Finally had the time to start unpacking the kit. A Few others have started so I can follow along as well.
Ki, as all Vanguard ones, come in a pleasing box.
All elements nicely packed
Brass, copper and book up top. You can see I unwrapped the printed ship's boats and stove as well as opened the boxes containing rigging thread and various other pieces
Lower layers of the box contain the laser etched parts
IMG_9449.thumb.jpg.5f863ce887b58157334ce26340610ccd.jpgIMG_9448.thumb.jpg.40fa2484b3de776f0d75c176ed876d98.jpgIMG_9451.thumb.jpeg.9958a9fbe147e05cebc68c3d872094da.jpegIMG_9450.thumb.jpeg.0999475e68ac841cf85431ccd6a21561.jpegIMG_9447.thumb.jpeg.5a04312387607362fb6d1bdf22fc0651.jpeg
Thought I would get the copper tape but was pleased when I saw actual copper plates
Lost of assembly work today.
First the cradle
Next faring the ribs. In this kit for the first time a line is provided  so as not to over do it
IMG_9456.thumb.jpg.db46eca7941e930db6fe9814a9457015.jpgIMG_9457.thumb.jpeg.cf6b3b5b05fc08c47a8e0bf1be19849a.jpegIMG_9458.thumb.jpg.01c0bc7cd84d1e55215d44169b82d120.jpg
Next assembling the hull structure. Everything interlocks so no glue until the end
IMG_9459.thumb.jpeg.bad3d4b22ccb98f3b4759e7a2ff358a3.jpegIMG_9461.thumb.jpeg.600de5edbc9b14f4b4493f0f32b35624.jpeg
Then the reinforcing keels
Locking inserts
At this point gluing the etched decks to the underdeck.  Lots of clamps to keep the thin etched deck from curling up.
IMG_9468.thumb.jpeg.bb87cd562fbb199f01d88e8f9b25e87a.jpegIMG_9467.thumb.jpeg.5cea965d92b6f48121da2656cecf5dcf.jpeg
Followed by inserting them and locking them into place
IMG_9472.thumb.jpeg.bf0af323a7d70abd9cf1d4dd1e386f3a.jpegIMG_9482.thumb.jpeg.ccf4a9f72a65169bd5c8bc1270450522.jpeg
Bow fillers sanded to line and can see when together pretty symmetric
Inserted into placed then capped
IMG_9477.thumb.jpeg.a9c0a8eb8a8b57e83cd5278372ec079f.jpegIMG_9478.thumb.jpeg.2a57a952d229795372efee25efafdfe3.jpegIMG_9479.thumb.jpg.e118aa0c1a36c578558b59b3ddee7c4e.jpg
Last for the day are the cabin assemblies on the stern made of multiple pieces
Have to remember to make mirror images of each other
Finally slotted into place
IMG_9484.thumb.jpeg.73b25cc9dab93498e66cad9a8dc708a0.jpegA
At this point brushing with wood glue permissible
Edited by ECK
duplicate photos
I don't know the difference between the two, I only have used plates. I installed them two at a time using  Super Phatic glue.  It was really easy to do. :) They are still sticking to my Pegasus.
Bob M.
Edited by Knocklouder
Guessing typos lol
"Start so you can Finish!"
In progress:
Astrolabe 1812 - Mantua 1:50;
In queue:
Pegasus - Amati 1:64
Completed:
The Dutchess of Kingston - 1:64 Vanguard Models 🙂
Santa Maria - 1:64, La Pinta - 1:64, La Nina - 1:64, Hannah Ship in a Bottle - 1:300, The Mayflower - 1:64, Viking Ship Drakkar -1:50 all by Amati. King of the Mississippi - Artesania Latina - 1:80  Queen Anne's Revenge - Piece Cool - 1:300  The Sea of Galilee Boat - Scott Miller - 1:20
I have yet to use copper tape. I opted for full copper tiles when I did Indy. Tape is easy to cut, trim and attach, no glue getting on the tiles. You do have to cut hundreds of pieces so you need a cutter seen below to make it easier and standardized. Also if you want the appearance of nails you would have to scribe 4 sides of each tile with the tool below.  Problem with the real thing is harder to trim (especially around the rudder) and use a lot of cyano. Occasionally falling off and needing to be reglued.
IMG_9492.thumb.jpeg.b8294187a9b13a1d11896ac777fed5ba.jpegIMG_9493.thumb.jpeg.050427f0b2162f63c27388c64e7b152a.jpeg
To me, the real copper tiles just look better as seen on my Indy build below
IMG_9490.thumb.jpeg.d2fa1f62bdfb4d651ffc8b95439b0bd4.jpegIMG_9491.thumb.jpeg.6cdb0bb329cfc4ee20b77607b68beef4.jpeg
Next ,although not required, painted hatches and capstan base
Next sail locker, really need to clap on veneers to prevent curls. Also orient veneers so plank lines align around
Blue Ensin and Glenn UK took photos of brick pavers to print a base.  As I do not have a color printer decided to do something different. Used scrap base then cut out wood bricks from some 1x3. Then glued them in staggered pattern.
IMG_9502.thumb.jpeg.e6e1f9dc211992d47afa508639f78066.jpegIMG_9503.thumb.jpeg.acf0e80a046fa83a655c53183c53d96d.jpeg
Filled with wood filler
Then painted red and rubbed down
Added white wash for mortar lines and rubbed again then light rubbing again with red paint
Next painted stove and added metallic filings to age it and mounted on faux brick base
IMG_9514.thumb.jpeg.11da82c2aaa75530227ef85187aaac7b.jpegIMG_9512.thumb.jpeg.0269a85919c75302f7377064b9fa6ccb.jpegIMG_9513.thumb.jpeg.05dddf12fedf7d0b96676fc2f885eb73.jpeg
Of course did not glue stove pipe chimney, that comes much later
Edited by ECK
For some reason duplicates show up at end
After seeing Glenn -UK's paint job of the lower deck, I decided to do the same. As I had already glued things, had do do a lot of taping before spraying. Unfortunately slight seepage requiring some scraping and sanding. Also recived the door handles and hinges from Syren and installed them.
IMG_9522.thumb.jpeg.9cfd564ed04b5adfc8cf7bfdf70aaec4.jpegIMG_9523.thumb.jpeg.62e165f3410381d359315f62332c4c94.jpegIMG_9526.thumb.jpg.888a227cec840e2ee2dd8c4bb656c555.jpgIMG_9528.thumb.jpg.23e47abfd9341b98060072cd540c7467.jpgIMG_9524.thumb.jpeg.ab03cec1e87266e9b7ce560f543b0347.jpeg
Spent a bit of time preparing the beams. First scraping the majority of the char with a scalpel then sanding
As I painted the lower bulwarks, I decided also to paint the beams, similar to the Indy.
Then inserting them into place
IMG_9533.thumb.jpg.902f37125c441a6be3006e121227610e.jpgIMG_9534.thumb.jpeg.0585ec24247306610aaaa0f909af7726.jpegIMG_9535.thumb.jpeg.2549088e7723d31d3b0fb720ba3455dd.jpeg
As I am waiting for the rings I purchased to come in to complete the hatch covers, I, like Glenn UK decided to do a few other repetitive tasks that need to be done. I decided to assemble the carronades and long guns. First a lot of char removal as it is hard to cover when airbrushing.
Although made easier by this nice tool
Next came sticking them on my painting board
 and finally a good airbrushing, a bit out of focus.
The final assembly with eyebolts and rings done. Total time to do all the guns about 6 hrs.
IMG_9548.thumb.jpg.d6d9a5931cb3887b9c10688db8f1aaad.jpgIMG_9547.thumb.jpeg.659e8caae01ad84ca890c6102eae1e08.jpegIMG_9546.thumb.jpeg.51c062be97059ddf99ab518e03c0a2c3.jpeg
As advertised, the deck clicked into place without and fiddling needed
Next feathered the ribs
IMG_9590.thumb.jpg.3a4bd5ca451d338132ea495f326a952c.jpgIMG_9591.thumb.jpg.58281aea568d3018c451dd615f78dcf6.jpgIMG_9592.thumb.jpg.d5a9ee85ba189fe73bf076e4d3f7d2c3.jpgIMG_9593.thumb.jpg.db5c475dc8d7615f876be2263215e139.jpg
Nest the stern patterns
Finally soaked and bent the the hull siding  to dry overnight. As others have noted, you need a lot of clamps.
It has been a busy week in more ways than one.  Having glued the bulwark in, I started the planking process.
You can see the rough planked hull
IMG_9639.thumb.jpg.21b65ad7e7cc519b203201d0edd01e72.jpgIMG_9640.thumb.jpg.e2de98e4ac09440c9aa648b04ba77d04.jpgIMG_9637.thumb.jpg.df44b538dbce19c2cb91eda732d75b47.jpgIMG_9638.thumb.jpg.c867090c3015cc2db97177165c714c4b.jpg
Then after cleaning it up. You can see I am trying to protect the bow as it just wants to break
IMG_9642.thumb.jpg.085a761d30cca2461f0d9266820b467f.jpgIMG_9643.thumb.jpg.d5468af497a441ec34d08722f165ffed.jpgIMG_9644.thumb.jpeg.9ba49aa5eea5304eaffe29e4a1845731.jpeg
Next added the outer layer over the sternpost , bow and false keel.IMG_9647.thumb.jpeg.7e1ed82cfac8f4cd8945f82dc1d2f524.jpeg
followed by the stern fascia
As Blue Ensign noted, it would be nice to cover the endgrain of the second planking rather than leaving exposed as in the original  instructions. When adding the stern fascia it is advised to sand it down flush with the first planking. I noticed there seems to be enough room to actually but the end of the second planking against it so I'll gice it a try. This would pbviate me needing to produce a larger fram from scrap pieces of wood.
IMG_9645.thumb.jpeg.45df62e9a1b8760ccfc577b6bcc372b3.jpegIMG_9646.thumb.jpeg.85c63eaa24e5614556c0ad1f929d0775.jpeg
As an aside, with several empty nest rooms , found a place to display several of Chris' designs, Granado, Flirt, Duchess and Adder
Post deleted -  should have read ECK's post more closely 🤒.
Edited by Richard44
Richard
Next build: Harpy Vanguard 1:64
Completed builds:
AL's Endeavour,  Corel's BellonaAmati's Xebec,  Billing's Roar Ege, Panart's Armed Launch
Ships' Boats - Vanguard 1:64 and Master Korabel 1:72
 Alexander Arbuthnot,  Christiaan Brunings,  Pevenseall by World of Paperships, card
HMS Pegasus by Victory
Captain John Smith's Shallop by Pavel Nitikin
Rumpler "Taube" 1911 by HMV, card
Thanks, definitely enough room. I like to add the poly since if I accidentally get paint on the unpainted areas I can scrape/ light sand off without major damage.
Of note, I have tried various method of tapering the bow sections of the planks. Always hard with blade /ruler method to get each side symmetrical. Settled on marking the are to be removed, clamping the 2 planks together and then planning done to get 2 almost identical curved planks.
IMG_9661.thumb.jpg.40a3f7641f3231de9acee3b652faa3bd.jpgIMG_9663.thumb.jpg.bd600ce881b875c33b78f219d26e0292.jpgIMG_9664.thumb.jpg.4ba1c65e626013b17b784be1fce51d21.jpgIMG_9665.thumb.jpg.edada876203537f2a40a557fd15363dc.jpg
Had taped everything up tight to airbrush strake but had issues so just used old fashioned brush.  Had painted tape edges with poly to seal any spots that might bleed paint. Did this before the maindeck area to prevent any accidents.
IMG_9682.thumb.jpeg.88f80f6e046757cb5ea80d4b02f6cc6d.jpegIMG_9683.thumb.jpeg.9d47a10096f639e691538dd495e755b1.jpegIMG_9684.thumb.jpeg.3988559aea6eaa88941cccd9723734fa.jpegIMG_9685.thumb.jpeg.155fa19cbfc8bb092bc39cabfa8ee357.jpegIMG_9688.thumb.jpeg.021ece5900d5a1286fcbc3d20eaa6b22.jpegIMG_9687.thumb.jpeg.dd8bdd5ff52610f376d7fcf453f59dbd.jpegIMG_9686.thumb.jpeg.a6631d32b6612a10591afda55b42af43.jpegIMG_9691.thumb.jpeg.23bd50e823391f032dd615a5cdf908fe.jpegIMG_9689.thumb.jpeg.d6ef5f8c3f3f7c3c12217bc225277397.jpegIMG_9690.thumb.jpeg.f1e03fb47593a6442a0855959315d6d5.jpeg
Decided to place the deck and inner bulwarks in before coppering.The deck just needed a little tweeking but fit nicely.
Soaked and clamped the forward bulwark overnight then airbrushed all the parts prior to installing.
Stern veneers fit after a little filing
Doors in. Used latches I had ordered from Syren and decided to airbrush the sides and roof. Of note the veneers are very delicate, unfortunately one split.
Then installed the rest
IMG_9697.thumb.jpg.00d6bdfdff10ea31dbe83a9009de6b45.jpgIMG_9696.thumb.jpg.815bc2bfc3b683d6394462375d854eba.jpg
You're powering ahead - looking good.
Richard
Completed builds:
Thanks. Airbrushing really helps with the big pieces and especially allows the engraving to be seen better.
