Landlubber Mike
Posts posted by Landlubber Mike
  1. Mike, the Badger was my first ship.  If I can do it, you can do it :)
    You don't need all the running rigging if you use furled sails.  I did the clew lines, buntlines and sheets.  The leech lines would be hidden I think, so I didn't bother with those.  There may be another set of lines that I also didn't add.  The clew lines, buntlines and sheets should be in your kit plans for the masts.  The bowsprit takes a little more work with the jib sails, as you need to add jib stays and halliards.  You also need chocks, a jib traveler, suitable belaying points.
    Take a look here - this might help:
    http://sailing-ships.oktett.net/square-rigging.html
    Good resources are Lees "Masting and Rigging" and the TFFM volume 4.  I recently bought Marquardt's "Eighteenth Century" book which also looks pretty good.
    Hope that helps.
  2. Ian B, I hope it helps.  I had searched but really couldn't find too many in-depth sail tutorials, so I thought I would share my approach.  I think sails, furled or not, add a very nice look to the model and are well worth the extra time.  I'm probably going to go with a mix of furled and unfurled sails on my next builds, as you are thinking - just be aware that if you are using full sails, there are a number of other lines that may need to be installed.  If you come up with new techniques, feel free to share them on this thread - I'm always looking to improve my work.
    Good luck!
  3. After spending a little time on the plans, I'm leaning heavily towards building this kit as the Lyme rather than the Unicorn.  I like the stern area a lot better.  The windows make a little more sense, as opposed to the Unicorn with what looks like cathedral type windows.  The transom decorations are a lot nicer to me as well, though I was hoping that human figures weren't part of the decorations  :huh:  And, the quarterdeck portholes and railings make a lot more sense to me than the Unicorn's open portholes in the Chapman plans.
    This means that I'll need a new figurehead, as the Lyme had a lion figurehead.  I might try carving or sculpting one, but I'll probably buy the figurehead for the Euromodel Mordaunt just as backup.  Ron's Ardent uses the same figurehead I believe, which I think is pretty nice:
    http://modelshipworld.com/index.php?/gallery/image/8226-arbowdetail01lr/
    I'll sleep on it a couple more days before making a decision on what ship to build.  Maybe wait for Ian to get back from his vacation so I can pick his brain as well  :rolleyes:
  4. The Lyme plans from the NMM arrived!  Like the Pegasus plans that I ordered a few weeks ago, these plans are gorgeous and show a lot of detail.  I ended up ordering J8267 and J6152.  Each seemed to have very different details that would be helpful for the build, so I figured that I would buy both - and I'm glad I did.  Not the cheapest transaction, but well worth it for the detail, and I can frame J8267 after the build is completed as well :)  You can find both sets of plans at the following links (note:  I only found the second set of plans by scrolling through the NMM catalog for 18th century ships, you can't use the simple search function to locate them for some reason):
    http://prints.rmg.co.uk/art/494855/Lyme_1748_alternative_spelling_Lime
    http://prints.rmg.co.uk/art/533689/Lines_and_profile_plan_of_Lyme_1748
    Here are some pictures in case folks are interested:
    J8267:
    J6152:
  5. Mike, if you're thinking about furled sails, I set up a separate thread/tutorial on what I did for my Badger.  Maybe this can be of some help:
    http://modelshipworld.com/index.php?/topic/3944-landlubber-mikes-technique-for-furled-sails/
    Sails are a personal decision.  There are the purists who leave them off because of scale.  For me, these are sailing ships and like someone said here once - a ship without sails is like a car without tires.  In any event, good luck with whatever you decide.  Adding sails added considerable time to my build, but I really enjoyed the process of going through and learning what all the lines, etc. were for.  It gave me a greater appreciation for these gorgeous ships.
  6. Hi Martin,
    Yes, the extensions are going to be a pain.  I agree that the planking goes between the bulkheads and doesn't cover them.  I'm thinking that it might be easier to cut the extensions out now and install new ones, rather than wait until later.  Are you going to replace yours?
    Boxwood is very nice :)  Maybe I'll go with pear as the wood of choice on the Unicorn, and boxwood for this build.  The only issue is that boxwood doesn't take stain very well, so I would probably need to use pear for the black items.
  7. That's very interesting SpyGlass.  It almost looks like the blonde 5mm sheet (I don't think it is ply) that I got might be for the Fly (assuming that the Pegasus and Fly have the exact same parts).    The quality of the 5mm sheet looks very good relative to the other two types of ply sheets.  For whatever reason, I think the other ply sheets are all 1.5mm thick - makes me wonder why Amati mixed and matched color tones with my kit?
    Looking at your last picture, I'm surprised how well the colors matched up.  Tonight I will put the planking strips against the 5mm sheet.
    By the way, the MDF keel, lower deck and bulkheads fit together like a glove.  I dry fit the assembly last night, and I almost feel like I can dry fit the bulkheads and glue the lower deck on top and call it a day - the assembly really fit perfectly and solidly, almost to the point that you don't need any glue at all.
    One thing I'm beginning to realize might cause me some angst in painting with wood is dealing with the bulkhead extensions.  I am going to have to cut them off at some point and replace them with different wood.  The question is whether to do that now, or wait until after the exterior is planked and then break off the extensions and replace them.  I'm thinking that the first option would be easier in the long run.
  8. Thanks very much guys.  I took a closer look at the walnut strip last night, and it actually looks pretty good - much better quality than the walnut strip I used on the Badger.  Since I plan on coppering the hull, I can select the strips I want for the upper hull so the variation is less of an issue.
    What is annoying is that the 5mm sheet (upper left corner in the first picture) contains the stem post and rudder, each of which have exposed wood sections that won't be colored or coppered.    The wood is so blonde, that it would need to be replaced.  But in replacing it, I might then need to replace the upper hull planks so that there is a match.   :angry:
    Thanks very much for the kind words Clare.  I agree that pear is very nice!  I'll have to look up your Higaki Kaisen - did you post photos of it?
    BE, thanks for your thoughts.  It's good to hear that the walnut held up well.  The strip wood looks very good in my kit, so maybe I'll just stick with it and replace the walnut pieces on the sheets that are the off colors that I intend to leave natural.  I'm still working out the color scheme on the masts.  I'm thinking of maybe using boxwood for the lower sections and maple for the upper sections.  It looks like the lower masts on the ship might have been painted yellow, so boxwood might work out nicely.  The alternative would be to use walnut or pear (whichever is used for the upper hull planking), and then maybe maple for the upper sections.
  9. If you wrap it around your finger, the coils will start out way too big.  That's why I used a pin when making my coils.
    In terms of the tie offs, I think you have to remember that for running rigging, the line was a working line so I imagine that you would want extra line so that you could properly secure it, have extra lengths for when you need to release the line, etc.  That being said, I think I tied off some of my rigging to the strops at the mast tops.
  10. For people thinking of the Pegasus, here's an idea of the color variation in the kit walnut:
    Variation is fine if you are painting or otherwise like that sort of thing, but if you are trying to go with a matched natural color, it is a bit problematic.  Hence my dilemma of what to do.  I might see if when dyed/stained black, the walnut all takes the same color.  If that's the case, then I probably won't have to replace as many of the parts.
  11. Ugh, that's disappointing to hear Spyglass.  Maybe I just need to plan to replace all the walnut.  I was hoping I could get away with dying/staining the black stuff and it would be fine, but maybe I should plan to scratch the various items.  I was hoping to avoid that, but since I didn't pay retail for the kit, I don't feel as bad replacing the kit wood.
    Jeff mentioned that some folks might not like the look of a tight grained wood like pear or boxwood against a loose grained wood like walnut.  I didn't really consider that, and maybe I should just stick with pear.  I was thinking of doing something a little different than the Unicorn, but it's really hard to beat pear for  color, grain and workability.
  12. I've been giving the wood/color choice some more thought the past couple of days.  I've been trading emails with Jeff at Hobbymill, who has been incredibly helpful and generous with his time.  I mentioned before that my Unicorn will be primarily pear with boxwood decks and accents, so I'm looking to go with a different scheme with the Pegasus to keep things interesting.
    I'd still like to go on the darker side, so I think I'm going to stick with walnut as the primary wood for the model - hull planking, deck items like hatch coamings and companionways, etc.  Given the large color variation and structural issues with the walnut ply in the kit, I'll probably just replace some/all of the kit wood with walnut from Jeff.  As for the deck, after seeing this picture of Jeff's walnut against Jeff's maple from Len's Bellerophon log, I'm sold on maple for the decking:
    Other colors and wood choices:
    -- boxwood will be used for some of the rails, and likely some of the accents.
    -- I'm still deciding on whether to go with red for the bulwark planking and some of the deck items.  If I do, I think I might try using redheart, which looks like a gorgeous wood.
    -- rather than painting the photo-etched windows white (I'm not a fan of white paint on models), I will probably replace them with scratch built windows made of holly, and use holly for the planking on the small boats as well.
    -- the photo etched decorations will be painted in a burnished gold/bronze color.
    This brings me to the masts.  Does anyone have any suggestions on what I could use?  With the wood I'm planning to use, I think I have four options:
    -- walnut for entirety of masts
    -- walnut for lower sections, maple for upper sections
    -- walnut for lower sections, boxwood for upper sections
    -- boxwood for the masts, with maybe maple for the upper sections
    I'd like to stick to these woods just to keep a consistent color theme.  I'd very much appreciate any thoughts or other suggestions. :)
  13. While waiting for the Lyme plans to come from the NMM, I've been giving my color/wood choices for the build some more thought.  I've traded a few emails with Jeff at Hobbymill, who has been incredibly helpful and generous with his time.  Here is where I am at the moment:
    -- my primary wood on the model will be pear.  The keel, rudder, stern post, and stem, as well as the hull planking, will be in pear.  The wales, black planking, black background on the transom, and spars will be ebonized pear.  Some of the deck fittings, like the hatch coamings and companionways, will also be in pear.
    -- I plan on using boxwood for the deck planking, accent rails on the hull, and possibly some of the decorations and stern carvings.
    -- for the bulwark planking, gun carriages and maybe some of the deck items like the bitts may be in red.  I was thinking of using red stains to achieve this, but after seeing Rusty's cross-section, redheart looks like it could be a real winner here (tight grain, and apparently relatively easy to work with).  That would mean scratching the gun carriages, but there are only 24 of them on this ship so maybe not such a big deal  :huh:
    -- for the masts, I haven't figured that out.  Pear would be a nice contrast with the boxwood deck, and would tie in with the rest of the build.  Do folks think that pear would work?  Or would boxwood be better?
  14. Hi John,
    To add to the confusion, Le debutant (first link below) and Ollyweb (second link below) built the kit with the bowsprit following diagram 1, while the gentleman who scratch built the Unicorn (third link below) has the bowsprit following diagram 3:
    http://modelshipworld.com/index.php?/topic/6223-hms-unicorn-by-landlubber-mike-corel-scale-175-1748-1771/?p=180937
    http://modelshipworld.com/index.php?/topic/4326-unicorn-by-ollyweb-corel-upgrade/?p=222408
    http://modelshipworld.com/index.php?/topic/6223-hms-unicorn-by-landlubber-mike-corel-scale-175-1748-1771/?p=193080
    Here's a link to a website that has completed models for sale.  One of the ships is the Unicorn, which is almost guaranteed to be the Corel kit (and the builder has the bowsprit following diagram 1):
    http://www.modelships.de/Verkaufte_Schiffe/Unicorn,_Fregatte_1/Photos_Frigate_Unicorn.htm
    For the three NMM models, two things to keep in mind is that they predated the Lyme class (1741, 1745 and 1710, respectively) and that the Lyme class was based on the lines of a french vessel.  Maybe the french had the bowsprit oriented into the bulkhead rather than the deck?
    Using the NMM online plans for the Lyme and projecting a rounded bow, I think my bowsprit is in the right location and orientation.  If I decided to go with the Unicorn, I probably will build out the front bulkhead to extend the forecastle (which would push me further into diagram 3).  Extending it 9mm may be a bit much, as the beakhead deck would shrink by a third, but maybe that is appropriate.  That should be relatively easy, as all I would need to do is add plywood to the front of bulkhead 1 (which I could base off of the templates for bulkhead 1).  Then, depending on where the bowsprit should enter the bulkhead and/or deck, I could raise or lower the deck appropriately.  It will be interesting to see what the Lyme plans show, thought now that I think about it, with the rounded bow the plans might not be all that helpful.
    Nice work on the shifting of the quarterdeck.  Look forward to seeing how it all comes out.  I also like the railings/gun positions in the second frigate as well.  Just out of curiosity, I guess that means that you wont include the portholes?
  15. It looks like the guy here at the 1:30 mark is using the gizmo on his hobby table saw:
    So it looks like with the 1/8" attachment you can cut very thin stock down to 1/8"/3.12mm.  That seems like it would work very well for cutting most scale planks in our hobby.  It's not cheap, but I might give it a try.  Working with the table saw really makes my back end pucker up, so this might help for most table saw jobs.
  16. John, sorry to have not seen your post until now.  For some reason the notifications function for new posts on builds I'm following doesn't work. :(
    I'm actually even sorrier for seeing your post now, as this brings up a traumatic memory of when I realized the discrepancy one late evening a few weeks ago.  Ian had pointed it out, but I think I didn't fully appreciate what he was getting at at the time.  But, this was particularly highlighted when I realized by trying to place the keel and bowsprit on the two main plans that the plans are not consistent and that there was a question of the bowsprit orientation/location (though, I think Corel has the angle of the bowsprit correct).
    The short answer is that I don't know whether the bowsprit on beakhead ships goes fully through the beakhead deck, the bulkhead, or somewhere in between, as my research from books came up empty.  Corel seems to be at diagram 2.  As Ian points out, moving the bulkhead forward would put the arrangement closer to diagram 3.  Chapman seems to have the bowsprit fully through the bulkhead as in your diagram 3, though it's hard to tell with the headrails in place.  On the other hand, if you take a look at my log at post 118 (linked below), I think the beakhead models suggest that the bowsprit is going fully through the deck as in your diagram 1.
    http://modelshipworld.com/index.php?/topic/6223-hms-unicorn-by-landlubber-mike-corel-scale-175-1748-1771/?p=208269
    What I did was closer to your diagram 2, which even when the deck and the bulkhead are planked, the bowsprit will intersect both the deck and bulkhead.  Without really thinking that Corel could be incorrect (shame on me), I lined up the keel with one of the plans, lined up the bowsprit, drew a line into the keel and noted its intersection, and shaved off that corner on the keel.  From a structural standpoint, I wonder if that configuration would have been very stable.
    I probably have a few more options than you do given where I am with the build, but I'll let you know what I'm thinking.  Of course, I'm a bit stuck now that I glued on the stem extension onto which the bowsprit rests.  If diagram 3 is the right answer, I can build a new bulkhead one to push the forecastle a little more forward for consistency with Chapman as Ian points out, and I can drop the beakhead deck a bit so that the bowsprit sits fully above it where it enters the new bulkhead.  If diagram 1 is correct, then adding a new forward bulkhead is probably not an option and I don't think I can move the deck higher or bowspirit forward, so I'm probably out of luck.
    Of course, all this discussion is moot if I decide to build the Lyme, which has a rounded bow  :rolleyes:  In any event, I should have the Lyme plans in next week, and hopefully the bowsprit location will be clear on the plans.  I'll pass that info along as soon as I get it.  By the way, for what it's worth, I was planning on locating the fore mast a bit forward of where it is on the Corel plans to get closer to Chapman.
