Impressive and inspirative work. Considering I slowly come to that stage, I am following with great interest
Very well done!!!!
Edited by Nenad
In progress:
CUTTY SARK - Tehnodidakta => scratch => Campbell plans
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-1#entry64653
Content of log :
http://modelshipworld.com/index.php/topic/2501-cutty-sark-by-nenad-tehnodidakta-scratched-campbells-plans/page-62#entry217381
Past build:
Stella, Heller kit, plastic, Santa Maria, Tehnodidakta kit, wood, Jolly Roger Heller kit, plastic
Not much progress this weekend, fitting the cabin skylight in place, putting in the port side aft bits, pinrail and eyebolts and starting to glue in the starboard side deadeyes - not quite brave enough to make my own yet, so I'll see how the kit's pre-fabs look.
Completed:    USS Constitution Cross Section
                      Pride of Baltimore 1:64
                      USS Cairo Blue Jacket Ships
In the Yard:    Half Moon
                      Smoothbore Naval Deck Gun
                      Brig Syren
                      Medway Long Boat
Do you plan to correct paint on white hull mouldings?
In progress:
Content of log :
Past build:
Yes, even though if you stand back far enough they don't look too bad.  I'm going to see if I can scrape them clean first.
                      Brig Syren
                      Medway Long Boat
Working on the main and mizzen stays (which don't show up well in pictures), but before I move to the shrouds I figure I should do the fore stays, so I can use the shrouds (moving fore to aft) to tighten the stays a bit - or at least make them look straight.  But that means fabricating the jib boom.  I made a cradle for my drill (standing in as a lathe) and will likely make my first attempt sometime tomorrow, after I draw out a full-sized template.
                      Brig Syren
                      Medway Long Boat
Actualy managed some photos
                      Brig Syren
                      Medway Long Boat
Fore-stays leaving the ends of the threads on for the moment in case I have to re-tie anything as I rig the shrouds.
                      Brig Syren
                      Medway Long Boat
​First attempt at the jib boom using my home-made "lathe."  First I made a template (3rd time looked good - using digital calipers helped) and drilled the holes for the sheaves, then slowly sanded the taper.   Test fit looks ok, although I still haven't quite figured out how to attach it all.
                      Brig Syren
                      Medway Long Boat
Some recent work in the boatyard
                      Brig Syren
                      Medway Long Boat
Great work on the bowsprit and dolphin striker and making them out of wood. You won't be disappointed when it comes to rigging.
Current Builds:  Revell 1:96 Thermopylae Restoration
                           Revell 1:96 Constitution COMPLETED
                           Aeropiccola HMS Endeavor IN ORDINARY
Planned Builds: Scientific Sea Witch
                            Marine Models USF Essex
Just excelent!
In progress:
Content of log :
Past build:
Thanks to you both.  Working with the wood was not as hard as I thought it would be - I may become more ambitious.
                      Brig Syren
                      Medway Long Boat
Steve,
Very nice work on the bowsprit and jib boom. I agree with Scott, it will make a world of difference when all the rigging goes on. I am planning on starting my own Revell Cutty Sark soon so I am watching your log with great interest.
Steve
Current Build: Merit 1/48 Early Eco 80' PT Boat and Imai 1/50 Catalan Ship
Revell 1/196 USS Constitution (My oldest son's school project)
Revell 1/72 Hanse Kogge
Revell 1/50 Viking Ship
Revell 1/72 U-Boat
Zvezda 1/72 English Medieval Ship Thomas
Revell 1/90 The Nina
A bit more progress on the rigging.  The model is beginning to show her age - some very brittle plastic that keeps breaking.  Some of the breaks I can mend - like the plastic eyebolts.  Others, like the cathead that just snapped, will be a pretty big challenge.
                      Brig Syren
                      Medway Long Boat
Standing rigging almost done, then I need to cut off the loose ends of the knots without cutting the lines - did that once already.  Thankfully the kit came with pre-made ratlines, so I did not have to learn that skill yet.
Next up - footropes.
                      Brig Syren
                      Medway Long Boat
hi Steve, Steve here
   I'm impressed with the bowsprit and jib boom- excellent work scale in dimension and looks realistic. I knew you would appreciate the ease in replacing key mast, boom and spars with wood it is just so much better. By the way, to finish the wood you will want to use a bit of sanding sealer, otherwise the wood will simply soak up the paint and that may cause the wood grain to emerge.
   great job, keep up the great work.
   steve
A bit more progress - need to practice trimming the knots a bit closer without cutting lines.  I think next time I may try to make the footropes out of wire, they have really been a struggle to make out of thread.
                      Brig Syren
                      Medway Long Boat
  • 2 months later...
Standing rigging is pretty much done; running rigging has intimidated me, which is why it has been a while since my last post.
Stropping and seizing blocks has been hard enough - I've been experimenting with different ways of doing it and using different materials - white thread, black thread, rigging line from kits, even wire (26 gauge for 5mm blocks, 28 gauge for 3mm blocks) - that I am starting to get the hang of, although blocks with 2 beckets are still a problem.
Attaching the blocks to spars is another issue  - I'm not even sure what knots to use or if I should just try seizing the lines like I did for the brace pendants. Any helpful hints/suggestions/tutorials/read this books would be appreciated.
                      Brig Syren
                      Medway Long Boat
Thanks.  I seem to be getting into a rhythm with these finally.
                      Brig Syren
                      Medway Long Boat
Great work and photos. I am in the process of making jib boom and bow sprit. Your work gives me some good ideas.
Thanks!!
Omar
Omar
Cutty Sark   Scientific kit 1:140ish
very nice take on the 'ole girl Steve  ;)    I have mine on a shelf in the hallway......I still need ti finish her.
I yam wot I yam!
finished builds:
Billing T78 Norden
in dry dock:
Still working on blocks - the ones in these photos I tried the method outlined in this video -
https://www.youtube.com/watch?v=WUrRb66VSSE
worked very well - although I still need practice - getting the thread not to slip off the loops as I'm turning was not always easy - and getting the same number of turns was often an issue.  Next ship I'll start using Chuck Passaro's blocks
Also started on the lifts for the fore course.  Hope to be done setting up the fore yards in the next week or so and then start rigging those at least.
Edited by stevenmh
                      Brig Syren
                      Medway Long Boat
