Everything posted by Elijah
- 228 replies
- gunboat
- model shipways
So, I've stained the hull, inside and out! The outside was not very difficult. The inside was a little more tricky. I'm thinking, since the pre stain wood conditioner had been allowed to set in for more than a week, I don't think the stain was able to set in as well. That being said, I don't think the look is that bad, so I think I will keep it. I noticed, after letting it dry for two days, it had a bit of shine on the inside. I used some sandpaper to take that shine off. The outside and inside look to show significant wear. What do you think of the finish? The initial shine of the stain after drying.
- 228 replies
- gunboat
- model shipways
Nice work! It does look like you could tip it with a feather......
- 449 replies
- sultana
- model shipways
Looking nice! Are there any rings for the hawse pipe ends?
- 449 replies
- sultana
- model shipways
Thank you very much Kurt! That would be great!
- 228 replies
- gunboat
- model shipways
Wow! Dave, those sails really make her look great! Did you have any prior experience in sewing before making these sails? Not to rush you, but what ship is up next?
- 245 replies
- bluenose
- model shipways
Happy new year! Recently I attempted to stain the interior of the hull. As we all know, hindsight is 20/20. Well, stupid me from a few days ago forgot to shake the container of the stain before using it! This meant that all the pigment was settled at the bottom. The stain I tried to apply had little to no effect. The interior is now a shade darker, mostly due to the pre-stain wood conditioner. Anyway, I now have some shopping to do! Attached is a photo of my staining setup.
- 228 replies
- gunboat
- model shipways
Wonderful work Bob! Do you paint with an airbrush or a normal brush?
- 682 replies
- halifax
- lumberyard
Yes. The demo pictured above was treated with Minwax pre-stain conditioner before it was stained.
- 228 replies
- gunboat
- model shipways
This is the same wood used on the model. This test was constructed from scrap planks leftover from planking. All of the model is the same wood, I believe its basswood. Its the same stuff you get in most model shipways kits.
- 228 replies
- gunboat
- model shipways
Looks amazing Bruce! One problem.... Do you know that the knees attached to the mast partner don't correlate to the plans? If you look in the plans, the long side attaches to the mast partner and the short side attaches to the hull. The added details look great though!
- 67 replies
- philadelphia
- model shipways
So, I'm trying to decide on which color to stain the exterior of the hull. I have it down to two couples in considering. The one on the right and the one on the left. I'm thinking I will do the center color for the interior. Left to right, the stains are Minwax Dark Walnut, Special Walnut, and Provincial. What's your take?
- 228 replies
- gunboat
- model shipways
The bolts look very nice E.J! Can't wait for more photos!
- 961 replies
Thanks, that sound like it should work.
- 228 replies
- gunboat
- model shipways
Thanks Mike! Though they are two different metals, I plan to paint it to make them work together. My only problem is that I'm not very experienced with gluing metal onto metal, so I don't really know what I'm doing!
- 228 replies
- gunboat
- model shipways
Thanks J.P, Bruce, and E.J! Also, thanks for all the likes!
- 228 replies
- gunboat
- model shipways
- 228 replies
- gunboat
- model shipways
- 228 replies
- gunboat
- model shipways
Progress moves on at a very slow pace. The aft storage chests were fairly simple to make and fit. The mast partner was fit per the Ships In Scale articles. Two nails were used to secure it on each side. It has not been permanently installed to make other tasks easier to accomplish. The 12 pounder sliding track was also a straightforward job. Lines were drawn on the deck to show proper positioning, then the parts were fitted and glued in place. Now for the more difficult and interesting part. The hawse holes! I searched the local hardware store for a brass tube of the correct size, but found only an aluminum one to be the correct size. I decided to go with that, as the hawse holes will be painted anyway. If you see a potential problem with this, please, say so. I first drilled the hole, then filed it to it's final shape. There is still one more to do. Now, here are the photos!
- 228 replies
- gunboat
- model shipways
That sounds like a good method, but I have one question. What is pledge? p.s. Dave, I couldn't agree more right now.
- 653 replies
- trabakul
- marisstella
Don, what is your procedure for cleaning your models?
- 653 replies
- trabakul
- marisstella
Those cannons are very nice Bob! What have you bee using to finish the carriages and other wooden items?
- 682 replies
- halifax
- lumberyard
Wow, very nice! She looks fantastic! Are you going to make or buy a display case for her?
- 653 replies
- trabakul
- marisstella
