amateur
Everything posted by amateur
  1. I have a question, not on your fantastic technique, but on the reality of gun-handling.... Quite often, you see ringbolts placed in the deck, and a tackle rigged (sometimes even two) to haul back the gun in order to sponge out and load. Seeing how far the gun has to be run backwards to get the sponge in the barrel, I was wondering: were should the ringbolts be placed to get the system working? Jan
  2. Ah... King George V, ofcourse...... Jan
  3. Hello NBP, Question1: is it NBP we have to use, or do you have a name? Question2: which ship is KGV? Question 3: can you show us your KGV (in the water...) Jan
  4. An Aircraft carrier I presume....
  5. 1:100, that will result i a model of around 2.5 meters? Does that fit into you living? (btw I guess you have already bookmarked the 1:72 Scharnhorst here at MSW?) Jan
  6. Tigris: http://www.worldnavalships.com/directory/images/001564_1_hmstigris.jpg https://images.vesseltracker.com/images/vessels/midres/Tigris-727137.jpg Jan
  7. ehhh.... is this a guess, or can you tell us WHICH Euphrates? btw How many are there of those?? Jan
  8. actually, everything we take for granted now is post 1900.... http://www.flickr.com/photos/historicdockyard/6149161183/ Jan
  9. The question is: would Nelson recognise this entry-port.... There is a nice model in NMM showing Victory as she was supposed to be n 1803 without the entry-ports.http://collections.rmg.co.uk/collections/objects/66474.html There is alos a model that shows victory as she was supposed to be in 1805 sith entryports and even a platform outside the hull.... http://collections.rmg.co.uk/collections/objects/66475.html The one without is assumed to be the contemporary model Jan
  10. Hmm... the most obvious is not necessarilly the most pleasing to the eye..... Jan
  11. What did you discover about the entry-port? That it was not there at all?? Jan
  12. Ah well, now it's the question: minesweepers were build by the hundreds. Do you really want a name? Dokkum-class has 32, Alkmaar-class has 18, I guess yours has 10+ as well..... Jan
  13. Minesweeping....yeah I already figured that one out Jan
  14. btw the one in the foreground (woith the Dutch flag) is also a Dutch minesweeper, from the Alkmaar klasse But the one in the middle..... Jan
  15. Hmmm.... the flag is the red herring. Dutch navy did not have this type of tuggies around. To the right are two Dutch minesweepers of the Dokkumklasse. However, in the middle..... The location is probably the Rijkswerf in Den helder... Your slightly uneven resize doesn;'t help either Jan
  16. And remember: kits tend to 'underprovide'..... Jan
  17. Something in common that is unique.... Quite a contradiction, isn't it ? There are loads of frigates painted around 1830..... Jan
  18. "It's like a fly/Pegasus-kit on steroids." That would be my problem with it....I don't like steroids Jan
  19. Wiki says that it is the flag of the Honourable East India Company after 1801. Quite a lot of checkered frigates over there.... Jan
  20. No, it's not the way of planking itself taht put him off, it is that the form of the hull itself does not correpond to the form it should have (at least, according to Arjan). That requires substantial reshaping of the frames, which made him stop the build. I am with you on the point of starting implies at leastthe intention to carry through to the end. Although: there can be many reasons why a once started build does not continue. Lack of time, money, inspiration etc. can all be reason to stop and do not return for a while. Jan
  21. It's Holmvik, yes. In the Netherlands better known under her current name 'Furie'. She was restored form an old and worn wood-tugging ship from the sweish waters into a Dutch seagoing tug, becasue of her role in a film on the topic. She is therefore still around as an example of the last Dutch steampowered seagoing tugs. Jan
  22. Next one (easy one, I would say) Jan
  23. Euphrates Jan
