Just thought some of you might find this light assembly useful. Even though I have a double flourescent light above my work bench, I was still finding too many shadows obscuring my work. Therefore I bought a pair of light stands and LED portable work lights. I have set up the lights on either side of me and above the work area. The stands are telescopic and swivel so I can adjust the aim. The light is 3500 lumens, so now I see EVERYTHING!
Cheers,
Peter
Build Log: Billing - Cutty Sark
In The Gallery: HMS Unicorn, HMAV Bounty, L'Etoile, Marie Jeanne, Lilla Dan, Zeeschouw "Irene"
A Toast: To a wind that blows, A ship that goes, And the lass that loved a sailor!
Peter, Merry Christmas and a Happy New Year to you and yours. The Sark is looking wonderful.
Hi Guys,
I have commenced the running rigging at last, starting with the three sets of lifts for the 3 yards mounted on the lower masts. Baby steps... And what with runing the rigging to the spider bands at the bases of the masts, meant coiling down the ends of those lines. In the past, I used to leave enough thread after running the line through its various blocks and tackles and coiling the surplus several times around the belaying pin. However, with greater efficiency and less toil in mind I decided to put Tom Lauria's method into practice. He coils the lines off the model and places the coils on the pins. It is a more accurate depiction of how lines are coiled onto pins at the expense of having two lines make up each individual rope. Here's a link to his video:
I did make a couple of modifications to his technique so as the loop around the pin didn't come undone and used diluted white glue to set the coils up permanently. Here are a few pic's of my efforts:
Here I used a scrap piece of cedar strip as the pins were more easily pushed into it.
Here are the coils around the pins with an additional pin set back from the top edge of the cedar strip. This allowed for a bigger bight to pull under and into the coil of rope.
Here I used actual belaying pins to thread the bight as it made it easier to place the coils onto the model. As mentioned I used diluted white glue to set up the coils and allowed for longer tails so the bight did not become unstuck.
And here are the results of the lifts' rigging onto their respective belaying points. It took a bit of trial and error to come up with a successful method but I am hoping it will alleviate some of the hassle in this repetitive task. Cheers
  • 11 months later...
After another lengthy hiatus, work has resumed on my Cutty Sark. I left off work last spring after discovering I had made a somewhat serious error on some of the rigging of the masts. It has taken several months to reconcile these errors, and  deciding whether to undo a substantial amount of standing rigging or leave well enough alone and charge on. I opted for Option B as the mistakes can only be noticed by me and an astute number of serious clipper ship aficonadoes on this website. 😉 I have fitted a number of the lower yards with ties and halliards and have now dry fitted the upeer yards on all three masts. I spent the last couple of days manufacturing collars for the trusses. Now I can continue rigging the yards with ties, lifts and halliards. Here are some pics showing all the yards in place , the upper ones being dry fitted.
  • 5 weeks later...
I've been a tad busier in my workshop of late which I'm pretty happy about. Since posting last time, all the yards above the upper topsail yards are hung and secured in place with tyes, halliards and lifts. I have used Longridge's and Underhill's books as references and the end result on my model is acceptable to my own satisfaction. The running rigging for the yards uses quite a bit of chain which is novel for me. I was able to source the chain needed at a local bead shop. It is some kind of brass alloy which I have painted black in situ after the yard is placed on the mast. I have found it easier to paint the chain on the model as the chain is taut and easy to access from each side. The next set of rigging to install will be the sheets, tacks and clew lines. I am trying to work from the centerline to the rails in order to have easier access to the belaying points. Therefore the ratlines will probably be the last bit of rigging to complete.
IMG_2038.JPG.beb75eea565162876f8019b4cba1eaa2.JPGIMG_2039.JPG.e152a56405545974842de26dce2170ba.JPGIMG_2040.JPG.03ecb8fed0ef92f5eea1813e6c0dfd9a.JPGIMG_2041.JPG.c0157decc8a50532bf450b857cb08fb2.JPGIMG_2037.JPG.a6e58915ceac6ccf8cb6e798d5ed9961.JPG
There are a fair number of tools and supplies necessary for rigging the model. Styrafoam trays are pretty handy in keeping sets of tools herded together and reduces the amount of time spent looking for the tool you need. My work bench is still a bit of a dog's breakfast at times but organizing it once in a while saves alot of foul language... I've also added a picture of the chain used on the model along with some reference material from Harold Underhill's book, Masting and Rigging the Clipper Ship and Ocean Carrier.
IMG_2042.JPG.0b92f60a589bac11068af1349e60ea5e.JPGIMG_2036.JPG.6e3e98f1247081571ffcccb5a62c027e.JPGIMG_2035.JPG.62c2efa93dd6dec6d575973964af30a3.JPGIMG_2034.JPG.4a56e6eff5089108a8ce041c3dda52d9.JPGIMG_2043.JPG.13a4736cf18f751d97659f2260067320.JPG
On to the next phase of rigging the yards. I have prepped all the blocks for the sheets, tacks and clew lines. Because of the use of the stock blocks that come with a Billing kit, I have painted them all black with 2 coats of Humbrol paint. A bit tedious to say the least but worth the effort. There are also a number of coils ready to hang from the belaying pins once the rigging starts.
IMG_2050.jpg.20475c60c0ec68e0ec983bce62709892.jpgIMG_2049.jpg.af23da4b5317fb6878ce8b4eb79192b5.jpgIMG_2048.jpg.03107e90466ad6464b9ba039de69460a.jpgIMG_2047.jpg.869759db500be3cde10896d2417a605c.jpg
It's ratline time! Since last posting, the sheets and clewlines have been rigged for all three masts from the topsails up. These lines have been belayed to the main pin racks behind the shrouds which will have these pesky little lines attached. I wanted as much access as possible to ensure there would be fewer obstacles in tying off the sheets and clew lines. Ratlines are pretty straightforward but I decided to make a post on a nifty way to get the spacing uniform. I cut a small piece of toothpaste box packaging to the correct width, folded it in half and then clipped it to the outermost shrouds the take the ratlines. The tiny clothespins were purchased at Michaels, a craft store chain. With the "jig" in place, the ratlines are added to the shrouds at the top edge of the paper. I'm not sure if this has been tried before, so apologies to the originator. Once the ratlines have been added to the lower mast shrouds, the sheets, tacks and clew lines will be added to the courses on all three masts.
Here is a picture of the "ratline tool" (patent pending) in place along with a pic of the tools in use for this rivetting aspect of model ship building.😉
IMG_2696.JPG.18a0bc3feead8b0304b9e26efd42950a.JPGIMG_2698.JPG.a773557ff02b1a73a889f83b7c3580e4.JPG
All the best with your project. Feel free to ask any question you have and I will try to answer them.
Cheers,
Peter
Twenty one ratlines later and this is the result. I'm a bit rusty at tying these but the process will become faster and more uniform with practice. I use bee's wax and a little dulcotte laquer to finish the ratlines which also keeps the knots knotted. Only 17 sets to go!
The Spencer Gaff is something that caught my attention late in the masting and rigging of the model. It is refernced in Longridge's "The Cutty Sark" so I have included it on my model. Campbell's plans also show it but without any associated rigging. Therefore it is now installed on my model with the vangs and chain sling, but without the lift. I had to re-rig the spanker gaff once the spencer gaff was installed as the former did not have the correct angle to the mast. The spanker gaff has a more accute angle. Here is a photo of the result.
Edited by petervisser
Work continues albeit at a slower pace now that spring has arrived. Between the installation of the running rigging, I have added the running lights which the Cutty Sark would have shown in her early days. The kit did provide 2 lanterns and sidelight screens, but they were not of the correct scale. This became evident when dry fitted onto the shrouds. Thankfully, I had some brass lanterns which were scavenged at some point and they seemed to be the perfect size. The screens were therefore modified and reduced in size accordingly. The kit did not provide a sternlight which to me seems a major oversight. Here are some photos of the results.
Cs4.JPG.685b7e960e071ce15d84d53cfaa3422b.JPGCS1.JPG.e20e471685a4adcaebbecd8cf74935d5.JPGCS5.JPG.7ea383b2d86aa679cb7dbcc764d545fd.JPGCS2.JPG.cc858d33fd5b6fae242b848a3a73ad83.JPGCS3.thumb.JPG.2b745807281b32900c56b9ae73096bdc.JPGCS5.JPG.7ea383b2d86aa679cb7dbcc764d545fd.JPG
OK, I'm hooked. You have another follower,Peter. You have done a fine job on her. I will enjoy this, even if I am very late to the party :)
  • 2 months later...
Your Cutty Sark is looking great.  You will enjoy rigging the braces!  I have had the pleasure of touring and photographing the Cutty Sark in Greenwich and am planning to do so again next month.
After tying about 900 clove hitches to complete the ratlines, the model is ready for the last phase of rigging. Phew! I can now begin rigging the braces at last. What with the hot weather here in Victoria, my workshop which is semi-sub ground level is one of the coolest rooms in the house. This has allowed me to work on the model, despite the sunny weather. Here's a photo showing the current status...
A fine job indeed, Peter. She looks very regal.
Peter......fine job for sure.  I've looked...but what scale is that model in?
Rob
Current build:
Finished build:
Current build(On hold):
Hi Rob. It is the Billing 1:75 kit of a rather old vintage produced in the 70’s I’m guessing. The scale is hiding in the title of the log.😉 Thanks for looking in.
Cheers, Peter
Cheers, Peter
Thanks Peter...I must have read right past that.....  I couldn't find it in the body of the conversation....and it was right in front of my face....all the time.
After looking through your log, I quickly gathered it was larger than 1/96.  The scale all my clippers are built in.....so I can manage the room they will take and scaling them together, for size comparison.
Good job...bringing back an old classic.  Indeed it must have been a lot more crafting....
Rob
Current build:
Finished build:
Hi Rob. I find this scale manageable but 1:96 scale would be too challenging for me. I also have a frigate in 1:75 scale which I would love to display next to CS but I’m getting ALOT of pushback from a certain someone about the so called clutter of ship models around the house. Girls….😉
Great looking model!
Bob
Current builds: Artesania Latina Cutty Sark, Myrtle Corey (scratch build)
Completed: Model Shipways Pinnance, Amati Hannah ship in a bottle, Blue Jacket America, Midwest Sakonnet
                     Midwest Fantail (R/C), Thunder Tiger Victoria (R/C), Victor Model V-12 Footy (R/C)
Member of the Model Shipwrights of Niagara
That is a beautiful display case and a fine looking model. And, you are right, clipper models like that are a lot nicer to look at than a telescope (which is made for looking through 🤣🤣 )
