More work on the Launch.
finished hull faring, added the wale planking and the "skids" that runs at the base of the hull. Working in this very small scale I use plastic strip to create the fineer details: the internal battens etc as wood is just not fine enough.
I then sprayed with Tamiya undercoat ready for painting yellow ochre on the inner and satin off white on the outer. I use an off white as white is too stark a contrast against the other colours of the ship.
After painting I will add all the details, thwarts etc
thanks for looking, cheers Mike
Stunning work Mike, a master class! I would have called those "skids" "chines" but I maybe wrong...Whatever they are called they are a little detail that adds to your model in the best way.
Cheers
Alistair
Cheers
Alistair
Current Build -
Making good progress.
added the rudder gudgeons, and the rear "elbow suuports"
I turned the hull upside down and sprayed with Tamiya, airforce Insignia white. As mentioned this is an off white, and at this scale I find it the perfect hue, and not too bright a contrast against the other colours.
I then masked off from the wales and sprayed the inside with flat black where the frames are only, then applied the yellow ochre over the top. this gives a nice subtle shaded look that enhances the detail. I learnt this trick during my aircraft modelling years.
Edited by mikec
Another interesting lesson in the use of colour in scale. The lighter yellow ochre colur looks right on the victory ship sides but too light on the launch. so I re-sprayed with a darker yellow. It looks right now. I also masked and painted the wales. I made the thwarts, by laminating 0.5mm sapele strip. I used this as it has a reddish hue that when  coloured with a black oak stain, it would retain a warm tinge to it. The photos haven't picked this up but in real life it worked.
I am very pleased with the result of my completely scratch built launch.
Now the fun bit - adding the details….
I just returned home from visiting family for a few days on waiheke Island.
I managed to paint, varnish and add the mast top supports. Also the seats of ease. Now just need to add details to the launch (oars, rudder knees etc)
then nearly finished.  also posting some detail shots...
Amazing work Mike!
Next time I'm in Devonport I'll be there to admire it. I like the hints of verdigris on the copper - planned or natural? In any case the whole model has a patina of a very well made and natural thing. Bravo! Brilliant!
Cheers
Alistair
Cheers
Alistair
Current Build -
Hi Alistair, thanks for your kind comments, give me a call when you are in Devonport 021 039 6214, happy to show her to you. and my Endeavour project.
The verdigris is deliberate, I obtained a special solution that a metalwork company uses to age copper for high end architectural projects that required aged copper as an effect. I have no idea what it is as they made it up for me, and was a trade secret.
cheers Mike
Thank you Mike
I will do that next time I'm in Auckland - at this moment it will be, sadly, for a funeral. Ivan Mercep - a living legend and one of NZ's finest architects is at the door and I've done lots of work with him.
Years ago I did a project in architecture which needed a quick patina on copper. The secret ingredient was pure horse urine. Kid you not...the copper went completely green in a matter of days. Happy client and a relieved horse...I guess. Horse **** - who would have thought?!
Thanks
Alistair
Cheers
Alistair
Current Build -
I have just about completed the launch, added the supports to the thwarts, made the rudder (this was very hard to do at this small scale- i wanted it to work (which I managed to achieve). made the oars, just a few more details and it will be finished...
Edited by mikec
  • 4 months later...
