Building this boat for the Wounded Warrior Project sale at Spring MSW Member Show-and-tell Meeting.
 Current build: Syren : Kit- Model Shipways
Side project: HMS Bounty - Revel -(plastic)
On hold: Pre-owned, unfinished Mayflower (wood)
Past builds: Scottish Maid - AL- 1:50, USS North Carolina Battleship -1/350  (plastic),   Andromede - Dikar (wood),   Yatch Atlantic - 14" (wood),   Pirate Ship - 1:72 (plastic),   Custom built wood Brig from scratch - ?(3/4" =1'),   4 small scratch builds (wood),   Vietnamese fishing boat (wood)   & a Ship in a bottle
This kit has a building jig that the boat is planked over for the shape then removed off the jig once the planking is done. Built the jig, glued the bottom plank & end stems then attached this assembly on the jig to begin the planking.
Planking the hull....
Will be following your build JesseLee. I just ordered Bluejacket's Grand Banks Dory kit.
Want some experience on lap strake construction before starting a more challenging
model.
John Elwood
Nice going there Jesse!  What a nice looking little boat and can't wait seeing you and it next April.
I am building a Main lobster smack for that same event!
Cheers,
Piet, The Flying Dutchman.
                       VOC Ship Surabaya
                             Friendship Sloop Gwenfra
                           Muscongus Bay Lobster Smack
Piet, I am hoping & praying I will be able to make it. My chronic lyme disease makes it difficult. I never know if I will feel well enough & traveling itself makes me very sick. I am hoping for the best because I REALLY want to attend this even if I can only be there for part of one day.
Making progress on getting the hull planked. The wood strips supplied are basswood & have been bending pretty well. I have had 2 break. As I get to the point where the curving of the planks increase I have been soaking the planks. It doesn't tale much- holding it under hot water running from the sink is all it takes & they bend easily into shape.
The instructions recommend using CA glue foe everything in this build but I'm too old school & chose to use wood glue instead. I have only used CA to glue where the planks meets the stems to hold the ends down while the wood glue is drying between the plank edges. It looks a little rough right now but it will look fine once it is scraped & sanded.
Nice progress there Jesse!  I like the "state of the art" planking clamps, rubber bands and masking tape!  That's also one of my methods  :)
Let's hope and pray that this lyme thing won't bother you come April.
Cheers,
                       VOC Ship Surabaya
Been sick & haven't been in the shipyard much. Will try to post some progress soon.
Thanks for dropping in John!
Finished the hull of the boat. When I took it off the jig that formed the shape the sides wanted to pull in making it narrower than it is supposed to be. The wood was pretty stubborn being very stiff & not wanting to be pulled out to its proper shape. Thought about it a while & decided to fit it back over the jig & try to re-wet the planks to see if they would reshape themselves. It was a tight fit & had to stretch the sides open a bit to get it back on. Then I decided on something maybe a little radicle......I filled a coffee cup with water & boiled it in the microwave a few minutes. Then I pored the boiling water onto the hull hoping it would reshape itself & praying that it would not come unglued & fall apart. It worked! I let it sit overnight. The glue held & it now holds it shape much closer to how it should.
The last time I had to use boiling water was with bending the ebony wales on the longboat, of course I didn't have to worry about glue softening.
It always amazes me what you can get wood to do with water and heat.
Looking good Jesse.
Looking nice Jesse and a good safe with the hot water, well done.
Cheers,
                       VOC Ship Surabaya
Good work so far.
Regarding your hull not holding its shape when taking it off the jig, I have always added a temporary beam across the hull on the inside of the planking to keep the hull stretched to its proper breadth until I can get some framing in the hull. Once you get the side frames in there, it will stiffen up nicely and the temporary stretcher can be removed.
Russ
Thanks for the tip Russ, I will do that
Sanded the edges of the planks down smooth. Added false keel. Soaking strips, bending & gluing ribs in place.
Thanks Russ.
Getting those ribs lined up & glued in correctly isn't easy. Got them all done- they are not exactly even but they are off so slightly that it doesn't show & the rest of the construction will make it totally unnoticeable. Added breast hooks to each end. Cut out, shaped & glued on the floor planks. Now I've got the risers clamped waiting for the glue to dry.
The spacing of the frames looks good. They do not need to be or have to be exactly spaced. Close makes them appear uniform.
This hull should be stiffening up quite well by now.
The rest of the details add a lot without a great deal of effort. Nice work.
Russ
Edited by russ
Made a lot of progress. Added the seats, knees & inwales. Got the hull painting started. Started assembling the paddles.
Constructed bottom frame of the lobster trap, bent a plank around a paint bottle to make the hoops for the top of the lobster trap. Started assembly & painting of the buoy. Added a rub rail to one side. One end didn't meet the false keel like it was supposed to so I burnished the end down by rubbing it across the end of my workbench till it touched like it should. Glued hoops on lobster trap. Used an old hose sock to make the netting inside the trap. Cut out first one cut hole, sealed edges with fray check. Stretched out & glued net on.
Wow, great progress Jesse!  She's really looking VERY nice and so do the extra's.
Cheers,
                       VOC Ship Surabaya
Finished the lobster trap construction & gave it watered down grey washes to give it a weathered wood look. Tied it to the bout & added the 2nd rub rail to the boat....
Made a stand for the boat & stained it. Added the rowlock blocks & oar locks. Glued the trap, buoy & oars doen & the Main Peapod is completed.
Very nicely done. Congratulations. One of the great things about these models is that they go together rather quickly. One of the bad things about these models is that they go together rather quickly. :)
Russ
Jesse,
You did a great job building your peapod and it looks fabulous!
Dee Dee
Current Build
 - Glad Tidings -MS
Completed Builds
 - Dragon - Corel - One design International Class Yacht
 - Sloup Coquillier / Shell Fish Sloop - Corel - Based on 'Bergere de Domremy / Shepherdess from Domremy
 - Muscongus Bay Lobster Smack - Scratch build based on drawings from Chapelle's book "American Small Sailing Craft"
On the Shelf
 - Gretel-Mamoli     - Emma C. Berry-MS    - Chesapeake Bay Pilot Boat, Semi-scratch
Find yourself hoping you never reach your destination
Thanks everyone! I wanted to make it look good because this is going in the Wounded Warrior Project auction this spring.
