Jason, Jim, I'd like to ask you about the 3mm blocks, have you filled down those blocks corners or did you strop them as they were in the kit?
Cheers
I used a "block tumbler" to round off the edges of the 3mm blocks, it rounds off the hard edges.
Cheers,
Jason
In the shipyard:
Hi again mates
What's your opinion on sealing rope knots with cyano?
I'm asking especially for mid to long-term time results.
Thank you.
This is my almost final approach for the breeching rope of the carronades
Edited by Stergios
I try to deal with those 2 mm blocks but really can not...
Such tinny structures, without lateral grooves to help myshelf for the stropping.
I give up !!
Edited by Stergios
Time for a kind of hair-cut to the elevation screw...
Jason, how did you reduce the height of the screw, using a plier or a tumbler tool?
Thanks again
Thanks again
The same wire cutters used on the other brass wire, you do want to be carefull.  Top can then be filed to remove any sharp edges.
Hooks are looking good.  If you haven't already, I'd suggest making up one full set and seeing how they look on the carronade.  You don't wan't to make all the hooks and then find they're not going to work.  Its hard to tell the size, but you do want to be careful to ensure the hooks aren't too long otherwise there won't be any space between the blocks.
Cheers,
Jason
In the shipyard:
Copy that, Jason.
Thanks
Well, you're right Jason, hooks are really too long... :(  :angry:
I still believe that the transformed eyelets to hooks are more authentic....
The point is that i need to cut/reduce their stem to have room for the tackling.
I wonder if I can find smaller in aftermarket...
Edited by Stergios
Making hooks with the 2mm photo etch "eyebolts" definitely gives a smaller hook (its what I used) than with the 3mm wire kit supplied ones - they come in sets of 250 from CMB.
Cheers,
Jason
In the shipyard:
Yes - those are the ones, got my sizes all mixed up!
Thanks again Jason..
What type of 3 mm blocks have you used for the gun tackling, natural or walnut?
Cheers.
Cheers.
Walnut - they do lighten up when they've been sanded in the block tumbler
Cheers,
Jason
In the shipyard:
New kids (0,3 mm eyelets) on the block...
I tried to use the aftermarket brass hooks (like Jim) but really no enough space for the couple of them, needed in every side of the carronade.
Using those 0,3 mm eyelets I'm ok with the setting of the standing & running rigging of the tackling
I start to prepare the tackling.
It;s my first time but it seems a painfull story, I'm not sure.... should I assemble it on the deck or not ?....
But above all, the real head-ache is doing the "frapping"... :(
I think that I need at least a length of 15 cm for the running rigging and a knot as a final starter to turn the edge of the line 4-5 times around the tackling...
Edited by Stergios
You seem to have it thought out Stergios, its definitely a tedious process but feels so good when complete.  The technique that worked best for me was to make up the tackles off the ship first (loosely), attach and then gradually tighten.  You are right, there is a lot of wasteage of the thread between attaching the hooks and the actual tackle, but its better to be safe than sorry as its not a big expense.
Cheers,
Jason
In the shipyard:
Thank you Jason, for the moment I'm studying your technique...
Hi mates, a basic question about pva glue: are you sure that is contraindicated for glueing fittings on varnished surfaces (deck, etc)?
Thank you.
