michael101
Everything posted by michael101
  1. Thank you EJ_L and happy to see you again i missed that forum , the build and the smell of the wood just happy to be back
  2. Hello friends , after long time I'm updating my build log, 6 month ago we had a baby so I not had the time even to think about the build but now starting again ... so 6 month ago I left the ship after finishing the first plank and now im working (very slowly but working lol) on the gallery here is some pictures how I left the ship :
  3. Hello Wallace it will help you a lot !! just be shore that all is exact 90 degrees and also in the straight line !!! take your time and do it very carefully ! if you need any help you can send me p.m Best regards, Michael.
  4. hello there, i had this kit before ... (and i turn it back ... i payed around 1200 dollar so it make me upset to dill with the bulkheads problems of that kit ,but dont worry about that ... you can fix all the problems like i said i turn it back only because i payed a lot on it .... ) a few tips about the bulkheads problems 1. before you will start gluing and fixing the bulkheads ... just make sure that all the bulkheads are symmetrical in both sides you can use a card for that (dont trust the plans even at the plans its not symmetrical ) 2.be sure to fix all the bulkheads on the same level ! (i mean to make them on the exact level on the deck line) , im not remember if the deck line its a flat line or there is a curve ... just check in in your plans and if there is a curve line just measure the distance from the bottom to each deck line in every frame ... and do the same position when you will glue the frames on the keel , after all ... you will notice that there is some bulkheads that going in from the planks line and some of them going out , now take your time to fix them (even if it will take you forever .... dont jump to the second process until you will finish this process !!!!) Best regards Michael.
  5. Cant see the difrent between MDF to a cardboard both of them was a wood in the past... And that is for sure the MDF sometimes its more stable even from solid wood because it made in mold... but all this its good until the humidity get contact with this new material then it getting a critical damage ..... and it not worth the time to work few years in a model that will gate a critical damage in the future Btw in Israel they made a new MDF that is much stronger than the normal one and it didnt past the test of our army ... (and im not talking about guns ... just talking about office desk of the army)
  6. For sure it is the Caldercraft !!! Its expensive but It's worth the money (every cent ) just buy it without thinking too much .. i was in the same situation before i bought this kit and thanks God I am very pleased !!! You can follow my build log and if you will have some questions you can p.m me
  7. because its not wood ... also in the future you cant know what can happen to the model due the humidity temperature act.. better to pay a little bit more and to work with wood but again its my opinion Regards, Michael.
  8. Im also working only with the Steel files
  9. strange, btw also this kit made of 5mm MDF cant understand that
  10. If I remember well the 1/64 kit it made of MDF (keel and bukheads) not sure , but if so .... it much better to build it from plywood and If the material is not important just build it from plastic anyway for my opinion if the keel and bulkheads not made of plywood its not a wooden ship... in my country we called to MDF - a cardboard best regards , Michael.
  11. You are lucky to have in order lime wood if you want search in my build log of the victory some method on how to bend the planks
  12. Hello Ronald , I bought the tools in my country - Israel and most of them are Proxxon but you can find in this link dealers of Proxxon in almost every country https://www.proxxon.com/en/dealer/search-dealer-germany.php Best regards Michael.
  13. That is true Matti , good idea about the iron angles !!! when i bought my plywood i took the strone one i dont know the name in english but they used to make doors from this plywood its a bit expensive but it worth the money btw i think it cams also from finland Best Regards Michael.
  14. The jig i made it without plans , You just need to take make a straight line on the base and then connect the supports (90 degrees supports) between the bulkheads, you can use the keel as a guid when you connecting the supports the only thing that you need to worry about its to have a straight plywood for the base it will help you later when you will measure the distance between the bulkheads to the base for making sure that all the bulkhead are on the same level ! , and also you must be careful about the supports to make them exact 90 degrees for both sides it will help you to check the level of the bulkheads by measuring from the top of the bulkhead to the base in both sides Be carful when you making the jig and take your time , its the must important process for the all body of your ship !!! Best regards, Michael.
  15. Very Good news !!!!! i just love mamoli !!! My first kit ever was the bounty 1/100 of mamoli , im very glad that your project came thru ❤️ Best regards Michael.
  16. Hello Ronald , Thank you for your coment about your questions , for the first one i have used mascking tape and paint with airbrush , about your secound question im not sure that im understanding your question can you repet ?
