Maybe trying a model at a relatively larger scale? Olha Batchvarov is doing a group build of the Model Shipways Gunboat Philadelphia at 1:24. It's not a lot of small fiddly pieces. No tiny thin planks.
And maybe having the videos may help - not that you don't know what you're doing, but watching someone do it might help remind your hands how to do something.
I'm a neuroscientist (not a physician, not a neurologist) and with brain damage from surgery or stroke from my understanding it's trying to rewire (literally) your brain. It's slower to happen as an adult, and may depend on what brain areas were removed and what areas are close by, but other brain areas can sometimes take over lost functioning to some degree, but it takes practice. If you're seeing a physical therapist, especially one focusing on fine motor skills, you might ask them about what things you might want to do to transition back into your hobby. They might even see model building as a form of PT. Lots of people don't do their PT homework - having done a little myself for a relatively minor problem I know doing my "homework" was a chore - whereas building a model is a hobby.
Best of luck!
Johnny
I had an accident and lost use of my right arm bicep. I can still move my right hand but it is stiff and does not have a lot of flexibility. I use my left hand as my primary hand now because I can not raise my right arm without assistance from my left arm. So I am incredibly slow in moving and each move has to be planned in advance. I use a 3rd and 4th hand a lot, I use reverse tweezers a lot to hold things, I use super glue much less often because it takes awhile to get pieces situated. I use a white glue that can be released with alcohol  as well. Mainly it is just realizing that I have limitations and plan accordingly. Can I be as good as those with two good hands, NO, but I can  still do quality work and enjoy the process. I do 1/48 scale but no longer try to do 1/64 or higher. I also do admiralty models because rigging is not possible with my limitations. I still have great fun.
Thanks for your response.
I understand and I have to adapt to my situation.
The response is very reaffirming for me to keep trying.
As mentioned recovery is slow but in my case continues
and even after 3 years I can see very slow but continued improvement.
I do force myself to keep trying build what is hard because I know
you have to force yourself or you will not improve.
I to, have found I use a lot less superglue and have to clamp pieces I would have held before.
Thanks, I think the encouragement you have given me is the most important thing.
I think others have already said it but, in case it helps, I had a stroke last year and basically lost control of my right side. Perseverance my friend is what it's all about. I am sure your therapists have talked to you about 'neuroplasticity' which is the posh way to say brain rewiring but it does happen albeit slowly. Keeping trying to do difficult things helps that happen and will make your recovery faster. Keep up what you are doing and just remind yourself of the 'oh, I couldn't do that last week', moments. They really do happen.
Previous boat builds:
Amerigo Vespucci Occre
Yacht Mary
In the Gallery:
My wife has a condition which has resulted in severe scarring of the brain, and it's been a continual "rewiring" process for years.  The brain definitely does figure out how to do certain tasks again by rewiring itself to bypass damage. To get back motor skills, I'd actually recommend an x-box or similar game in which the game is played exclusively with your hands.  The more you use your hands, the quicker the brain will rewire.  Video games are the first things that come to mind for me, but anything which forces your hands to perform over and over and over and over... It works, it just takes time.   The other thing I'd recommend is to purchase Drawing on the Right Side of the Brain.  It is an amazingly enjoyable book which teaches you how to draw, and I think consistent drawing would also be beneficial for the rewiring process.
Alan
Alan and Mike
Thanks for responding.
My situation is very similar although I was fortunate enough not to have a stroke
when I woke up from the operation nothing on the right side of my body worked.
Of coarse I am right handed.
I work on writing a lot and getting better. That simple thing pushes me to small improvements.
Who ever thought writing would require so much brain activity.
It's strange, I can do most of the things I used to do and am also right handed but I have huge trouble writing especially noticeable when trying to sign something. Still, We persevere.
Yacht Mary
In the Gallery:
I am exactly the same.
I practice writing [or printing] daily and it is getting better even after 3 years. Very slowly but noticeable.
When I started out my brain could not even figure out how to hold a pencil.
Writing is probably the most difficult daily function and I write
for practice even though I use the keyboard for almost everything.
I can tell you it gets better the more you do.
https://pictures.abebooks.com/isbn/9781585429202-us.jpg
This is a remarkable book. A friend of mine on her retirement decided tot take up water dolour painting and read the book. She was o impressed that she took an in person  course taught by the author.  She now produces extraordinary paintings. The book is available new on Amazon for $28 and user on www.abebooks.com for about $1.
Thanks I will check it out.
When I turned 62 I felt like retiring because I and enough and was not happy in my job.
I realized it was not the work but the work environment.
One day I quit the job I had working in the same industry my entire life.
I did not know what was next because I really did not have a plan.
To make a long story short an acquaintance said ' lets build machinery together'.
I thought what the heck.
That was 15 years ago and we have built over 50 unique steel tube scarfing machines
that improve operator safety.
We have had a great time. The last 15 years have been the best in my life.
I have created a steady income stream for my wife and I and truly secured out future.
I guess my point is I agree with you. And you never know. My life sure did not go as I thought it would.
Johnny, I’ve had two strokes, one in the right cerebellum and the second in my left cerebellum. Also Multiple Myloma, cancer of the blood, (in remission after a bone marrow transplant), suspected cause of that was exposure to jet fuel.
The second stroke was worse than the first. Cause was atrial fibrillation.  I suffered balance issues, depression and issues with handwriting . Long story short, physical therapy helped the second stroke. And two other things have helped.
I have recently taken up learning the piano. Learning to read  music,  and using my left and right hand to play at the same time. I believe this has helped me “re-wire” my brain. And then there is model ship building.
I’ve had trouble building Smuggler for the last year but have resumed. My hands are now much steadier, and was even  to even carve out the Bulwarks, although it took me two weeks! .
Music has helped me, maybe it could help you too. The power of music and model ship building,
All the best during your recovery.
Edited by East Ender
spelling
Tim Lent
