I decided to leave the top edge of the 1st component of the foremast and mainmast round like I did for the tenon of the bowsprit. I consider this as less important issue so I can lιve with it
Edited by Stergios
Next stop was to fix the bowsprit cap at 90 degrees to the keel.
I used this pin to hold it and after all I cut it and left it inserted flush in the cap to provide more stability.
I've left the most anterior grating unglued for the mo.
I've seen that Jason and Jim (according to appropriate scales and literature) have used a 2mm line for the anchors.
A question in personal debate is how much out of scale could be the option of 2,5mm line...
Hi my friends
all those small strips of black paper of 2mm.... to simulate the metal bands etc on the masts.
It is about a special type (propably self-adhesive) paper?
How did you cut it and apply it so perfectly around the masts circumference?
I was thinking to apply rings of 2 turns of 0,75 line instead, I don't know whta's your opinion....
Thanks
Stergios - take a look at link below for visual (Seems some had mysteriously disappeared from my log which I just corrected).  Use the black card included in the kit and cut 2mm strips.  The technique I found easiest was to take one end of the strip on back of mast with CA glue, you can then continue to glue around the mast making sure to keep everything square.  Tiny amount of CA glue again worked fine.  Once the band has been glued around the mast, glue with a small overlap and then trim off with a sharp blade.
http://modelshipworld.com/index.php?/topic/509-hms-snake-by-beef-wellington-caldercraft-scale-1-64-first-wooden-ship-build/page-27#entry121805
Cheers,
Jason
In the shipyard:
Jason thanks for the pics which hopefully are back in you build log.
The point is that I can't see any black paper in the kit...
Despite the experienced references to use a 2mm line for the anchors, by looking the crew I don't consider the 2,5 mm line so huge especially as the rope for the main anchors of the ship....
It is my idea?  :)
Edited by Stergios
Sounds like it got left out of your kit  :( .  I'd suggest going to an office supply store and getting some thick black paper as an alternative to contacting Caldercraft - it would probably be a easier solution.
I like the look of the anchor rope you decided upon, your Snake really is coming together now and looking great.
Cheers,
Jason
In the shipyard:
Crosstrees and tressletrees dry-fitted.
The foremast is'nt totally vertical to the deck, there is a slight posterior inclination, but the crosstrees and tressletrees are parallel to the waterline...
There is a difference between the plans and the anterior "opening" of the lower mast top but I hope that this is a minor cause of concern...
Thanks.
Edited by Stergios
It is less than that. I had no problem with it.
Mort
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
I agree with Mort, the gap actually makes life much easier for fitting the slings. I think the extra gap was introduced around this period specifically for that purpose.
Cheers,
Jason
In the shipyard:
Proxxon db 250 lathe was a very usefull option/tool to enable me to mark and place almost correctly the black "metal" strips.... and the respective cleats.
Edited by Stergios
Looking good Stergios. You're right to get the platforms parallel to the waterline, I found it best to get that correct first as the bibs required a little shaping to match as each mast has a slightly different angle. Not sure if you've made the top masts yet, but I suggest doing that before finally fitting the masts as it's easier to work off the ship with small adjustments - my opinion. I also saw there is debate as to whether to glue the masts, I did and given the slow setting time of PVA glue there is plenty of time to ensure these are vertical.
Cheers,
Jason
In the shipyard:
Thank you Jason, I've almost completed the top mast out of the model (pics to follow...).
The foremast's lower edge is already dry-fitted/fixed in the respective hole/slot below the deck, with no chance of reamarkable changing of that slight posterior tilting...   Do you consider that tilting/inclination as undesirable/abnormal? In my opinion is'nt so important.
Thanks.
Stergios
Edited by Stergios
Are you referring to differences in the angle of the top and lower masts? They really should be parallel, and I definitely had adjustments to do to get it as accurate as possible. I used my eye to judge rather than any scientific measurement. If it looks good to you, that's really what matters as everyone sees things differently. Sorry if I misunderstood your question.
Cheers,
Jason
In the shipyard:
I'm referring to the fact that the main mast is'nt vertical/perpendicular to the deck.
Anyway, the only thing that matters is to align the lower mast top parallel to the waterline, from this point of view I am ok...
Thanks Jason
Edited by Stergios
The masts should all be at different angles, the foremast will be closest to perpendicular, the slots in the keel factor this in. Every think is looking good!
Cheers,
Jason
In the shipyard:
