Dhows their decks don't even have nice neat planking more often than not and as for neat rope stowage - the idea never existed…
Yeah, I know a lot of dhows can look pretty rough. I didn’t want to be the one making that excuse though!  I’m trying to improve my workmanship and it’s a slow process for me.
  - Eric
This is sort of my current dilemma. My workmanship isn’t at the point where I can build an intentionally tough looking model (though I easily can unintentionally). I will likely be going for the more artisanal look simply because it will be easier for my current skill level.
  - Eric
The second layer of planking is now completed. Being my second model that uses this style of two layer planking, I have mixed feelings about it.  It definitely allows a less experienced modeler an easy way to have a relatively nice looking hull as the it is easy to hide mistakes.  On the other hand, the wood is very brittle and difficult to bend and lay flat. Dhows don't use a rabbet with the planking so I used strips to essentially frame the edges.   Thanks to @Javelin for sending me some good photos for reference, the two below were helpful in seeing how the boats are planked.
I started framing the bulwarks and right off the bat I managed to create a gap that needed to be redone.  Not sure how I managed that one.
After replanking.
Once the bulwarks were done I started with the garboard and worked back up to the bulwarks
Second layer planking completed.  I tried to plank it based on actual construction photos but I was having a difficult time getting the sapele wood shaped in such a way.  .
The next step is to add the rub rails, of which I got the first of 4 in place.  There is a little lip on the front which didn't look bad when I was placing it, but it photos it looks like it isn't sitting properly, so I will sand it flush.
  - Eric
And no wonder, since the dhows are built from the outside.
Nice looking boat, I've built one myself some 5 years ago.
  • 4 months later...
That is a nice looking dhow.  Thanks for sharing.  Apologies for the late reply.  I haven't had a chance to do any modeling for a bit.
  - Eric
