I sure like the way this is going together. The precision reminds me of surgeons preparing for an operation
S.os
New Bedford Whaleboat build. Kit by Model Shipways
I've been making progress on my model and according to the instruction booklet I should be painting it, at least parts of it.
Are acrylic's ok ? I did apply a sanding sealer. but I want to stain the untreated floor boards which are walnut.
Thanks
S.O.S.
Mike,
   Dang!  You guys have a roof not made out of canvas!
   I see you are using beech for your gundeck framing as well.  I did not notice it with the other framing, but it really shows here.  Do you only use if for faming or will you use it for planking in any areas?  I was thnking about using it for ceiling planking for my next project...give it that miniature oak look.  Thoughts?
Edited by Chuck Seiler
Chuck Seiler
San Diego Ship Modelers Guild
Current Build:: Colonial Schooner SULTANA (scratch from Model Expo Plans), Hanseatic Cog Wutender Hund, Pinas Cross Section
Completed:  Missouri Riverboat FAR WEST (1876) Scratch, 1776 Gunboat PHILADELPHIA (Scratch), John Smith Shallop
Chuck,
The problem with our roof is they only bought enough boards to do the starboard side. The guys on the port side still get wet when it rains.
This is the first model that I used beech for all the framing. It is real easy to work with and gives that miniature oak appearance. I used it for deck planking on the Pennsylvania and exterior planking on the Pinta (posted on Model Ship Builder) it is a good all-purpose wood.  I will use blood wood for the ceiling planking on the Washington.
Have you used bloodwood before? I like the look when freshly cut, but it darkens over time. I guess you need to put a finish on it rather quickly.
Chuck Seiler
Chuck,
I usually finish bloodwood fairly soon after using it. Try the link to USS Pennsylvania – (1837) I used quite a bit of bloodwood in the section and it doesn’t look too bad.
Patrick,
Thanks I will finish the framing tonight and post an update tomorrow.
Mike
Mike,
   What guns will you be using?  John Bratten* lists WASHINGTON as having 1x 18 pounder, 1 x 12 pounder, 2 x 9 pounders and 6 x 6 pounders.
*The Gondola PHILADELPHIA & the Battle of Lake Champlain, by John R. Bratten
Chuck Seiler
Looking good, Mike.  Now I grasp the concept of the clamps, string, and what appears to be hooks for securing the planks while the glue dries.  But the BFG and nails...?????
Thanks by using wire hooks and rubber bands it is easy to adjust the tension on the planks as the glue dries. The framing hammer just shows how small the model actually is.
Patrick
I make all my own grating and ladders from boxwood using a Proxxon table saw and a jig.
Mike
