Finishing up the hatchways I glued them to the deck along with the shot racks.
The cover boards for the capstan platform were then added between the aft hatch and companionway opening and finally the edge boards around the inside of the companionway were glued in place.
After all the hatches were installed I thought I would add a little 'Dirk bling'.  I liked the iron angle pieces he added to the corners of the hatch where the anchor ropes enter the hull so I thought I’d give it a try.  Using the spur from the photo-etched parts I made a couple ‘L’ shaped pieces.  Next I drilled holes for .5 mm rivets I got from Scale Hardware, blackened all the parts and then very carefully attached them to the coaming.  Not too bad but I have to try a little harder to keep the ca glue off the parts
Sal
Current
Nordkap 476 - Billing Boats
Complete
USCG Harriet Lane - Model Shipways
U.S. Brig Syren - Model Shipways
New York Pilot Boat 'Phantom' 1868 - Model Shipways
Thanks Dirk, you are definitely an inspiration for me. And thanks for letting me know about the grating, please don't hesitate to tell me if I have anything else not correct.
Edited by _SalD_
Sal
Current
Complete
Looking good Sal!  :) Nice touch with the coaming corners.
GEORGE
Sal
the coaming corners look great.
The good part about me working so slowly is I get to see how you and the others did parts.
Richard
Edited by rtropp
Richard
Member: The Nautical Research Guild
For the companionway ladder I drew up my own riser template to make sure the spacing between each rung was equal.  After transferring the rung location to the side rails I made grooves for the treads by using a flat file that has teeth on its edges only.  The treads were then glued in place.  The finished ladder came out slightly racked but since it’s going to be installed below deck and you can't really see it I decided not to do it over.  I’ll need to do better for the above deck ladders.
The capstan was quite the challenge.  I stated by making templates to place over the small wooden disks to mark their center points.  I then drilled a small hole in the center so I could mount the disks and cog onto a dremel mandrel.  This was done so I could lightly sand the edges to remove the char and to keep the pieces round.
Next I installed the 8 whelps on the center wooden dowel, prior to gluing them on I drilled a hole down its center.  The instructions called for a 5/32” diameter dowel but the drawing showed it to be closer to ¼” diameter.  I thought the larger dowel looked better so that’s what I used.  To help me line up the whelps I make a couple templates, one was glued to the bottom of the dowel to line up the bottom of the whelp and the other was used to align the top.  The larger template was not glued to the dowel and the smaller one was sanded off after the whelps were installed.
I don’t know if this is over kill but to glue all the pieces together I used the screw from the mandrel to fasten all the parts together while adding glue between the pieces.   This kept everything in alignment.  I think the hardest part of this piece was to make all the tiny chocks that fit between the whelps.  After about a dozen failed attempts I finally figures out how to make them.
The last piece to be glued on was the small cap on top of the capstan and then I added some 7mm rivets for effect.
For the companionway I started by gluing 5 strips of 1/32” x 1/8” basswood together. I made it long enough so I could to cut the two sides and back of the companionway out of it.  The back piece had to be trimmed about 1/32" on each side to fit in my companionway opening.
I could have made this piece even longer because I also did the same thing for the top of the companionway.  I decided that I would run the planking 90 degrees to what was shown on the drawing. This worked out because I was able the cut the lid out of this piece also.
The door hinges were made from the photo-etch spur and the lid hinges were the ones provided.  Once I had all the pieces it was just a matter of assembling them all.
One word of caution is to make sure you measure the height of the capstan cog openings and to make sure you don’t make the companionway higher than that.  I had to reduce the height of mine compared to what was show on the drawing.  One addition that I made was to add a trim piece along the top of the coaming.  This covered up a small gap I had between the coaming and companionway sides and back.  I also added a couple pawls near the capstan.
Sal
Current
Complete
Very nice, clean work Sal!  She looks better every time I check in.  :)
GEORGE
Small update and I’d like to thank everyone for their kind words and for hitting the ‘likes’ button.
I put together the binnacle which was pretty straight forward as most of the parts are provided on the laser cut sheet.  I beveled  the top's edges and door and drawer fronts before gluing them on and decided not to install the trim piece between the top doors and lower drawers, it just didn’t look right.  I added handles made from 7mm rivets and drilled the three vent holes on each side. The bell support was the hardest part of this section trying to get the wire legs all the same.  I’m still not sure if I like the way it came out and it may be on the list for a do over.
Sal
Current
Complete
Wow, your deck furnishings are looking so good & detailed. I'm studying all of this to help me do better when I get to these steps.
Jesse
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
Assembling the 12 pounders.  This task was straight forward using all the parts provided in the kit.  The laser cut gun carriages were assembled and painted as were the cannons.  The handle for the quoin is a small belaying pin I had left over from my Phantom and used some of the leftover copper tape for the iron brackets, cut to shape and blackened, to secure the cannon to the carriage.  A few rivets were added for effect.
The ship’s wheel that came with the kit (top wheel in the first photo) was in very bad shape so I got in touch with Model Expo and they sent me a replacement.  I also order, from ME, a wooden wheel with the intention of using it instead of the metal one but it turn out to be much too thick to use.  The replacement metal wheel casing that ME sent was in better shape than the original but had a lot of flash to remove. The wheel was filed and all the wooden pieces cleaned of the char and stained.
post-11922-0-89047300-1445952539_thumb.jpgpost-11922-0-55021500-1445952542_thumb.jpgpost-11922-0-91882100-1445952543_thumb.jpg
I haven't permanently attached the cannons or ship’s wheel to the deck yet because I want to wait until I make the tiller and work out how I want to show the rigging for the steering.
Sal
Current
Complete
Beautifully done, Sal! Your long guns look the part, and the new wheel cleaned up very nicely! I have looked at the commercially available wooden wheels myself and found them all out of scale. This is clearly a part where Chuck's Syren company could come up with a nice little steering wheel kit.
Btw, if you continue at that speed your Syren will be finished at Christmas :)
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
Thanks Thomas,
Christmas! That might be a very aggressive schedule but on the up side that would mean I could ask Santa or should I say Mrs. Santa for a new ship. :)
Sal
Current
Complete
Hello! Your build look great! Is the ships bell made of wood? I really like your Phantom as well and will be referring to it as I build mine. I just have to wait until Christmas to get it!
Edit: Sorry I didn't look close enough. I see it isn't made of wood. (I think :))
Edited by Elijah
-Elijah
Current build(s):
Completed build(s):
Model Shipways Phantom
Member of:
Hello Elijah,
Thanks for looking at my logs and for the kind words. The bell is a britannia metal casting and it comes with the kit. You should enjoy building the Phantom it's a great kit, take your time and enjoy it. And if you run into any problems along the way there's a wealth of knowledge on this forum with a terrific group of people who will help you out.
Sal
Current
Complete
First I would like to thank everyone for all the 'likes' and for the kind words of encouragement, they're much appreciated.
Continuing with the aft deck fixtures I made the water pumps from some brass and copper tubing I had.  The pieces were soldered together and given a coat of paint.  It’s amazing what a couple of coats of black paint will cover up.  The parts were then assembled as described in the instructions.
The aft cannons were set in place and rigged pretty much the same as the carronades, just not as many.
The tiller was made as shown in the instructions and as I was thinking about how to attach the split rings to it I remembered that I had won a serving tool in a raffle at the Northeast Ship Model Conference last April.  So I tried my hand at serving some rope to lash the rings to the end of the tiller.  It took a few attempts but I finally got the hang of it.
Finally I rigged the ships steering mechanism.  My final configuration is a conglomeration (say that five times fast) of a number of layouts I studied on this forum.  I thought that the position (angle) of the line from the tiller to the bulwark would work more efficiently if it was more in line with the arc the tiller would travel in instead of being perpendicular to it.  To accomplish this instead of moving the eye bolts on the bulwarks farther aft which would have crowded the aft cannons, I made the tiller a little longer.  I also added two blocks at the base of the ship’s wheel to keep the line lower to the deck.  To give myself a little more room to install these blocks I decided to reposition the wheel to the outside of the support legs.  I’m not sure if this is historically correct but it made rigging the line easier and I thought it would give my helmsmen a little more room to steer.  I also had to remove the binnacle that was already installed because the spacing between the wheel, binnacle and companionway didn’t look right.  Before reinstalling the binnacle I decided to add a compass in it.
post-11922-0-41890100-1446476969_thumb.jpgpost-11922-0-01337000-1446476965_thumb.jpgpost-11922-0-87045400-1446476965_thumb.jpg
Sal
Current
Complete
Looking really good
Your model is looking great!
-Elijah
Current build(s):
Completed build(s):
Member of:
Hi Sal,
I totally echo George's sentiments and when I saw the pics the first thing I thought was SWEET!!!. I hope you bring it on 11/14, I'd love to see it in person.
Best,
John
Member:
Connecticut Marine Model Society
Model Ship World
"So we beat on, boats against the current, bourne back ceaselessly into the past" F. Scott Fitzgerald - The Great Gatsby
"If at first you don’t succeed.......skydiving is probably not for you”
Nice work ---- getting a little crowded back there, isn't it.  Love the compass.
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
Hi All,
Ther way I see it, is that given this is Sal's second build, he is mere steps away from Danny V., Remco, EdT and some of the other great builders on this site!
Best,
John
Member:
Model Ship World
