​Take your time and use a sharp V groove chisel The sharper the better making small light passes at first so to produce light curls of wood
Many light passes are much better than One large blunder and a trip to the wood shop for more timber
Andy
Current Build
HM Granado CC
Past builds
 HMS Chatham CC, HM Convulsion CC,  Duke William German Kit, Fair American LSS, The Wright Flyer MS
Link to comment
Share on other sites
Hi RAFTERRAT2006
It would be nice to have a name that we can call you. Thank you.
The rabbet is not a vee groove for the entire length.  It is a dynamic groove that matches the lay of the garboard strake for most of it's length.  It continues to change as it rises at the bow to match the angle at which the planking will land in the rabbet.   Near the stern it is virtually a vertical "L" shape .  As far as how to make the groove, I start with a vee chisel as described above, but for only a shallow cut.  I then go to a small, extremely sharp flat chisel to finish the rabbet.   Be sure the keel is secure on the work bench so you can control the chisel with both hands.  The attached sketch may be a better explanation.
Allan
Link to comment
Hi David:
Depending o the scale (and your commitment to accuracy), you could take a simplified approach to carving the rabbet. I usually draw the bearding line (which marks the inside edge of the planking along the keel) and then the rabbet line below it. I then score the rabbet line lightly with a #11 x-acto blade. I then use a #10 x-acto blade (the scalpel blade) to shave wood off the keel from the bearding line to the rabbet line. The #10 blade is also useful for scraping along the rabbet joint as you carve.
I was trying to post some photos to go along with this, but for some reason my uploads keep failing.....I'll try again in a bit
hamilton
Edited by hamilton
MS Glad Tidings (1937) (in need of a refit)HMS Blandford (1719) from Corel HMS GreyhoundFair Rosamund (1832) from OcCre Dos Amigos (missing in action); Amati Hannah (ship in a bottle); Mamoli America (1851)Bluenose fishing schooner (1921) (scratch); Off-Centre Sailing Skiff (scratch)
Link to comment
OK so here are some photos for you David - these show marking the bearding line and carving the rabbet on my build of the Corel Greyhound.
Here are the bearding & rabbet lines drawn at the bow
Here are the same at the stern
The bearding line is normally marked on the hull profile plan (perhaps as a dotted line on the cross section drawing) - it runs along the bottom edge of the bulkhead frames where they meet the keel. The rabbet line runs below it.
After scoring the lower rabbet line with a #11 blade, I then shave off wood starting from the bearding line until I hit the rabbet line and then scrape or carve the wood out to form the joint.
This is the finished look
Hope this helps
hamilton
Link to comment
Would it be truly insane to try to use a Dremel router bit freehand? Theoretically that would be the perfect tool, but practically speaking, one slip and its all over.
I'd be leaving that well alone Al :huh:  .
:cheers:  Danny
Cheers, Danny
Link to comment
I love my Dremel, but you have to very careful with it. It gobbles up material faster than you can comprehend it. Once the material is gone....it's gone. Good luck.
Link to comment
Dremel makes router attachements if anyone is interested, (and didn't already know).
http://www.amazon.com/s/ref=nb_sb_ss_c_0_13?url=search-alias%3Dtools&field-keywords=dremel%20router&sprefix=Dremel+router%2Caps%2C176
Reasonably priced and would give you a perfect rabbit with just a little practice.
Edited by Pops
Previous build(mostly) - 18th Century Longboat
Current build - Bounty Launch
Next build - San Francisco by AL
Future build - Red Dragon
Future build - Mayflower from Model Expo
Link to comment
Hi David, I cheat (oops perhaps I shouldn't admit that :) ) - for POB kits (as per Hamilton's post) I cut the keel away on the backbone wood from the bottom of the rabbet edge down (after marking it out of course).  I then remove sufficient wood from the rabbet area to allow for the total thickness of the planking (bevel the edge) to create the rabbet recess.  After assembling the skeleton (backbone and bulkheads) and sometimes even after the hull planking,  I fit a new keel which in effect creates the bottom edge of the rabbet for the planking.  You can include the stern post and stem in this process also if you wish.  If you do it after the planking, my trick is to dry fit the keel before planking and create a couple of alignment holes in the bulkheads which will align with pins in the top of the keel when they are finally fitted (just leave these holes clear when planking).
For me this creates a very clean edge to the planking, and if using a good hardwood, provides a better finished keel (stem and stern posts etc if all are done) in which you can add the scarfs etc-  and who can tell the difference if you don't tell them ;)
cheers
Pat
Edited by BANYAN
Link to comment
I have seen some use a razor blade to shape edges and nice cuts but I haven't been able to cut the marks on the blades very well. I've got to get the v-groove correct which I have to do this very, very cautions as not to take to much off, measure twice or even 3 or 4 times cut once.
Link to comment
Join the conversation
Guest
Reply to this topic...
  Only 75 emoji are allowed.
