Inboard planking looks very nice.  Earl will charge $19.95 ----- any boat, any color.  Keep that black paint handy  :D  :D
Augie
Current Build: US Frigate Confederacy - MS 1:64
Previous Builds :
US Brig Syren (MS) - 2013 (see Completed Ship Gallery)
Greek Tug Ulises (OcCre) - 2009 (see Completed Ship Gallery)
Victory Cross Section (Corel) - 1988
Essex (MS) 1/8"- 1976
Cutty Sark (Revell 1:96) - 1956
I’m a bit confused, not the first time and I'm sure it won't be the last.
I’ve been reading up on laying the deck planking from various sources and it appears that the two most common patterns used were the ‘4 butt shift’ or the ‘3 butt shift’ systems.
Chuck recommends using the ‘4 butt shift’ in the instruction manual.  Now maybe it’s me and I realize that reading a couple of books in no ways makes me and expert on decking, but… the planking layout shown in the manual doesn’t appear to match either the ‘3’ or ‘4’ butt shift pattern above.  Depending on which pattern you use, you would have either three or four planks in between repeating butt joints, the manual shows only 2.
Using the 4 butt shift pattern above and a plank length of approximately 20 feet I came up with the pattern shown below.  I would appreciate any comments, pro or con, or just hit the 'likes' button.
Please let me know if I’m totally off base and should keep reading.  Thanks
Sal
Current
Nordkap 476 - Billing Boats
Complete
USCG Harriet Lane - Model Shipways
U.S. Brig Syren - Model Shipways
New York Pilot Boat 'Phantom' 1868 - Model Shipways
Sal -   back in the 'good old days' of MSW 1.0, Chuck had the build log for his Syren prototype.  It ran some 140 pages.  It included discussion/comments.  Many times, it clarified what might be a little 'fuzzy' in the manual.
What Chuck shows in the manual is essentially a 3 butt shift.  The pattern repeats every 3rd board.  But he uses only single nails at the end of each seam.  So it does not match your first illustration.  Your proposed system repeats every 5th board.....and does not nail every board at every bulkhead although it does use single nails at the ends of the seams.
Now we're working at 3/16 scale.  You need to consider not only what might be historically accurate, but also what looks reasonable.  I know that when I tried to do a true 3 butt shift (with the double nails at the seams) it looked like I had blasted the deck with a shotgun.  So I went essentially with what Chuck showed in the manual --- repeat every 3 boards, single nails only.  But notice the 'alternating' nails at the bulkheads where there is no seam.  These add a lot.
Here's what I'd suggest.  Make up a 'mock deck'.  Maybe 4" long and 8 boards wide.  Try out a variety of patterns --- as well as a variety of treenail diameters/colors, and pick what you like best.  You can also do your entire finishing sequence on this sample to truly have a mind's eye view of what the finished deck will look like.  Just like painting a room, what it looks like in a large area may not look like what you envisioned from a color chip.
Time spent now making the final selection is well spent.  Hope this helps a little.
Augie
Previous Builds :
Augie, Dirk thanks for the input.  Augie your right I forgot to show the treenails at the intermediate bulkheads (lots of holes) and Dirk I didn’t show the cut outs but I should have.
I’m still scratching my head over this but I did lay out Chuck’s planking pattern to compare it to the one I did.  After I did this I realized (I think) why he did it that way.  On the 4 butt shift the butt ends of the planks don’t always fall on the ‘supplied’ bulkheads but in between on the ‘imaginary’ ones.  Where as in Chuck’s pattern the butt ends all land on the ‘supplied’ bulkheads.  If I use the 4 butt shift I would need to provide supports at the end of the planks where they missed the bulkheads or use and unusually long plank to keep the ends on the bulkheads.
So for now, seeing that this is my first deck planking attempt, I’m leaning towards Chuck’s layout but I'm still reading.  I also understand Augie’s point that sometimes you can’t go with 100%  accuracy at these scales.
Sal
Current
Complete
I don't wish to bore you with this but after doing a little more reading on deck planking and downloading and reading through Chuck’s original build log I think I have a path forward on my deck layout.  Below are three layouts of different deck patterns.  The first is Chuck's layout, the second is a 4 butt shift and the third a 3 butt shift. Treenails between the joints are not shown for clarity.
In Chuck’s original build log he uses a three butt shift but uses the bulkheads instead of the ‘actual’ deck beams to space the joints.  I believe that’s the same conclusion I came up with after drawing his plank pattern but just didn’t know how to explain it as well.
Chuck’s log (star date 2007):
I also read a few articles from Practical Shipbuilding, by A. Campbell  Holms,  on deck joints and in Article 336 it states:
Being a structural engineer myself it’s hard for me to ignore rules and specifications (much too anal) so in a round-a-about way, what I’m trying to say is that I’ve decided to use the four butt shift pattern, shown above, for the deck on my model.  With the four butt pattern there are not as many joints that will fall off the bulkheads as with the three butt pattern.  And in reality with the balsa fillers I have between the bulkheads there will only be four or five joints that won’t have any support beneath them.  All that being said, now I have to go and actually do it. :o
Sal
Current
Complete
Ship is all repainted and ready for the deck.
post-11922-0-25607100-1425319826_thumb.jpg                          post-11922-0-23546400-1425319827_thumb.jpg
post-11922-0-15207200-1425319828_thumb.jpg            post-11922-0-15033900-1425319829_thumb.jpg
post-11922-0-07900800-1425319830_thumb.jpg                          post-11922-0-16131900-1425319831_thumb.jpg
Sal
Current
Complete
I decided not to use the laser cut margin plank that was provided with the kit because it would have required quite a bit of sanding to make it fit.  I used the remaining 1/16” thick sheet of basswood I use for the cap rail to make the margin plank in one piece.  I used a paper template to get the shape of the bulwarks and then traced it onto the wood sheet.  It was then cut out, sanded to fit and glued in place.
post-11922-0-78629300-1425482723_thumb.jpg             post-11922-0-78859900-1425482725_thumb.jpg
We had one minor glitch with the margin plank when the apprentice carpenter, who was responsible for measuring it's length, appears to have used a tape measure with the first few inches broken off.  Subsequently, the margin plank was a little short. Now this shipyard’s owner is very frugal and not wanting to spend the money for new planks decided to install a deck plank at the stern, athwart of the main deck planking to fill the gap.  Similar to an edging plank in your hardwood floor.
Moving on....  After reviewing some of the build logs here on MSW I decided to place the deck planking similar to what Thomas (Gahm) did on his Syren, that is to follow the bulwarks with the planking toward the stern of the ship.  I like how this looks so I thought I would give it a try. I would also like to thank Thomas for giving me a few pointers.
I don’t know if this is newbie over design but to help me keep the planks in alignment I pasted little tick strips along each bulkhead marking the location of each plank.
Since most of the first four planks on either side of the centerline will be covered by deck furnishings I decided to install each of them in two pieces. The ends of each plank meet at bulkhead ‘D’ where they will be covered by a grating hatch. The planks towards the stern were sanded down to fit the curve of the bulwarks with the aid of a template.  All other planks will be installed cut to length per my layout drawing.
post-11922-0-48577600-1425482729_thumb.jpg             post-11922-0-14092000-1425482733_thumb.jpg
My planking ‘shop drawing’ to help me keep track of which plank I’m working on and where the butt ends are located.
Edited by _SalD_
Sal
Current
Complete
Nice work on the margin planks.  You're on your way to scratch building.  And I agree, it's tough to get good help these days!
Augie
Previous Builds :
Thanks Augie.  He's a good guy and he's learning a lot so I think we'll keep him around.
Sal
Current
Complete
The deck planking went surprisingly well.  I’m glad I used the tick strips along the bulkheads because they were a big help in keeping the stern planking in line.   I’m also glad I the used balsa wood infill between the bulkheads because it gave me something to set the push pins in to hold the planking in place.
Nibbing the planks at the bow wasn’t as hard as I thought it was going to be either.  The only problem I discovered after I had installed most of the nibbed plank was that I didn’t pay close enough attention the diagonal length of each nib on corresponding planks, either side of the centerline.  This resulted in the flat portion of the nib, on corresponding planks, not starting in the exact location along the margin plank.  Lesson learned for next time.
post-11922-0-82263100-1425922981_thumb.jpg post-11922-0-38547500-1425922983_thumb.jpg
Planking in progress                                                              Push pins used to hold planking in place
post-11922-0-87255100-1425922984_thumb.jpg post-11922-0-30850800-1425922986_thumb.jpg
Planking complete, not sanded                                            Planking sanded, no finish
Aft companion way opening cut out                                         Marking hatch and mast locations
This is a little off topic but whenever I do any major home improvement projects, e.g. finishing off the basement, which involves framing walls and installing drywall I have a little habit of hiding a little something in the wall just in case someone in the distance future knocks the wall down. So prior to putting up the last piece of drywall I will put an empty (clean) beer bottle, with a dollar bill and note inside of it, in the wall.  To that effect I decided to place a little something in the hull of the ship before finishing the planking.  The beer bottle I couldn’t fit but the dollar and note went in okay.  Who knows maybe a hundred years from now a budding model ship builder will buy the ship at a thrift shop and find the treasure and note while restoring it to its former glory. :D
Sal
Current
Complete
Excellent job on your deck planking! Well done!
Thomas
Current Built:   Model Shipways  Syren  (US Brig 1803)
Last Built:        Anfora (kit bashed)  Ictineo II  (1st steam powered submarine 1864)
Nice work on the deck.  And a nice touch with the memento.  Usually, I just leave some DNA.
Augie
Previous Builds :
Thanks Thomas,  I like how the tapered aft planking came out. I'm glad I did it that way.
Thanks Augie and  ..."I just leave some DNA.",  I'm not going to ask how.  :blush::)
And thanks to everyone for all the 'likes'
Sal
Current
Complete
Looks good Sal. hey I am going to try to come again this Saturday. i have ordered the Syren but its going to be a while before I see it. Can you bring your instruction manual along so I can browse through it? Thanks. Hope all is well See you soon. Jim
Current/But Not immediate Build Logs
I am still gathering the tools I need but starting preliminary work. Nothing to show just yet.
Fair American
Armed Virginia Sloop.
Just happened across your Syren build here Sal, and she's looking marvelous! Your planking is turning out fantastic. I know I'm a little late for the party, but will pull up a stool and cigar now if you don't mind.
Cheers  :cheers:
GEORGE
Great looking deck Sal! The planking is very clean.
Thanks Patrick, the Admiral is always making me swab the decks :D
Very nice !  Beautiful deck and painting.
gerty, thank you
Jim, I'll see you on Saturday and I will bring the manual.  Do you know you can download each chapter from the Model Expo website?  They're located under the document tab on the Syren page.
Cheers  :cheers:
Thanks George and welcome aboard.  There's always room for another cigar smoker.  How about a scotch to go along with it?
Sal
Current
Complete
Yes Sal I have it, but I would like to flip through it rather then go from PDF File to PDF file just to look through it. Thanks. Hope your well.
Fair American
Thanks.
Fair American
I was a little disappointed in the way I finished the deck and I learned what not to do next time.  I drilled all the holes for the treenails prior to staining the deck which in hind sight I don’t think was a good idea.  Prior to staining the deck I stained a test strip with holes in it similar to the deck and found that the stain was bleeding into the holes making a dark ring at each hole.  To avoid this I filled all the holes with wood filler before staining.  There was no bleeding into the holes but the stain was a little blotchy (yes Augie I tried pre-stain this time).  I believe it was from not sanding the deck enough to remove all the wood filler that was on the surface.  I was a little reluctant to sand too much in fear of sanding through the deck plank but again in hind sight there was plenty of material left to sand.
post-11922-0-85495100-1426598326_thumb.jpg post-11922-0-11520200-1426598328_thumb.jpg
post-11922-0-53639600-1426598329_thumb.jpg post-11922-0-88459900-1426598330_thumb.jpg
For the treenails I decided to show only the treenails located along the deck beams where I had a butt joint and not at every beam between the bulkheads.  I thought it would be too much, not to mention I didn’t want to drill all those holes.  The only problem was that after I filled them with wood filler and stained the deck the treenails didn’t show up too well.  I may redo them.
For the waterway I tried a few different procedures to make the triangular chamfer strip from the 1/16” square stock.  There is probably a real simple way of doing this but what I came up with was; first I cut a V-groove in a piece of scrap pine using a V gouge, making the depth of the groove slightly less than the finished shape of the waterway.  Next I taped two erasing shields on either side of the groove to avoid sanding into the pine.  The shields are 0.1 mm thick.  Then I laid the wood strip in the groove and removed the top half using my dremel’s drum sanding attachment.  What was left was a nice 1/16” X 1/16” chamfer strip.
post-11922-0-14489400-1426598408_thumb.jpg post-11922-0-88626800-1426598406_thumb.jpg
post-11922-0-41987700-1426598405_thumb.jpg post-11922-0-58978500-1426598468_thumb.jpg
Sal
Current
Complete
Your waterways are nicely done! They are a very clean fit. What stain did you use for the deck?
Thomas
Chapter 8 – coppering the hull
Prior to coppering the hull I need to make the stamps for the simulated nail heads in the copper plates.  I will be using the nail pattern that Chuck shows in the instructions for the port and starboard plates and after studying Dirk’s (Dubz) build I will be making two additional stamps for the port and starboard dressing belts.  The patterns were drawn to 3/16” scale using AutoCAD.
For the pins I used 26 gauge Lancets, bought at Wal-Mart, as mentioned in Richard’s (rtropp) and Thomas’s (Gahm) builds.  I went with the thicker 26 gauge lancets and not the 30 gauge as Thomas used because I wasn’t showing as many nails he did.  Extracting the needle from the plastic holder proved to be a challenge and what I finally did was; using my propane torch I heated the metal tip thus softening the plastic around the needle so it could be pulled out easier.  Disclaimer:  If you use this technique please be aware that the plastic does burn so use caution and have a cup of water on hand to place the plastic holder in.
I used some scrap poplar to make the stamp and cut it to the dimensions shown in the instructions.  I glued the nail pattern on it as a guide and then I got to use the Christmas present from the Admiral (Proxxon drill press with compound table). :)
After drilling all the holes I inserted the pins and glued them in.  Prior to inserting them I did cut about a ¼” off the needles (sharp end) so they wouldn’t stick out so much.  One modification I made to the stamp was to attach an X-Acto chisel blade to one end of the stamp at the same height as the pins.  I believe it’s a #17 blade and it fit the ¼” wide stamp perfectly.  I attached the blade to mark the copper where I would need to make the cut for the individual plates, I found however that by applying just the right amount of force the blade will cut the copper but not the paper backing.  I also made the opening in the jig a 1/16” larger to account for the blade thickness.
post-11922-0-26281300-1427124767_thumb.jpg post-11922-0-68335000-1427124768_thumb.jpg
Edited by _SalD_
Sal
Current
Complete
