Everything posted by Ian B
Thanks Keith-- I will have a look at the rigging plan again and work the way you suggest. I had fitted the foremast and rigged it before seeing all the advise about not doing that as it was easier to fit yards and sails first.. Thanks Matti the blue was toned down by giving it the same coat of oak stain I used for the hull.
- 51 replies
- bounty
- billing boats
Unless advised otherwise my next actions are- 1.--- make the sails 2. fit sails to all yards 3. attach foremast yards to already fitted mast 4.attach main mast yards - then attach mast to hull 5. fit mizzen mast yards- attach mizzen mast. The main and mizzen are only dry fitted, I thought it would give myself lots of room to work around each mast as I rig them.
- 51 replies
- bounty
- billing boats
My wife has been keeping me busy on the DIY front but I have now finished making the yards. In the kit they are only shown as plain yards with the appropriate blocks attached. I have with inspiration and pure plagiarism from other builds on here created stun sail booms, the support banding around the middle of the larger yards and feet ropes. For the foot ropes I drilled and glued in 3mm loops for stirrups, wrapped line around the yard to make the appearance of them being tied and painting them black. On reflection I should have not had the line tight but sagging slightly between stirrups.. never mind one to remember for my second build. The stun sail boom supports were made from soldered copper wire and blackened.
- 51 replies
- bounty
- billing boats
I just love the way you have handled the furled sails, I am at that stage on my Bounty build and rest assured I will be using your inspiration and techniques...thanks
- 431 replies
- pegasus
- victory models
Thanks Kevin, yes she is. I just need to create some time to complete the rigging. I am looking forward to starting the yards then--something different
- 51 replies
- bounty
- billing boats
I have posted this on another thread talking about Buoys which inspired me to make some for my ship. but thought it worth also adding to my build. I am still working on the main and mizzen masts which should be ready for installing next week some time-fingers crossed Using a couple of old glass beads a bit of string and some wire it makes a reasonable (I think so) facsimile of a 17c anchor buoy.
- 51 replies
- bounty
- billing boats
amazing -well deserved recognition for what looks a simple straightforward display but massively under plays the skill, craftsmanship and patients required to achieve this superb standard.. well done
- 50 replies
- cannon
- le fleuron
wow loads of super info, I am really glad I asked. thanks for the link. Next week I hope to sneak away from doing DIY and household chores when I am home and start creating them. Thanks again everyone. Ian
That's great, thanks for the very prompt reply and explanation. Right now to look at some of the builds on here about scratch building them..
I think I have the right name , it is the parallel booms on the upper side of yard arms. Is this a feature all large square riggers have? It is not shown on my Billings Bounty model but a few Bounty builds and a lot of similar models have them? I am about to tackle making the yards and if they are needed then I need to plan out how I will do it. Thanks
What about this multi purpose machine? The Unimat 83000 it seems to drill, lathe, mill and sand-- I am sure it could make the coffee to? Just google Unimat 83000
HMB Endeavour by mikec - Eaglemoss
Ian B replied to mikec's topic in - Kit build logs for subjects built from 1751 - 1800
:( :( :( makes my bowsprit look a mere 'pointy stick' LOL!!!!!! I can't wait to incorporate some of your ideas into my next build... keep the detailed pictures coming, -
So what we are all really saying is 'there is no definitive answer to this question' and we should leave to our judgment and the ascetics of the model?
Hi , I have only just seem this build log and just wanted to say I really was fascinated by the video clips of the subs in action....well worth posting
automotive pin stripe sticker
Ian B replied to leroy's topic in Painting, finishing and weathering products and techniques
I think if you check on the build logs someone used it on their HMS Worrier...looked good -
Landlubber Mike's technique for furled sails
Ian B replied to Landlubber Mike's topic in Masting, rigging and sails
Thank you Mike for taking the time to create this conversation. This is one task looming up on my Bounty build and this thread has been great in getting right in my head before attempting it, I intend to furl all the top sails and mizzen, a slightly gathered sprit sail and possibility have the main sail and fore main sail fully deployed-- apologies for the non nautical terms and the non standard deployment of sails-- just thought it would look good. -
As others have said 'the nails really make it' what a transformation a little detail (even if it took weeks to achieve) can make. love it
