Everything posted by KeithAug
I have never had much success with paint - particularly on brass. No matter how well I prepare the brass the paint seems to be easily damaged or subsequently flakes off. If you do try painting and have success I would be interested to know what you did and details of the paint etc etc. Good luck.
- 236 replies
- Chile
- Latin America
(and 5 more)
Phil - you clearly missed out on the late 60's early 70's "Flower Power" era!
- 218 replies
- minesweeper
- Cape
John - Me neither for much of my life. I do however remember borrowing a Sinclair Scientific calculator for my finals in 1975 - a mere 50 years ago.😬😬. I also remember our first family B&W TV in 1958 - 67 years ago. I also remember being inspired to start my boat modelling career when I watched Noah working on his Arc.
A little more progress. At the front of the stabilisers are a couple of metal fillets - presumably to deflect debris from the gap between the stabiliser and the hull. I'm not sure why the holes in the stabilisers are for and I have omitted them in error. I'll need to go back and insert these. I cut the fillets from brass and included a web for mounting. Cutting the slot in the hull was another stressful operation - I marked the slot position with card. Before cutting the slot with an x-acto keyhole saw. I took my time to avoid damaging the hull varnish. The stabilisers and fillets were then Temporarily installed to test the fit. Then it was on to preparing for the paint job. Starting with the waterline stripe. I was having difficulty getting the waterline to sit at the correct height at bow and stern using the laser level. After some head scratching I realised that the bench wasn't perfectly horizontal. This of course wouldn't have been a problem if I had been marking the waterline with the traditional scribing block and pencil method. To sort the problem out I had to shim the base board at the bow. I also had to place a spirit level on the bench (as a track for the laser level), also shimmed to be horizontal. (See arrows). Having sorted the levelling problem I went on to mark the waterline by laying the masking tape directly to the laser line. After changing the height of laser I went on to mask the upper edge of the waterline. Of course I then had to turn the hull round and re-level before taping the other side. I didn't get any further with masking because I got the call for dinner. One must never delay when called by "she who must be obeyed" or the dinner will be in the dog.
I am always amazed how far Cornwall Model Boats business extends. Nearly as famous as Wall Drug. Always a tricky and stressful job Bruce, but you executed it well.
I presume the flower arrangement was standard naval issue Phil?🙂
- 218 replies
- minesweeper
- Cape
