Posts posted by MEDDO
Its been shelved for a couple years now but I also remember a bit of asymmetry with the bulkheads. The LSS practicum helps a lot with those types of things but it does deviate from the kit supplied instructions quite a bit.
Michael, I will keep that in mind when I start a PoF build down the road. I may try to find one of these Halifax kits out there if they still exist.
There is probably one somewhere on a a shelf or in a closet someplace.
The Constitution is in my queue so i will be following along with ya here. I had started this using the LSS practicum but it met an unfortunate accident and I need to try to rehab the hull a bit before starting again. I think someone in the "yellow stripe" thread mentioned something about a pending renovation that might change the number of stern windows. I am interested in what will come.
That's a fantastic looking bow on your Halifax. I've a question for you though... I'm not completely familiar with frames for fully framed ships so what are the little squared off pieces of wood on each frame by the keel? Will these get sanded away eventually?
Yup all of these are going to be sanded down eventually. I think they are there to add "bulk" in the manufacturing/cutting process so there is less risk of accidentally breaking off a point or breaking a thinner piece. Its always easier to take a bit off than to put some back i guess.
I don't know about that specific brand of paint but I have buffed with 0000 steel wool to dull the finish a bit. Sometimes that works a bit.
Nice recovery there Michael and a great looking build,
Great catch! The joints even look better than before.
Yeah, great catch there Michael, and even better recovery. Looking good!
Thanks everyone! This is such a learning experience. I am glad I found this site again. I think looking though so many logs here has helped me with my "right/not-right" eye.
The Search for Speed Under Sail and The Baltimore Clipper, It's Origin and Development both by Howard Chapelle have a good bit about American Privateer craft.
Not a book, but the April issue of Naval History has a focus on War of 1812 privateers.
I just received my copy of The Baltimore Clipper today from amazon. So far it looks very interesting. Will look up the Search for Speed when I get a chance.
Ok, first major mistake! I was looking forward to placing the half frames on the stern area and I kept coming back to the area just posterior to the last full frame. Something didn't add up. After going back to the plans and going over some photos in the practicum I finally noticed what I had done. Apparently when build up the stern post I had switched the 'deadwood' (term used in the practicum) around. Having switched this "around" I had inadvertently left a gap between the deadwood and the rest of the keel. You can see this in my previous photos as well as here.
So I used some 91% isopropyl alcohol to soak into the glue joints and was able to debond them.
Unfortunately I did break a very small piece of the sternpost off.
It was then a simple matter of letting them dry, sanding and fitting the pieces back together.
Welp, you live and learn. I think it looks pretty good for a redo. It makes more sense as well.
- Elmer Cornish, gjdale, WackoWolf and 6 others
- 9
For an unstinted deck I have used a pencil on the the edge and for a darker stained deck I used a black sharpie pen on the edge. Both came out pretty well.
I always thought this would be kinda cool to do, but not sure if there is any place to sail near me.
Very nice build so far. Will be following along, interested to see the rigging go up.
Actually the poly is more for the sides of the frames as once they are installed there is a really small area to work with (only 1/2 cm or so between the frames) if I was to do that later. Also now when I am sanding/fairing the inside and outside of the hull I can see exactly where I have sanded as the poly does sand off nicely. It can be reapplied after fairing and is no problem blending into areas which were previously poly'd.
I did just a few passes with the sanding stick on the second frame here and i think you can see in the picture where the poly was sanded off versus the area where it was still present.
Oh My! The close up pictures really shows up the gaps and scratches....
- fnkershner, Elmer Cornish, Mike Y and 3 others
- 6
I also have the LSS kit bash Rattlesnake in my queue. I love seeing this. Keep up the great work.
If you want to do a scratch build, The Lumberyard has the plans and the wood (of your choice) for the Halifax.
I wonder if Bob Hunt still has the rights to his course for this ship.
Eventually going to proceed to scratch building. The plan is to do a few kits then maybe heavily bash a kit then move to a Lumberyard timbering set. Eventually moving to a scratch built section then a full scratch build...... (It will take a few years)
- Mirabell61, Aussie048, dgbot and 2 others
- 5
I think you are lucky to have that kit. The company that took over producing these kits ( royal shipyard ) was not continuing with them unfortunately.
I know I should of bought all the other ones when I had the chance. Luckily I have a Fair American on the shelf waiting.
- mtaylor, fnkershner, Elmer Cornish and 1 other
- 4
I have always used old t-shirts for the wipe on poly. (I basically have a lifetime supply from my time in the military). They seem to work great and don't ever produce the "fuzz".
Constitution by patrickmil - Model Shipways - 1/76th
That's a picture of the Pride of Baltimore II. I have been gravitating toward the smaller ships recently. The Niagara as well as the Syren are on the "way future build" list. I really like the schooners as well as the single decked warships.
I assume many of us have the same disease/problem.... As soon as I finish the Halifax then onto Pride of Baltimore II then I can fix/complete the Constitution then goto the Rattlesnake then the Fair American then the..........haha
A lifetime of building ahead...
