I'm quite satisfied from my first attempts to stimulate the boom irons.
This is my 1st cut strip of 22mm to stimulate the irons.
I've tried two methods just to see wha's the best for me in practise...
I'm showing you the consecutive steps of the first one. I think that these steps is easy do be understood.
Making the iron of the yard dummy
and after that the respective one for the stunsail dummy
Taken from another angle...
Could you tell me what;s the indicative best distance "x" between the red lines, for my Snake?? :(
Another pic
And here you are the preliminary result..
Of course in need for iron soldering
Edited by Stergios
The second method is by calculating the distance of every circle for the iron using the yard diameter and the rule of "3,14"...
Here without space or distance between the yard and stunsail dummies...
The iron for the yard first using clockwise turn
I've used a tape to stabilize the two dowels how you see
Here is the counterclockwise turn for the iron of the stunsail, from a posterior view
And the anterior view
Thank you for your comments in advance, just to help me how to proceed.
Edited by Stergios
My main concern is about the strength of those 0,3mm strips against possible tension and other forces from the rest of rigging etc...??
Of course I'll stabilize the yards to the masts using 1,5mm brass wire.
Edited by Stergios
Of course I'll stailize the yards to the masts using 1,5mm brass wire.
The stuns'l booms don't have any rigging so nothing to worry about there,they are really just decorative in this simplified representation.
Cheers,
Jason
In the shipyard:
Thank you Jason.
I know that you follow the whole literature regarding the rigging and the other procedures.
have you any idea about the distance "x" between the yards and stunsail boom?
I think to go with the second method (no space between them) to fit the irons.
Cheers.
You will need a gap, much smaller toward the center of the yard, but increases on the outer boom iron - simply because the yards are tapered, but the stuns'l booms should be horizontal.
Cheers,
Jason
In the shipyard:
Nice work and very fitting, I assume these are for port and starboard yards, as you know you only need one per side, with a boom ring at each end.
Looking good.
Frank  :piratebo5:
Looking good.
Frank  :piratebo5:
Hi Frank and thanks for the comment.
Those are just two dowels dummies just to stimulate in practice yard's and stunsail's assembly.
The real dowels are in a safe place!...
Edited by Stergios
Hi everybody
the yards factory has started.
Thinking to go with the blocks first and to continue with the foot ropes.
I'll leave the section of the irons for the final stage.
I hope to have your agreement on those steps.
Thanks
PS: The main yard with its marked blocks-ropes and irons attachments.
I'm thinking to fix three foot ropes at each half yard at a distance of 2,5 cm.
Edited by Stergios
Hi Snake-partners
May I ask you about those J-L-B-J fittings..... those are two seperate sets of fittings/ropes or a single one with all the blocks included?
Any idea or tutorial on how to deal with them?
Thank you in advance!!
Stergios
Hi Snake-partners
Stergios
...any help for the J-L-B-J block-complex guys?
I can't find any tip...
Thanks again.
Thanks again.
I think I'm looking a tip for that main yard's lift...
Edited by Stergios
I'm not near my model or plans, but I can tell you that Peterson rigging book is much more usefully illustrated, I used the plans only for belaying locations as the details are not completely clear.
Cheers,
Jason
In the shipyard:
from what I remember - it was over 2 years ago - I mostly followed the plans with Peterson at my side the entire way. I probably made the lifts per the illustration but I don't recall, the model is at my sister in laws house.
mort
Current Build - Caldercraft Diana
Completed - Artesiana Latina Swift, Harvey, MGS Prince de Neufchatel, Imai USS Susquehanna, Mamoli Constitution, Rattlesnake per Hunt Practium, Caldercraft Snake, Diana, Caldercraft Victory, Kammerlander Duke William
Waiting to be Launched -  Bluejacket Constitution
Proud member of The New Jersey Ship Model Society, Model Shipwrights of Niagara, Model Shipwrights of Western New York and Offshore member of the Society of Model Shipwrights
That's my 1st (main) yard with its boomsail irons in place.
I'm quite satisfied witht the initial results.
Thank you.
PS: The 3mm dowel is just a guide for the right placement of all the irons. A 45 degrees inclination is required.
Edited by Stergios
Looks great Stergios! Remember feeling accomplished when I got my first yard fully done. Just have to look forward to fitting the parrals....!
Thanks Jim, it was a really great experience to have almost done the main yard.
Go ahed for the parrals!!
  • 2 months later...
I just ordered my HMS Snake a few day ago, I will definitely be following you build!
