I ve left a lot of spare fittings and rope-threads to improve later as a final touch up procedure.
Now I really feel that i'm close to the finish. I plan to create a custom made base and to support/stabilize the keel with those two 2mm metal rods.
I hope the model to be stable and safe
Edited by drtrap
Last weeks are spent trying to understand strategy and the correct way to fix the braces….
Starting from top to bottom, from front to back, some tips important that I should know in advance…??
A real headache again :)
Edited by drtrap
Small, current updates of my work
I've left a lot of spaghetti-threads on the deck just to feel secure enough before I freeze or trim them down.
A real symmetry of the lines and the respective tension of the threads is needed at this stage
Edited by drtrap
I like the extra anchor detailing you have done very much.
Andrew
Completed (Kits):-
Thank you Andrew, it is a fact that this particular part and fitting of the model I wanted to represent it as best I could
  • 8 months later...
21 hours ago, drtrap said:
Greetings to everyone, despite the many professional obligations the shipyard continues its work all this time, I will be with you soon with several photos from the completion of the ship after a long time, thank you
Looking forward to seeing the Grand reveal!
Andrew
Completed (Kits):-
I don't know if I asked it before...
What kind of lighting and placement of it (top, bottom) dou you suggest for the case I'm preparing for?
Thank you
  • 4 months later...
Hi Stergios did you finish your case for your wonderful Snake?
Andrew
Completed (Kits):-
  • 11 months later...
Hi AJohnson!
After a long-term planning and some delays I finally placed the model in a custom made case.
Photos to follow...
Edited by drtrap
