Posts posted by popeye2sea
On Naval vessels (modern) the bitter end of the anchor chain is shackled to a pad eye in the chain locker. I can't imagine that it would be left loose on any vessel. If it was ever to let loose and run free it would be too easy to lose the entire thing overboard. The last fathoms are painted red so that you know to set the chain brake soon or you are going to lose it.
The term applied to all the serving material that I have seen refer to " twine". So we are talking about small stuff. Seizing in my book would be made with somewhat thicker stuff
Incidentally. the Constitution pic shows what seem to be webbing straps - not something I have seen before - can anybody enlighten me on that subject ? Are they fastenings for a cover of some type?
Spyglass, the web straps are gripes for the boats. They hold the boats in.
As I mentioned before, the stern of this kit is a series of difficult fitting jobs. The stern balconies were fitted in the order of lowest to highest. The balconies were aligned as well as possible using the side profiles as a guide so that they match up to the quarter galleries. Then the brackets were added to the undersides. Any filling that was necessary was then done followed by touch up painting. The carved pillars were added last followed by more touch up paint. I had to add some height to the carved pillars between the second and top balcony by using some strip styrene shaped to form a continuation of their pedestals. The large figures on the sides have no real attachment points so finding out where they actually come in contact with the various surfaces to prepare them for glue was interesting. Those contact points are rather small, hopefully they will adhere well enough. There remains to be added two reclining figures on the taffrail and the stern lanterns in order to complete the stern. I have to wait until the poop deck is in before I can finish.
Overall, I am quite pleased with the result.
Thanks for looking
Regards,
Although it is a hazard to the crew there is nothing I can do about that loose cannon. And I am not about to go jiggling the model upside down on the hope that it falls out through a ladder well. But now people can actually call me a loose cannon
Interesting development last night..... I noticed that one of the cannons of the second battery had been knocked loose in the fall. It is now rattling around inside the ship - inaccessible. The only way to remount the gun is through the gun port. I had a few spare cannon assembled and painted from when I was working on that deck, but obviously it would not fit through the port. I dismounted the gun and took off the wheels. That gave me the clearance through the port. Then I made up the height difference by making a platform out of sheet styrene, inserted through the port and glued to the deck. Next came the gun carriage through the port and glued to the platform. Finally the gun was remounted through the port.
The whole procedure reminded me of playing the game 'Operation' when I was a kid.
Thanks for looking in on the build.
So...I was filling and painting the transom last night and the ship decided to slide down the ways on it's own and fell to the floor. (insert appropriate language here) The stem and figurehead broke off and the bowsprit was loosened, but intact. After re-entering the yards for repairs the stem and figurehead were repaired with no ill effects. I found, however, that the bowsprit had sheared off its step and would not re-seat. The beakhead bulkhead had to be removed to provide access to the step and a new one was fashioned to hold the foot of the bowsprit.
I am happy to report that after a few hours of repair work everything is back to shipshape.
- FrankWouts, Hubac's Historian, lambsbk and 1 other
- 3
- 1
The stern on this kit does not go together very well. The alignments are off and very difficult. Once the quarter galleries and the lower stern balcony are affixed and lined up as well as possible there are still large gaps at the top of the transom and around the edges of the quarter galleries.
Contour putty filled the gaps.
Very nice work Henry :-)
If you did not do all the carriages yet: It also is a further improvement, if you change the position of the wheels and axles a bit. The front one more to the front, the aft one more aft. Also the trunnions of the barrels could be moved to a correct more backwards position.
Is the big ring in the middle for the breeching rope as this one runs through the middle of the carriage??
Daniel, yes the carriages are all made. I can still move the trunnions back a bit on the barrels. The eyebolt on the sides is for the gun tackle (it looks big in the picture). I have a hole drilled into the carriages for the breeching.
The upper sides have been fitted to the hull. Still have to set and bend over some eyebolts for the chains to fasten to. The bent over ends will fall into the gap at the bottom of the upper sides. Then I will fill in the gap with contour putty.
My thanks to HistoryGuySteve for the suggestion on fixing the dullcote dissapointment. Your solution worked well.
- Hubac's Historian, lambsbk, NAZGÛL and 2 others
- 5
The Description reads that the deck plan is of the vessel Sir Lancelot. Also vessels Norman Court, Cutty Sark, Eliza Shaw, and Belle of Lagos
Here is the product of all the hard work of the smith. All are made from 28 gauge steel wire blackened with Blacken-it.
The small rivets/nails are not blackened yet. I am waiting till I get a pile of them made. They will be used to represent the bolts that hold the gun carriages together.
I may be going a little overboard with these bolts. Each one is peened by hand and I am putting 8 on each gun carriage. The hooks and eyebolts were easy by comparison.
I must be crazy....that's what the Admiral says
What about spars? I will be replacing the plastic ones for my Soleil Royal kit.
Your cannons look superb. I know what you mean about a lot of love and determination. I figure it's all part of the learning curve. If I can make 2mm blocks and rigging look good It will be easy for the larger sized rigging. My cannons should be completed in a few days. Then I can close up the decks and move on to the stern galleries and transom.
Thanks for the compliments. The putty for the molds is from Castin' Craft. It's called Easy Mold (item # 33700). The casting resin is from the same company, called Easy Cast (item #33008). Both are very easy to use.
- Hubac's Historian and Fright
- 2
The blacksmith forge at the shipyard is working overtime making hooks, eyebolts, and ringbolts for rigging the cannons. The riggers (unfortunately they are all neophytes and apprentices) are working out the proper ways to rig everything in ship shape fashion.
Here is the latest:
Breeching Rope with ring bolt
Thanks for looking in.
- Hubac's Historian, Fright, tarbrush and 1 other
- 4
I think I am going to go with a short piece of thread (not scale rope, too expensive to use for this purpose) with an overhand knot. The knot to be hidden at the base of the block between it and the strop. The tension of the strop against the block should hold the knot closed. That will allow me to use a becket bend to properly fasten the standing part of the tackle to the block.
Perhaps with the larger blocks I'll try a proper grommet for the becket, but for the 2mm blocks it's just too much effort.
Do I see a ring on the lid, directly opposite the stand behind the object which looks like a convenient place to fasten the open lid to.
Mast Tackles were rigged to hoist cargo and gear into the ship. The pendants on the fore mast and the main mast would be connected by a runner so that the tackle fall would hang over the main hatch. Yard tackles would also be employed to swing the cargo over the side and lower away onto the pier or boat alongside.
The burton tackle is just the name given to the mast tackle on the mizzen.
USS Constitution by CaptainSteve - Model Shipways - 1:76.8 scale
Steve,
Sorry for the long wait on this reply. Here is what I understand is a history of the ships configurations.
As built Constitution had open rails ( no enclosed gunwales) from abreast of the foremast to the taffrail with stanchions defining the gun ports on the quarterdeck aft of the main mast. The line of the cap rail did not follow the sheer line, it had a flatter appearance. Her bowsprit was steeved higher than it is currently. She had open head rails and ornately carved trailboards with a figurehead representing Hercules. She was pierced for and carried 30 guns on the gun deck and carried 14 carronades on the quarter deck (rated as a 44). The carronades on the fore deck were added later bringing her war of 1812 armament to 50 - 54 guns (including bow chasers). The transom was ornately decorated and had 5 windows
I believe that the first Corne painting that you posted depicts this configuration.
Sometime around 1802-1803 Captain Preble was fitting out for her Mediterranean cruise and it is at this time that the section of rail aft of the mainmast was closed in by a solid gunwale.
After a collision with President in the Mediterranean on Sep 12, 1804 Constitution lost her jib boom, flying jib boom and part of her bowsprit. Also lost were her figurehead and parts of her cutwater and head rails.. Repairs in Malta were functional only and her bow has never looked the same since. She received a billet head in place of her figurehead and the trailboards and head rails were not restored to her original appearance. The head rails were still open during the war with Britain. Subsequent overhauls and repairs would gradually alter her bow appearance to what it is today.
During 1812 Captain Hull opened three gunports in the upper transom (above the windows) in order to fire stern chasers at the British squadron.
The second Corne painting you posted shows this configuration.
During a refit in the 1830's the sheer line of the gun and spar decks was lowered aft of the main mast. 2 1/2 feet in height was added to the bulwarks from the main gangways aft to the transom. The fore mast was shifted 2 feet aft and its rake was increased 2 1/2 degrees. The main mast was shifted 2 feet forward. The mizzen was shifted 13 inches aft. The rudder port was lowered and the rudder head moved forward. A dog leg was added to the tiller to clear the deck beams of the lowered gun deck. The transom was moved slightly aft.
During her conversion to a school ship for the US Naval Aceademy in 1858 two of the windows of the stern were filled in
