Everything posted by usedtosail
I just made an edit on post 792 - it turns out the boarding steps are at the aft end of the waist not the fore end, so my carronade tackles would not be in the way of the boarding steps. There is enough bulwarks at the aft end of the waist for those tackle lines to be attached so I don't need to put those into the plank sheer.
- 1,348 replies
- constitution
- model shipways
Don't despair David, I have the same problems. Just last night I managed to pop off both trail boards at the boarding steps while rigging the carronades. Luckily for me it was a clean break. I also have been touching up the paint along the sides as I go along. I managed to drill one hole for an eye bolt clear through the bulwarks in a moment of not paying attention. But with the black paint it cleaned up nicely. I have also always had trouble drilling through planks as they want to splinter. I haven't decided if a slow drill by hand or a fast drill using the Dremel is the better method - I seem to have trouble with both. Keep up the great work you are doing.
- 117 replies
- constitution
- model shipways
Nice job on the rails David, That is one of the hardest areas I have had to deal with so far, and you pulled it off nicely.
- 117 replies
- constitution
- model shipways
Ah yes, where to put this beast. Luckily both my kids have moved out so I have access to more room in the house, but that is only temporary until we retire and sell the house. I'll ether find a place in the new house or give it away. Maybe my son will have a house of his own by then.
- 1,348 replies
- constitution
- model shipways
Thanks John. Welcome to the build. Sorry if you had other plans for the day. I hope you do decide to build this model someday as it will keep you busy and is very satisfying. The Niagara looks like a nice model too.
- 1,348 replies
- constitution
- model shipways
David, I just had a chance to look at your log, and you are doing a fantastic job. I started with the first chapter of the Hunt practicum which did help me out to get started. Keep up the good work, but as JS says use it with a grain of salt.
- 1,348 replies
- constitution
- model shipways
David, you are doing a fantastic job. I will enjoying following along.
- 117 replies
- constitution
- model shipways
Thanks Greg. Thanks George. I am trying to break up the repetition by assembling and rigging 4 carronades at a time. That way I have a variety of tasks for each one before repeating on the next group. Sal, your Syren is looking great. Ratlines are another of those repetitive tasks that you can't wait to be finished with. Yours are looking great. Welcome David. Thanks for the compliment. Do you have any pictures of your build? I would love to see them. Are you following the kit or making changes/additions as you go?
- 1,348 replies
- constitution
- model shipways
I have used thin CA to fix a few spots on mine. I have not had widespread problems with tiles not sticking, though, usually they stick very well. I do prime the wood under the tiles and I don't cut off individual tiles, which are hard to remove from the backing. On a strip of copper tape, I cut through the copper for each tile but not through the backing, then I can remove just the copper pieces from the strip of backing more easily, leaving the copper tiles nice and flat.
Thanks Tim and Al, and for the likes. I finished assembling and rigging the four carronades on the fore part of the spar deck, before the waist. I first just put one set of side tackles on to make sure I would have enough room for two on each side without it looking too crowded. I glued these tackle lines to the deck and trimmed them, to get them out of the way. You can see that for the two carronades right next to the open waist, I had to add the eyebolts into the planksheer since there is no bulwark there. Now the side tackles wouldn't be there most of the time, but in hindsight I probably should have moved that gun port a bit forward so I had more bulwark on that side. Oh well, can't change it now. I then added the outer sets of side tackles. I was able to fit them all in, so I am pleased with the result. I have glued these second tackle lines to the deck but have not trimmed them yet. I also still have to add the rope coils, so I started the production line for those. 20 carronades, four side tackles each, four rope coils each = a butt load of work left to do . Here is the view from outside the hull. I still have some paint touch up to do on the carronade barrels, inside and outside the hull.
- 1,348 replies
- constitution
- model shipways
Sorry for the long time between updates, but I have been busy with work and school vacation last week. I have started assembling and rigging the spar deck guns. I am starting with the two long guns and four carronades at the bow, to see how these will look with all the rigging before continuing on with the guns after the waist. I assembled and rigged the two long guns first, since these were very similar to the guns on the gun deck. I still have to tighten up the side tackles and secure the ends to the deck. I then drilled holes through the carronade sleds and bases, into the deck, and secured a piece of wire to hold them in place. I then assembled one carronade, first by seizing a ring bolt to the end of a piece of line for the breeching rope, threading that line through the ring bolts on the sled and the ring on the barrel, then seizing another ring bolt to the other end. I then glued a brass screw in the hole I drilled into the casabel, and glued the head of the screw and the barrel trunnions to the sled. I finished it off by gluing small strips of black paper over the trunnions. Here it is placed on deck. I am in the process of making the four tackles needed to rig it. I have started to assemble the second carronade and the production line of stropping hooks to blocks for the tackles. Here are all the gun carriages on deck ready to be assembled and rigged.
- 1,348 replies
- constitution
- model shipways
Thanks Gerty, welcome to the build. Everything is now painted and I have started the assembly of the guns. For the cannonade bases, I first installed the brackets that will hold them to the gun port sills. I made up a little jig to help me get them all the same distance from the front of the bases. I could have made it more elaborate by adding guide pieces to the sides of the brackets but this worked pretty well as is. I decided to add a small block of wood in the slots of the bases, so that I could put a wire pin through the sled, base, and into the deck, to hold the whole assembly in place. I also made a replica of the area around the spar deck gun ports to help in the assembly and rigging, like I did for the gun deck guns. Assembly of the long guns and cannonades is next up.
- 1,348 replies
- constitution
- model shipways
Hi Greg. For the width, I either use an X-Acto knife first than a sanding block or if the taper is slight just a sanding block. For the thickness, I used a sanding block, working from the end that is the same thickness as the upper planks, to a reasonable way back to the full thickness.I think it was near the last bulkhead or so. After all the wale planks were added, I evened up the thickness again with a sanding block until they were all the same.
- 1,348 replies
- constitution
- model shipways
Thanks George, Al, and Popeye. It is not too tedious yet George, as there are lots of different things that need to get done, all be it 20 at a time. I am glad to see you back Al. I hope you get right into where you left off. I finished making all the hooks and ring bolts, and added the ring bolts and eyes to the sleds. I need to finish painting the barrels and trucks before I can continue assembling the carriages. This is my last week home before I start a new job on Monday. It has been fun having time to build during the day, but after this week it will be back to nights and weekends in the workshop again. At least for another 5 years or so.
- 1,348 replies
- constitution
- model shipways
Congrats for a job well done. She looks great in the case.
- 456 replies
- finished
- bomb ketch
Thanks Popeye and the likes. I continue to build the pieces parts for the spar deck armament. I finished the cannonade sleds and cut the brass screws to size. I made up a small block with a hole in it that i put the screws in then cut them flush with the block, to get them all the same length. I cleaned up the metal barrels and trucks to remove the flashing, and made the two quoins for the long guns. I assembled the long gun carriages. I mixed up a new batch of bulwarks red paint for the carriages because the batch I used on the gun deck went bad. I think it is a close match. I painted the carriage parts with it and the wooden trucks black. I cleaned the metal parts with white vinegar and blackened the brackets and brass screws. I need to touch up the brackets with some paint because of the CA glue that covered some of the brass. I still need to paint the barrels and metal trucks. I am also in the process of making all of the small parts I will need for rigging the guns, like 170 hooks and 88 ring bolts.
- 1,348 replies
- constitution
- model shipways
Cutty Sark by NenadM
usedtosail replied to NenadM's topic in - Build logs for subjects built 1851 - 1900
You can get microballoons at boating supply stores like West Marine.- 4,152 replies
- cutty sark
- tehnodidakta
More work on the carronades. I am making the sliding part of the sleds again using pieces cut from some sheet wood and some square stock for the supports to hold the trunnions. I will file slots in these when the glue dries. You can also see the brackets I made. These will support the base in the gun port. I made them from some flat brass, then glued a small piece of brass dowel to look like the top of the pin. I should have drilled holes in the gun port sills before putting the rail on so I could actually pin these in place, but it is too late now. I will pin the bases to the deck near the gun ports, though, which will hold them in place. You can also see the new screws I ordered - flat heads and a little shorter than the ones I showed earlier. I am going to use the supplied trucks, but I am using the front trucks in the back of the base. The supplied rear trucks I am not using, as there will be no trucks in the front of the bases.
- 1,348 replies
- constitution
- model shipways
Well said Frankie.
Thanks Steve. It has been great this week to have a lot of time to work on it. I am deviating again from the supplied parts, this time the carronades. On the tour of the Constitution that Popeye2Sea gave me, he pointed out how the current carronades are not that authentic and should look like these with an elevating screw. So, I took inventory of the supplied parts and decided I couldn't use the sled parts as the slot is too wide and they are too boxy, and I am not using the forward trucks because these sleds are pinned to the gun port sill and don't have trucks in the front. I will use the rear trucks, after I clean them up a bit. I can also use the barrels, but with a modification. I filed the casabels to be flat on the top and bottom, then by hand drilled holes through them for a small brass screw. These screws are 1/2" long, but I don't have enough of them so I ordered some 3/8" screws that I will use instead. They are size 00-90 diameter. I also ordered flat head screws instead of round head. I don't think I am going to drill through the screws at the base for the turning rods, as that is just too small for me. I also am making new sled parts, starting with the bases. I cut rectangular pieces to start with, then milled 1/8" slots down the center. By now you know I have an X-Y table on my drill press, which I used for this process with a 1/8" end mill bit. The X-Y table is one of the best tools I have and really makes the drill press so much more versatile. It is not the best mill though because the head turns as the height is adjusted, but I have marked the center point on the column and head so for this kind of work I can get it pretty close to square. After all the slots were cut, I rounded the ends and sanded them smooth. The mill bit did such a nice job of cutting the slot, I had very little sanding to do in them. After these I will make the slide part of the sleds.
- 1,348 replies
- constitution
- model shipways
Thanks George and Greg, and the likes too. Greg - there were enough horizontal lines between the white strip and the planks that I could keep them level by eye. I was going to put another strip of tape down the other side before I started gluing them, but found it worked out better for me without it.
- 1,348 replies
- constitution
- model shipways
