Everything posted by mtdoramike
I'm glad you asked this question, This particular ESC comes with a small fan that attaches to the heat sink on the top of the ESC to keep it cool. I'm not too concerned with heat build up because I will include some air intake vents in the top portion of the boat, which should help with air circulation inside the deck. Plus with canned brushed motors it won't run as hot as brushless motors. Now, if I find that the motors are running too hot, which is what I would be more concerned with, I can get cooling tubes that slip over the cans and run water lines to cool them but usually this is only needed for racing setups or running for long periods at one time, which this will not be doing unless the owner who ever it is decides other wise and if that is the case, they can set it up any which way they want. Or if they put a bid in to buy the boat before I'm finished with it, I will try and make any changes they want. mike
- 146 replies
- dumas
- Chris-Craft Commander Express
I found a battery that will work for my application and a Electronic speed control. I lucked up on the battery on ebay and was the only bidder and got it for $20.00 and normally it sells new for $70.00. The ESC I got for $25.00 on a pre Black Friday sale. It will handle two canned brushed 500-700 motors with forward and reverse.
- 146 replies
- dumas
All I can say is WOW, What a real beauty. mike
- 339 replies
- dumas
- Chris-Craft
(and 3 more)
Hey Ian, I did the same thing on my Vic and lined the Gun Ports then sanded the hull down which made the gun port linings disappear. So I had to go back, rip the linings out, paint the lining planks red BEFORE I installed them the second time, which made a huge difference. That was about a weeks of added worth of work to fix that issue. I had to step back for a few days before I fixed. I hate having to do something twice. mike
One side of the chain plates are done. I don't think I have ever built a ship model with as many dead eyes as this particular ship model has.
Hello Les, I think your problem is the other kits are calling to you. I try and not have any other kits around while I'm building a specific model. This keeps me focused on the project at hand rather than looking at future projects thinking they might be easier or I just need a break. The problem is when you take a break, that same project will be waiting for you and you will start feeling guilty for not buckling down and finishing it. This forum is full of models that were started with good intentions, put aside for various reasons, but the main reason is usually lost interest if the builder is honest about it. I have to say here that after close to 20 years of building models and 30 or so ship models that I finished, I don't have a single model laying around that I didn't finish. No brag just fact. Now, yes, I too have those days where I don't really want to mess with the model and even weeks. But I try and push myself to spend a minimum of an hour a day on the model even if it's just to research the build. Like today for instance, I went into my work room, attached a couple of pieces to the model, only to realize that I did it wrong and had to straighten it out. That is when I called it quits for the day. But the two days before, I spent most of both days on the model. I have bought soooooo many models from friends, ebay, forums and Craigslist where they were started with good intentions but the builder fell short and didn't finish them. Some I was glad they didn't finish because the work was so bad, others I couldn't understand how someone with such a gift for modeling couldn't stay focused long enough to finish the project. mike
Isn't this a beautiful piece of wood. I dust the display board off every now and then and spend probably 15 minutes just admiring the beauty in the wood. I might have spent close to $40.00 for that piece of wood, but it was well worth the price. mike
I'm currently working on the chain plates. I wrap the deadeyes in brass wire and then twist it. I then slip it into the hole in the chain plate board, cut it off and then bend the end up into a hook. Then I take one of the long length eye bolts that I found some time ago at Hobby Lobby and hook it into the fashioned hook on the deadeye. I then cut eye bolt to length bend it, drill a small hole into the hull and slid the end of the eye bolt into the figure 8 fastener and then into the hull with a spot of glue. I then nail the bottom of the figure 8 fastener. It seems to give me the best and cleanest finish as far as the chain plates go. mike
Well, I have decided to sell the Chris Craft Commander once it is completed. It will come ready to run with all equipment from battery/charger, radio and ready to go. So if any interest in this model, pm me. It's not something I'm really interested in and my son in law feels it's a might more than he would be interested in as well. mike
- 146 replies
- dumas
hahahahahahaha, my wife accuses me of that old the time, I call it selective memory and hearing But I'm going to do the same thing with the plating kit. mike
- 146 replies
- dumas
Yeah, I was planning on Mack's for the motors and props. I had already bought the running hardware by Dumas and then I saw Mack had their own running hardware setup for the Commander that is supposed to be better than Dumas setup. mike
- 146 replies
- dumas
I would also like to get a three blade brass prop rather than the two blade. mike
- 146 replies
- dumas
I'm most likely going to replace the plastic props with brass ones once I get into the installation of things. mike
- 146 replies
- dumas
I located and purchased the running hardware for the Chris Craft Commander. I hope to have everything I need before beginning on the build in March. The cost of the running hardware alone was $70.00 shipped from Omni Models. Now, I'm trying to decide whether or not to use nicd/nimh batteries or opt for lipos. I really like the lipo batteries in the RC planes I flew, but this is for my son in law and my grand son. Lipos give longer run times, more power and longer storage charge, but nimh batteries are less volatile, less worry with storage. I will be running twin 550 can brushed motors in it. So I'm on the fence on the battery setup. mike
- 146 replies
- dumas
hahahahahaha yeah and I was staring at that bugger for a while. It's not as good as my bench top 36 inch belt/disk sander was, but it does the trick in a pinch for sure. I've had that old work mate for about 40 years. It's not like the newer ones, this one weighs a ton and not that cheap metal ones they sell today. mike
I'm continuing to go up with the mast. Here is my make shift sander that I use while making the mast and spars. I used this setup on the Victory as well since I sold most of my modeling tools several years ago when I got out of the hobby for a while. Yep, it's a Craftsman belt sander clamped upside down to my old Black and Decker workmate. mike
I have not started the build of the Commander as yet, I'm still working on my current project and probably will not be finished with that until March. But I am how ever buying all the needed Radio control gear when I can pick it up at a good deal. I have the transmitter with two receives, just picked up a battery charger and a couple of servos. Here is a list of needed equipment: Transmitter & receiver (got them) Battery charger (got them) Two servos (got them) Battery (lipo) Two motors running hardware kit Reversing speed control (preferring electronic over manual) Now if all of this equipment was purchased normally, it would run about $600.00. Running hardware kit is about $80.00, not to mention the motors, which about $120.00 for brushed, if brushless then the price goes up, the reversing speed controller is another $50.00. I figure all total I will have close to a Thousand dollars invested in her, which I think I will name her the MONEY PIT! I starting to believe in the old adage "The two best days in a mans life is when he buys a boat and when he sells it." mike
- 146 replies
- dumas
I spent a few hours on the Monte today and got quite a bit of work done on the Foremast and the Bowsprit. mike
hahahahaha, yep Mark it sure is and at 49 inches long with that bowsprit sticking out so far it will be a challenge just to keep from breaking it off. mike
