Everything posted by clearway
I find it can take upto 2-3 years to fully finish a ship of this size depending on how many hours a day you can put in. My billings cutty sark took about 3 years (with large gaps due to other models and family commitments) but i also altered and added a lot of alternate or scratchbuilt fittings. Keith
- 413 replies
i purchased the billings cutty sark in 1996 and that still had die pressed ply and seperate fittings, but i bought the st. roch a little later and that was laser cut with fittings included. The kits do take a bit of work and refinement but do lend themselves to improvement/ alteration easier than some other manufacturers. keith
over the bank holiday managed to get the gunports cut to approx size (will be opened out fully later) ,got the gun carriages made and started sanding the hull. even though i'm modelling the lids closed i couldn't resist! will paint them matt white then stain and varnish them. primary rough sanding completed- will use fine grade from now. P.V.A'd all the hull below gunport level to help bind the planking together- this did lead to fun when sanding back though! Keith
looking good m8- also if you only varnish one side you may warp the hull- best do both sides at same time. keith
- 413 replies
the india ink method is messy but worth it especially if you coat the thread with beeswax afterwards. i used an old plastic tub to soak the thread then hung it outside to dry- then spent two hours scrubbing my hands- gloves recommended! Keith
- 104 replies
- victory
- billing boats
thats looking great m8. will take a while to sort but will be worth it in the end. Keith
- 413 replies
new planking fitted around the transom- each strake was removed one at a time and the new one trimmed to fit. thats most of the brass pins removed- will leave the ones in the new stern planking till the glue has had plenty of time to cure. Templates made for marking out the gunports- used the ones on the laser cut ply sheets for measurements. Keith
Hi Keith looking niceeeee! When i rig my ships i start with the mizzen mast and work forwards as it is easier rigging the forestays working forward. Did you try the india ink for the standing rigging and if so fun and messy lol. Keith
- 104 replies
- victory
- billing boats
I find that sometimes i do things and to me they stand out a mile with neon signs pointing to them! but when people are looking at the model you have to point it out to them! but she certianly looks the part and the new gunport linings do look great. Keith
- 413 replies
not sure how we would set that up but would help 1st timers a lot. when i plank my models i soak the strips in hot water then tweak them between fingers and thumbs after tapering them to size. Keith
- 47 replies
- victory
- billing boats
Hi Michael- we should all form the billing boats victory support group! I have built a lot of billings kit and have a build log of my victory on here. If you have any questions feel free to ask. Keith
- 47 replies
- victory
- billing boats
Certianly looks o.k. from the photos- i noticed when marking out the gunports on mine while planking that some were out of line- i am building mine with the lids closed so will be easier to re-align them. Keith
- 413 replies
Just single planking her Boyd. All the pins will be pulled then the hull filled and sanded, then the wales added. Seems a lot of trouble when she is going to be painted and "coppered" but best doing like this then you know the planks are going to stay and not come adrift. Dont mind the questions at all- keep em coming! Keith
looking good there, brings back memories/ headaches from when i built this a few years back! Keith
- 607 replies
- scottish maid
- artesania latina
nice work so far my man. The whales do not follow the same line as the gun ports. I just googled hms victory- theres loads of nice shots of the whales- though they are a bit hard to pick out on some pics due to the colour scheme. Check my build log for victory- i think i have the planks running right on there. Keith
- 413 replies
Just read you are going to do billings cutty sark next- i have just posted some pics in completed kit built models gallery of my billings cutty- i rigged her as a wool clipper and replaced some of the billings fittings with more accurate sergal ones. Keith
- 104 replies
- victory
- billing boats
