Jaekon Lee
Everything posted by Jaekon Lee
  1. Really good idea. I'm so happy to find this info at the right time. Thank you and Dr. Michael. Lee
  2. Very nice hull planking, Paul. May I ask what kind of nails did you use and how did you blacken them?
  3. Garboard Thank you Nils. Small update after long break. For the start of clinker type planking of port side, the garbord strakes were attached along the keel. Rabbet was scored at the upper side of strake to receive the plank strake above. Cheers, Lee
  4. Going outside of hull By the lots of joining long stuffs, she became strong enough to work on outside of hull. First, stepped and rough starboard side surface of frame was smoothened with rasp, file and scraper was used for final finishing. Port side frame surface, where the planking will be scheduled, was only finished with rasp. The main wale was prepared with 2mm thick ebony strake. They were steam bent and joined at the same height of upper deck clamp. Next step will be the planking of port side by clinker type. Cheers, Lee .
  5. Treenail simulation and finishing of inner hull After removing upper deck beams, I tried treenail simulation with hypodermic syringe needle on the inner hull planking boards. It is the good place of experiment because this place will be invisible after upper deck planking.
  6. Hi, I always appreciate your kind words and "like"s. Alex and Nils, thank you for the kind recommends about deck beam and I agree with you. At this moment, I removed all the beams from the ship and will observe closely the shape change, however, I'm not so worry about the flattening of beams because the hull wall will act as the constraint of shape change. Anyway, this is a good chance of experiment and in the next project, I may take the method of shape cutting. Regards. Lee
  7. Hi, Siegfreid the Dragon fighter, I've just catch up your build log. Thank you for sharing your really great job and beautiful coloring. Lee
  8. Upper deck beam Cambered upper deck beam were prepared by steam bending method and joined on the deck clamp temporarily. Bending was more simple than cutting curved beam, however, it is not easy keeping bending radius constantly for each beam. As can be seen on the following pics, some of beams are needed rectifying the curvature. After marking the position of carling, they will be removed for scoring recesses, attaching hanging and lodging knees and so on. Regards, Lee .
  9. Nils, many thanks for your warm words and tips. Long time experience of wooden furniture making as a hobby, woodworking for model ship building is familiar with me. But the rigging, I've never done yet, seems highlight of ship modeling. Yes, rigging of Alert will give me a good chance of experience. Fortunately, she has only one mast.
  10. Fantastic work you are doing. I can not imagine I can do rigging and sail like you in the future. Lee
  11. Thank you Wyzwyk for your interest on my building log. Thank you Druxey for your kind comments on the planking line. Though the upper thick stuff lines are much curved upward, they ended just below the upper deck hook fortunately. I think the ends should be terminated at around upper breast hook to get more reasonable result.
  12. Upper deck clamp, deck hook, inner hull planking between deck clamp and thick stuff. Upper deck hook was joined directly to the stem and hawse pieces at the height of upper deck line. The deck clamps were also placed at both side of inner hull following the deck plane line. Then, inner hull between clamp and thick stuff of port side was covered with normal planking boards as was done below the thick stuff. Cheers, Lee .
  13. Question about planking line As shown in the pictures, flat lower deck plane at the midship is almost coincide with upper thick stuff plank line, however, at the fore most deck plane is far below from the line, ie., inner hull plank line seems too much curved upward at the fore section. Is it generally right or I made mistake? In Goodwin's book, he did show very little information about inner hull planking. He only commented thick stuff placed over the chock of futtock joint. So I followed that as possible as I can.
  14. Thank you Nils, Mark and Michael for your generous compliments and "like"s. Nils, I stumbled on small black blanket is so effective for making contrast of model ship with my mobile phone camera. No special tech.
  15. Lower deck planking Half of lower deck (port side) has covered with plank boards and oil finished. During planking, blackened glue was used between the plank boards to simulate the calking. Treenailing was disguised by pointing with awl before oil finishing.
  16. Hi, Johann. Happy new year. Really amazing detail with your fine metal working. There is nothing impossible. Great!
  17. Little progress of lower deck planking. Cheers .
  18. Thank you Antony and Nils for your encouraging words and interesting. I'm learning lots of things through this building though I made many mistakes. I hope this practice makes me better for the next project. Regards
  19. I'm very happy to hear that Christian. Your work is also very helpful to me. Lee
  20. Lower deck beam and deck planking, pump well and shot locker Happy new year 2015! Lower deck was partly planked over the aft magazine. I'm not sure my understanding of plan around the aft clutch, some part of clutch crossed the deck plank. In this small ship, lower deck beam structure is so simple, ie., beams are not curved (no camber), no knees and a few carlings. Pump well and shot locker was installed in front of lower transverse bulkhead. Cheers.
  21. Hi, Giampieroricci. I just find your fantastic building log today. You are so skillful and seem to know everything of model ship building. I can get lots of tips with your log. Please look at my building log and give some advice. Thank you again. Lee
  22. Treenailing, aft magazine & lower deck beam, oiling... some progress at the inside of hull In this small scale, diameter of treenail would be about 0.5mm, however, it's not easy for me making treenail of that size. Yes, from the other's building logs, I learned how to make treenail with draw plate but I failed. I think I need more experience. So, I drilled 0.5mm empty holes without treenails on the planked board. I hope I can try again in the near future. The fitting on aft magazine was simple, light room and magazine access stair. Lower deck beams over the magazine were added. One more progress was finishing oil trial. I usually used linseed oil and wax for the finishing of furniture but they have a problem of bonding strength with glue on the oiled surface. So I tried varnish type oil and found that the result of joining strength and color was not so bad. Happy new year! Lee
  23. Many thanks Antony for your generous words. I hope you and all visiting here have great time in New Year. Best Regards
