Venetian Carrack or Cocha by woodrat - FINISHED - 1/64
As a first step in my cunning plan I have made a mold from plaster of Paris, cunningly using a Frascati bottle as a shaper.
The rough mold is shaped with files and sandpaper
Cheers
Dick
Current build:
 Le Gros Ventre 1:48 POF   http://modelshipworld.com/index.php?/topic/564-le-gros-ventre-by-woodrat-scale-1-48-pof-1767-french-exploration-vessel/
Past builds:
Mycenaean War Galley by Woodrat - 1:48 - Shell first Plank on Frame:https://modelshipworld.com/topic/33384-mycenaean-war-galley-by-woodrat-148-shell-first-plank-on-frame
Venetian round ship 14th century by Woodrat fully framed - 1:40 scalCompleted
https://modelshipworld.com/index.php?/topic/17991-venetian-round-ship-14th-century-by-woodrat-fully-framed-140-scale
Venetian Carrack or Cocha 1/64 by woodrat   https://modelshipworld.com/index.php?/topic/4915-venetian-carrack-or-cocha-164-by-woodrat        completed
United States Frigate Essex 1:64 POF   http://modelshipworld.com/index.php?/topic/4496-usf-essex-by-woodrat-scale-1-64-fully-framed-from-takakjian-plans/ - completed
Yenikapi12 by Woodrat - 1/16 scale - a small Byzantine merchant vessel of the 9th century
https://modelshipworld.com/topic/23815-yenikapi12-by-woodrat-116-scale-a-small-byzantine-merchant-vessel-of-the-9th-century-finished/
The Incredible Hulc by Woodrat - an experimental reconstruction of a mediaeval transport
https://modelshipworld.com/topic/25641-the-elusive-hulc-by-woodrat-finished-a-speculative-reconstruction-of-a-mediaeval-merchantman-132-plank-on-frame/
Link to comment
Share on other sites
Wow, that turned out very good so far!
Jesse
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Link to comment
My cunning plan is so cunning even a cunning person wouldn't think of it. It's so great...
Yes Druxey, I will varnish it and coat with mold release.
Current build:
Past builds:
Link to comment
The second cunning plan was not quite as cunning as a cunning plan could be.
Silkspan was wet and stretched on a frame the painted with dilute acrylic. Taken off the frame molded and set with medium.
593d1f07bfecf_mainsailsecondattempt01.thumb.jpg.7c85f6a7f1c2eb0554730dc650847a43.jpg593d1f0d0cfa0_mainsailsecondattempt02.thumb.jpg.47742dcabeaf60356b9b462aead8bc09.jpg
the silkspan did not have enough strength when removed from the mold to hold the complex shape.
But..... nil desperandum. The third cunning plan has gone a bit better so far
I used vertical strips of calligraphy paper over the mold with white glue. Then horizontal strips of silkspan over that.
Dry and detach from mold
Seems to be holding its shape. Ready for reinforcements and boltropes.
Dick
Current build:
Past builds:
Link to comment
Whew! Looks like you are winning now. Might I suggest using acrylic matt medium rather than white glue? Then, if necessary you can dampen areas of the sail to reshape them without anything falling apart.
Link to comment
Druxey, I don't know what brand of medium you use but the one I bought did not hold its strength when rewet. I can keep trying and pick the best looking sail.:huh:
Current build:
Past builds:
Link to comment
Can't you fixate with plain ordinairy hairspray ........ like on charcoal drawings ...
Carl
Link to comment
thanks Druxey and Carl. The problem is making the construct stiff enough to maintain its shape against gravity. Experiments continue.
Current build:
Past builds:
Link to comment
Hairspray won't do, but you might try a rattle can with glue ... after drying you can paint it if required, as it won't dissolve
Carl
Link to comment
Yes, indeed, Carl. I plan some painting and weathering of the sail.
Dick
Current build:
Past builds:
Link to comment
How many layers of SilkSpan are you using? It should be a single layer, except for the reinforcements. That will be light enough not to sag when stiffened with acrylic medium. I'd be very cautious about using spray glue: any remaining unpainted spots will 'grow' dust fuzz.
Link to comment
Hi Woodrat -
I have had good success, like Druxey, with acrylic matte medium.  I lay up the sail with all its details - bolt ropes, cringles, reinforcements, etc.  Then I lace it to the spar and suspend it horizontally  from the corners of the spar and the lower corners of the sail.  The matte medium is painted on and allowed to dry completely.  The simple weight of the liquid medium pulls the sail into a nice billow.  This can be encouraged with a small bag of rice.  Once dry, it hangs quite nicely, I think.  You can read more about the method, and some mistakes, in my build log of the Queen Anne's Revenge.
Best of success.
Dan
Current build -SS Mayaguez (c.1975) scale 1/16" = 1' (1:192) by Dan Pariser
Prior scratch builds - Royal yacht Henrietta, USS Monitor, USS Maine, HMS Pelican, SS America, SS Rex, SS Uruguay, Viking knarr, Gokstad ship, Thames River Skiff , USS OneidaSwan 42 racing yacht  Queen Anne's Revenge (1710) SS Andrea Doria (1952), SS Michelangelo (1962) , Queen Anne's Revenge (2nd model) USS/SS Leviathan (1914),  James B Colgate (1892),  POW bone model (circa 1800) restoration
Link to comment
Thanks Dan. That would work for a simple billowing sail and that is not the problem. In this carrack sail, there is a reverse curve in the centre where the centre of the sail is being pulled back by a lanyard so the sail does not rub on the mainstay. Also, the carrack mainsail in contemporary illustrations does not hang off the yard. It billows upwards and forwards. 593f517b8c820_carrackfroma1482chartbyGraziosoBenincasaa.jpg.4e6174981306f3baa7bc331d344dfc63.jpg
This is why I am having difficulty. But I think I have it licked.
even the excellent R C Anderson model does not attempt this. If I can reproduce this it will be a very gratifying effect. Cheers
Dick
Current build:
Past builds:
Link to comment
Hi Dick -
Glad you have it licked.  Looking forward to seeing the results.
I was just agreeing with Druxey that acrylic matte medium is a good stiffener and has worked for me.
Dan
Link to comment
Dan
I could do with a good stiffener, right now:cheers:
Seriously though, Dan your results on the Queen Anne's Revenge are superb. I wont be able to match that. What I hope to produce is something like the true shape of a carrack mainsail cracking on in a following wind
Current build:
Past builds:
Link to comment
The following is the construction of the maintop (or crow's nest if you like)
The construction of the base. Note the access aft for the jacob's ladder to allow ingress to the top and the entry of the halliards. for ward of the mast will be the exit of the halliards.
The side frames for the top are made by laminating thin strips of wood and sawing them to thickness required
the position of the frames is located using my Emco dividing attachment (Unimat 3)
The circular rail for the top is turned on the lathe. Note the crane arching over the rail. This is for lifting objects such as ammunition etc from the deck to the maintop. It has a pulley.
The frames are strengthened by bracing timbers
Temporary positioning of the maintop on the mast
Almost ready for the mainsail and yard. Still have work to do at deck level.
Dick
Current build:
Past builds:
Link to comment
Looks great!
Jesse
Link to comment
The crane on the maintop is wrong. It should be projecting laterally not aft so that it will access the waist not the quarterdeck. Will fix as it will bug me!
Dick
Current build:
Past builds:
Link to comment
Link to comment
On 17/06/2017 at 2:46 PM, Louie da fly said:
How big are those lubber holes, Dick? Are they big enough for someone to squeeze through? They look rather small - but doubtless you've already worked that all out.
Steven
He fitted with inches to spare. Crows nest were very large fighting platforms in those days
DSCN1350a.jpg.422e3d2ea910af14d91ae80196f6ab66.jpgDSCN1351a.jpg.0899b2439c50254581c28739d4170377.jpg
Dick
Current build:
Past builds:
Link to comment
I doubt there were many "well-built" crewmen on a carrack - at least among the topmen. The cook, maybe . . .
By the way, Dick, I really ought to take the opportunity to say how good that ship looks, and how well she resembles the contemporary pictures. That last profile picture of her really shows up what a magnificent job you've done.
Steven
Link to comment
You are most kind, Steven:blush: and I would also like to thank everyone for the 'likes'. I can almost see the light at the end of the tunnel.
Dick
Current build:
Past builds:
Link to comment
I agree with Steven, I am enjoying this build very much - both the craftsmanship and the historical research!
Jesse
Link to comment
I have done the best I could on the mainsail. It is an approximation of the possible appearance of sail in that era. It only remains to hoist it.
DSCN1357a.jpg.f76dfb983511417336a975765b8c28a7.jpgDSCN1356a.jpg.bf7b0350efb308387c74650dfa75f9e2.jpgDSCN1358a.jpg.326ab84b5dd2ef6650feef1d21a826ff.jpg
Current build:
Past builds:
Link to comment
That's very impressive, Dick.
So what did you finally use to make the sail, and is there a chance of a tutorial in the future for those of us who want to follow your lead?
Steven
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
