Posts posted by Ian B
What are the proper colours for the Bismarck greys?
Also I assume the Atlantic camouflage strips are black and white and not something subtly different?
Any suggestions welcome along with recommendations of paint brands--- I will be air brushing where possible (a brand new thing for me)
1 hour ago, hof00 said:
Hi Ian,
That is looking pretty damn sharp!! 🙂
Cheers.... HOF.
Thanks @hof00---As I type this I am sat here installing the PE below the water line (fits really nice) and fitting the rope runners on the bow. The plastic parts for this are very poorly moulded, needed some filling and cleaning before they can be fitted. The propeller shafts are ready to install. So doing all the nice bits
finally after far too many hours of sanding, filling, painting --repeat and repeat-- she is smoooooooooooth
The grey flat piece of wood is so I can practice spraying with my air brush-- I bought this in 2020 and its the first time I'm going to use it it anger ... I want to try and add panel lines, well a hint at them through the top coats of paint and to very subtly weather her-- another first for me. If all else fails-- she will be in pristine paint LOL
looking good look on the bright side--- you took all the pain and trails so i don't have too when I get to that stage--- 😜
Its going to be a great ship to display very soon ..--- feet up and on to the next project ...👍
- VitusBering, hof00, Canute and 1 other
- 4
- Joseph Schmidt, Canute and mtaylor
- 3
On 4/29/2023 at 3:51 AM, Bob Cleek said:
What scale are you working in? Degaussing cables were generally at the waterline. Some went down the entire length of the vessel and others only part way. Some were ever moved around from time to time. Was that 240mm cable 240mm in diameter or circumference? There's a big difference between a nine inch diameter and a three inch diameter. That's a lotta copper either way!
It's 1/200, the anatomy of ships plans clearly shows the position and whole run around the hull. Ill post some pictures on this thread of some samples in the next few days and get some consensus
What sort of diameter would an average degaussing cable around the hull of a ww2 battleship be?
- yvesvidal, wernerweiss, hof00 and 2 others
- 5
3 hours ago, wernerweiss said:
Hello Ian, you' re on the right way, the plan is quite simple....."just" fill and sand and fill and sand and....until the hull looks like made of plastic without the slightest indication of planks....
My way was as follows: when I was content with filling and sanding, I gave the hull a coat of parquet lacquer. When it was dry, I polished the hull with a polishing disc on a drilling machine
Regards Werner
Sounds like a good technique, almost done 👍👍
so grey primer rubbed down, then I masked off any PE and where any PE will go then sprayed the hull with a high build filler primer-- and yes-- rubbed it down again--- now to give it a thick coat of varnish --then a fine rub down which 'should ' just leave a few spots and areas to tidy up---well that's the plan, and we all know what happens to a plan 😜
- mtaylor, NavyShooter, ccoyle and 4 others
- 7
I think the coils look super---don't knock them-- you did a good job on a great build.
10 out of 10 for perseverance--- going to be a great talking point when finished (i guess it is already) when people visit you
- Keith Black, Canute, mtaylor and 1 other
- 4
- wernerweiss, Canute, yvesvidal and 2 others
- 5
Bismarck greys?
in Painting, finishing and weathering products and techniques
Thanks I'll look into it 😃
