To make progress on my Pram and Sherbourne, I needed a small miter box (to cut copper tube for the Pram, to cut masts for the Sherbourne). It came in but it turned out the narrow saw I had would not work with the miter box, so I had to order another saw. While I ordered the saw on Amazon and have Amazon Prime, it'll be another week or so before the saw arrives.
While waiting, I decided to start on the Lobster Smack, the third kit in the Model Shipwright Series.
Some notes and heads up on this one:
- I chose to keep the centerboard glued into place. A challenge of doing so is that the centerboard then becomes an easy thing to crack or break (it’s terribly thin basswood) and it gets in the way of banding and clamping pieces after gluing. I think there’s may a 50% chance it survives the build. It might end up being in what appears to be its raised position by its absence.
- This model has lots of thin basswood. That makes it easier to shape pieces (and some pieces have to be shaped quite a bit). But it also means it's pretty easy to sand through the planks when finishing the hull (I did not do that because I learned from my half hull build when I did it).
- Like other Shipwright Series models, do not assume any “to scale” drawings are actually to scale (I don’t know if other Model Shipways models have the same problem). I had to zoom to around 103% to get something close, at least when I had a point of reference. It’s frustrating for the price they charge these models that they don’t have better quality control. Drawings to scale should be to scale.
- I was completing the Pram and Smack before completing the Sherbourne because I wanted to get some practice on rigging before doing it on the Sherbourne. It's not necessarily that the Sherbourne is more challenging (in some way it's less challenging because the instructions and plans are so complete), but because I'd rather make a mistake on the Pram or Smack than the Sherbourne. One bit of frustration with the Smack (and Pram) compared to the Sherbourne is that the rigging instructions for the Smack are incomplete at best. I ended up having to turn to the instructions on the Pram to figure out how to rig the sails (they end up using a similar technique which is explained more completely for the Pram - so if you're just building the Smack, open up the instructions online on the Model Expo site for the Pram when you get to the rigging section). Unlike the Sherbourne, there are no rigging plans for the Smack. There is a sheet, but it's more to know how to shape the sails and part out the masts. There's maybe one drawing of a bit of the rigging (really more about passing line through some blocks), but that's it. When reading the instructions, I've learned that you need to keep track of the name of a particular line that might be tied off somewhere and named in one paragraph and then the description of where it goes might be explained several paragraphs later, just using the name of the line. Just follow the name of the line through the instructions to follow where the lines is supposed to go. I'm sure this is obvious for people with lots of experience working on boats or building models, but it's a little frustration when this is supposed to be an "instructional" model kit to have the instructions so confusing. I suppose compared to many model kits (not including Vanguard's) these are more complete than some models, so in a way if you can't get past these fairly complete incomplete instructions, maybe you won't do well on a non-instructional model kit with few instructions at all. I've seen some kits that seem to only have a bundle of material and a set of plans to follow.
- One thing to make note of is that the metal - I think it's called Britannia metal (which replaced lead in old models I believe) - is pretty soft and kind of lousy. The rigging line supplied with the kit and the holes in some of the metal parts the rigging needs to go through are not quite lined up with each other (the line is way thicker than the hole). As a result, I had to bore out some holes a bit to even hope to get the line through a part. Well that then structurally weakened the metal (way more so than I would have thought given how much thickness remained). And just when tightening a piece of rigging (just a tiny bit so it didn't sag) the metal failed. Be careful.
- For future builders: This kit does offer opportunities for kit bashing since some of the details are pretty basic (e.g., doors and hatches that are just square pieces of basswood with no detail at all). I thought for a second about trying to mimic some builds, but I bought the Shipwright Series just for some extra practice and I have other models in the queue I want to get to. Here’s one build that’s really nice with lots of added details someone might try to emulate:
https://modelshipworld.com/topic/37380-muscongus-bay-lobster-smack-by-desertanimal-finished-model-shipways-124-moderately-bashed
Edited by palmerit
You will enjoy this build!
Gregg
Current Projects:                                                             Completed Projects:        Waiting for Shipyard Clearance:
After clipping the spine overnight, it had a pronounced bend. I wetted down both sides (just bushed with water) and then placed a heavy book (wrapped in plastic wrap) on it. Tonight, when I removed the book, it was fairly flat and straight.
Edited by palmerit
I added the seats. The floor was tilted a bit because one of the bulkhead frames was tilted. I had to sand down the seat support piece on the one side so the seat pieces would lay flush. There ended up being a tiny gap between the seat pieces so I ended up putting some filler that I’ll sand in a bit.
I added the deck, faired the hull, and started to add the keel. I’m not entirely sure how much to fair the part near the stern. I’ll need to check the fit of the planks. I had to sand down some of the bulkheads quite a bit in a few places because they extended too far beyond the deck.
Edited by palmerit
Had some gaps with the third strake. It was either reshape the strake or install the strake and have gaps. Since I’ll be using filler, sanding, and painting, I decided to fill the gaps. We’ll see how it looks when I’m done filling, sanding, and painting. (One gap had to remain for the rudder.)
Edited by palmerit
Adding the toe rails around the top edge of the deck was a real challenge because there was nothing to clamp it to and because it was a thicker piece and was harder to shape. I had soaked it in hot water, shaped it, and let it set for a day, and it still wasn’t quite right; in retrospect, I probably should have soaked again, and let it shape for another day. I used rubber bands and some clips in the open sections and used a couple quick grips. I did use the titebond speed set so it would set up a bit more quickly. I still need to shape the ends of the toe rail.
Edited by palmerit
Shaping the coaming (around the seats) and shaping the cabin sides (they’re wet, not glued in yet). Needed to soak both in nearly-boiling water quite a while to get them to bend (and not fear that they’d snap) - the bend is pretty extreme. I’ll leave them to dry overnight. Getting the cabin sides to fit required a bit of carving to make sure there was a slot for the piece to fit in and it took a little bit of trimming (as in maybe 1/2mm in places) to get the slots to fit fully. There’s a little bit of the ends of the cabin sides that extend back to the coaming that I needed to trim (maybe a mm on each side). Better that it’s a tiny bit too long than too short obviously.
Edited by palmerit
Nice lines, sir.  Looking very sharp. 🏆
I bought one of those OptiVISOR magnifiers a few years back (maybe it was when I was working on my own lobster smack).  Had to send it back... it didn't fit my 7 7/8 noggin.  🤷‍♂️🤣
Edited by GGibson
Gregg
I shaped the mast using the drill and sandpaper method. The starting point is two pieces cut from a sheet and glued together. It took a lot of sanding to get it round. There was a tiny bit of residual char, but I was worried I’d repeat what happened with my Pram and oversanding with the predrilled holes might cause the mast to snap.
Yet again, there’s a mismatch between reality and the instructions unfortunately. The predrilled holes do not line up to anything shown on the plans. They’re not just slightly off, they’re off by a bunch. Frustrating.
Edited by palmerit
The instructions say to use “small seed beads” for the parrals.
Anyone have a suggestion for how to figure out what size of the beads to use for the parral? I’d measure from the plans, but they don’t show the beads, unfortunately.
I’m guessing I can just order some black beads (they don’t specifically need to be “seed beads”, whatever that is) but I need to have an idea what size to buy.
Edited by palmerit
Nice work Palmerit, I pick up the smallest wooded beads from Hobby Lobby. The ones I got are about 3 mm. Still a little large I think.
I'm still working on ModelExpo's Lowell dory, so I'm some way from thinking about the Muscongus Bay sloop. However, for what it's worth: My (full-size) boat is not much shorter than a lobster sloop, though a good deal lighter.  I have her rigged in clunky 19th-Century style, rather than anything sleek and yacht-like, yet the parrel beads on the jaws of her gunter spar are only about an inch in diameter -- call it 1mm at scale.
Go for the smallest you can find or, like the instructions say, go without.
Trevor
